I have canon pixma mg5470 multi.functional printer , I am Using Refillable Cartridges after a couple of weeks of using I shows the error for Black BK "The following ink tank cannot be recogonized" Support code 1411. Please help me
SOURCE: MY Canon Pixma MP 500 Printer won't Print.
Reset the device when it is not functioning properly. If the device is not functioning properly or to clear memory, reset it.
  1. On the operator panel, press and hold the <ON/OFF> button for one second. (The display will go blank.)
  2. Wait approximately ten seconds and then press the <ON/OFF> button again.
  3. Wait until the device has completed its cycling process before submitting another job request.
  4. To clear error messages displayed on the LCD or if the printer is not functioning as expected, it may be necessary to simultaneously press Stop/Reset and ON/OFF buttons.
  5. With the printer powered on, press and hold down the <Stop/Reset> button then press the ON/OFF button.
  6. Once the printer is powered off, hold down <Stop/Reset> and then press <ON/OFF>.
  7. clear any paper jam
  8. May be your product requires repair service.
Posted on Apr 03, 2008
SOURCE: How to Override Ink Level Gauge When Using Refilled Cartridges
I have the same problem with my PIXMA IP 3300. The ink cartridges have 4 electrical contacts on the front. I think the ink level gauge is controlled with these contacts. This is probably just another ploy from Canon to stop you from refillng these cartridges. If anyone knows a way around this , please let me know
Posted on Sep 19, 2008
  • 899 Answers
SOURCE: Error Code UO43
the wire strip that connects to the printing cartrige is probably brole or just comming out of its plug
try to push the wire strip back in and see if that does any good , if not then there is a problem inside of the printer
the wire strip is broke or comming unpugged or the detection circut that sees the cartriges has failed and needs repair
hope that helps!
electech
Posted on Oct 20, 2008
SOURCE: Canon Pixma IP600D - error code 6502
Sometimes the Canon printers which use PG-5BK/CL-8 colour cartridges with chips will give error massages like 6502 or other types of error message to do with the cartridges, which has the orange light flashing and the printer will not work. Follow this procedure which quite often resets the printer and allows it to resume printing.
When error is indicated, turn power switch off so green light is extinguished.
First hold down resume button and then hold down power button so both are held down at same time
When green light comes on, continue holding down power button and let resume button go, then press resume button twice. Then let power button go.
Then press resume button four times, power button should be released before doing this.
Wait until printer settles down, if power is off, turn on. If power will not come on, remove power cord from back of printer, then wait 15 seconds before plugging back in again and turn power on. This normally solves the error problem - if not go through same procedure again.
Incidentally, you may find that if the chips had previously been disabled, the low ink warnings are showing again and they will have to be disabled once more. This would indicate that the above procedure clears the firmware memory of the disabling of the chips, this may be useful if you need some warranty work done on your
printer after the chips had been disabled.
Posted on Jun 10, 2009
  • 37 Answers
SOURCE: Using refillable cartridges on epson 4000 low ink reafding on blk
click on the first link and follow the instructions. if this doesn't work, then try clicking on the secind link and method.
http://www.fixyourownprinter.com/forums/inkjet/52056
http://epsonresetter.co.cc/reset-printer-epson-RX650.html
Posted on Jul 27, 2009
Why lexmark 3550 won't print after installing new ink cartridges
Check your manual for instructions about this type of problem. Are you using the ink cartridges meant for your printer? Sometimes using refillable cartridges instead of the manufacturer's cartridges can cause the printer to still think the cartridges are empty, and display an 'on-screen' message that they need to be replaced, which could stop the printer from engaging. I have a Canon Pixma printer, installed refillable cartridges, and now the unit displays a 'cartridges are empty' message on PC screen; but the printer still works. The system just recently went into a non-printable mode displaying a more convincing message that the black cartridge is EMPTY, and completely stopped printing. The solution to this: press and hold the Stop/Reset button for about five seconds, and it overrode the issue and started printing. Moral of the story, maybe its best to just buy the manufacturer's printer cartridges.
Jul 26, 2014 | Lexmark Office Equipment & Supplies
I have a canon mp630
It has been reported that some manufacturers have issued an update which can cause the printer not to run generic cartridges, could also be a faulty cartridge, change this first.
