Question about Mitsubishi WD-73737 73 in. HD-Ready TV
Mitsubishi wd 73737 green light then red - Mitsubishi WD-73737 73 in. HD-Ready TV
premtech
  • 934 Answers
SOURCE: mitsubishi wd-62825 dlp
The WD62825 has a Digital Module located on the left side of the chassis looking at it from the rear of the set. It's housed in a metal box that can slide out of its holder after removing the trim screws.
The module has its own power supply board and there are a group of 16v/1000uf caps on that board which commonly fail causing the constant flashing standby light. Further back on the module is a small board about the size of a matchbook called the E2P module. Its SMT (Surface Mount Technology) caps also commonly fail which can cause the same symptoms. Techs can tell whether the E2P has failed by simply removing it, hooking the DM back up and trying to power the set. If it powers on the picture won't be much good - but at least you can tell what's keeping it down...
Back to the caps on the pwr board. If they've failed they usually will buldge visibly on top. And ESR is almost not necessary. In any event that's the nuts and bolts on this model.
Is it a job for a layman? Yes and no - you might strongly consider a tech if you don't feel comfortable removing all the connections that the DM has with the signal board. There are about six - multi-pin - wired connections to unplug and then sliding the DM out of the unit and carefully removing the screws and latching to take the DM top cover off...
Hope this helps.
Bill
Posted on Nov 10, 2007
  • 6 Answers
SOURCE: Mitsubishi WD-62628 power shuts off!
I have the same issue have not done the repair yet but here is a link to photos of the various boards and the problem caps:
http://www.fixya.com/support/t155026-
flickering_blue_picture
Posted on Feb 16, 2008
  • 103 Answers
SOURCE: Mitsubishi WD-62725 constant blinking of green light
Check the lamp to see if it is damaged(this is in your owners manual for removal)If not please contact me for more info
Posted on Apr 26, 2008
Slinteriors
  • 8617 Answers
SOURCE: mitsubishi wd-62725 rear proj green timer light will not reset
you need the V26 DLP DM repair kit at the following link. The kit contains the replacement capacitors and the cd with instructions.
http://www.tvrepairworld.com/
Posted on Jul 20, 2009
ladywinn
  • 5138 Answers
SOURCE: Hi there...I have mitsubishi WD-73927 manufacture
If your TV is DLP , Then your Light engine is Bad,when color changes and little spots appear it is light engine.
Posted on Aug 19, 2009
Blinking green light
Sounds like a lamp problem itself. Anyway, if you wish to make it sure, check the site linked here. It has details about the blinking codes to Mitsubishi. http://electronicshelponline.blogspot.com/
Pull up previous posts by its left sidebar, or type in the brand name and model number to of your set, to its search box, and press 'Enter' or view it in Mosaic / Timeslide option.
Sep 28, 2013 | Mitsubishi WD-73737 73 in. HD-Ready TV
If the blinking is continious, the fault should be at its main digital board, as these blinks indicates a SDA - SCL probelm, says technically as IIC problem.
May 14, 2013 | Mitsubishi WD-73737 73 in. HD-Ready TV
Error code 61 on WD 73737
Retired tech says, may be one of the fuses/resistor/transistor in unit blew out. reset won't work
Aug 28, 2012 | Mitsubishi WD-73737 73 in. HD-Ready TV
How do i reset a Mitsubishi WD-73737 73 in.
The green light blinking is the set trying to boot up especially if power lost---70 seconds and should stop. Here is a link to a question I answered that might be helpful:
http://www.fixya.com/support/t12296849-turns_off_shortly_after_turn?mt_f=viewFull162
Wd73737 blinking green power light
my tv keeps turning off i have a mitsubishi wd-73737 what can i do to fix it?
Jul 12, 2010 | Mitsubishi WD-73737 73 in. HD-Ready TV
Mitsubishi WD-73737 73 in. HD-Ready TV Logo
98 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