Jun 01, 2014 | Canon Refillable Cartridges For Pixma...
Reset ink level on canon mg2120 after ink refill
The following procedures may be used to reset the Canon printer ink level monitoring following the installation of a refilled Canon 30, 31, 40, 41, 50, 51, 210, 211, 240, or 241 integrated ink cartridges. In most cases, the error/alert will need to be cleared to enable printing. Ink waste container reset procedures are also provided below.
NOTE: for multi-cartridge installation, the procedure(s) may need to be repeated twice.
For PGI-5, PGI-9PBK, CLI-8, PGI-220 CLI-221 PGI-225 CLI-226 PGI-250 CLI-251 Cartridges: These are new Canon cartridges which have an embedded chip on each cartridge. If you just refill the ink, the printer will still reads the cartridge as empty. You have two choices:
Purchase a "refillable cartridge" from www.asapinkjets.com
BCH or other sellers. These refillable cartridges have an auto-reset chip (non OEM) and will reset automatically.
Use a chip resetter (e.g., search Canon + model number + resetter on eBay). Follow the instruction below to refill your original cartridge, and use the resetter to reset the chip.
Inkjet Cartridges and Toner Refills
Aug 29, 2012 | Canon PIXMA MG2120 Inkjet Photo All-In-One
What is error e5 in mp 198 printer
E5 - The ink cartridges are not installed or a non-supported ink cartridge is installed , or the ink cartridges are not installed properly..
  • In certain models of Canon Pixma printers such as the Canon MP160 and Canon MP150, you may receive an E5 error when trying to print. In this state, you will not be able to use any of the functions of your printer. The error itself is an ink cartridge error. It may be that you are using generic or off-brand ink cartridges in your Canon Pixma printer. Canon Pixma printers do not work with other brands of print cartridges; invest in Canon brand ink cartridges and this should take care of your problem.
  • Nov 18, 2010 | Canon PIXMA MP210 Photo All-In-One Printer
    HOW TO REMOVE E5 EARROR
    make sure you removed the orange tape from the cartridge.
    usualy E5 is when the color cartridge is faulty but if the orange tape is on the cartridge it will show E5.
    if you removed the orange tape an it still shows E5 go with the cartridge to the store where you purcess it for excange.
    Nov 18, 2010 | Canon PIXMA MP150 All-In-One InkJet...
    Error code U163 on cannon pixma mp220 printer
    Those cartridges don't refill unless you have a way to reset the internal chip. Check online for refillable cartridges or a chip resetter. For priming you go into printer properties and choose maintenance and head cleaning, or choose cleaning from the front panel.
    Feb 15, 2010 | Canon PIXMA MP530 All-In-One InkJet...
    Canon MX850 will not print from small Black Ink Cartridge - 8BK. It only uses the large black ink cartridge and I have a drawer full of small 8BK cartridges. How can I get it to use the small black...
    Canon PIXMA MX850 Multi Function Printer Printer Canon MX850 will not print from... Answer Canon MX850 will not print from small Black Ink Cartridge - 8BK. It only uses the large black ink... (More) Canon MX850 will not print from small Black Ink Cartridge - 8BK. It only uses the large black ink cartridge and I have a drawer full of small 8BK cartridges. How can I get it to use the small black cartridge and not the large black cartridge? Thanks
    Sep 30, 2009 | Canon PIXMA MX850 Multifunction Printer
    My canon pixma MP145 showed E5 and wont print anymore
    I have been using black and color ink refills for sometime now, but am unable to use my printer since last week. It shows E5 and on the dialogue box is stated that it cannot recognize the COLOR.
    Aug 07, 2009 | Canon PIXMA MP160 All-In-One InkJet...
    This maybe in the manual under ink tank replacement, most cannons have this, but keep in mind that sometimes the ink feed tubes to the print head get clogged and then the printer will report no ink at all, these cansometimes be cleaned by soaking them in acholol
    May 28, 2008 | Canon PIXMA iP3300 InkJet Photo Printer
    44 people viewed this question
    jasbo
    jasbo
