Question about Poulan Garden
Trimmer starts but stalls. I believe I may have made mistake reconnecting lines from carb to bulb to tank. Need to know what goes where
    Problem Solver:
  • 19 Answers
Fuel line wrong way round prime the carb and hold thumb over two outlets on carb feel for the one whats sucking thats the where the main fuel line goes the other one is the return to the fuel tank
Posted on Jun 22, 2009
Fuel want pull into bulb on my craftsman 27cc weedwacker #711200
There are 2 fuel lines going into the back of the primer bulb. One line goes from the back of the bulb into the fuel tank, and the other goes from the back of the bulb into the carburetor. I believe that the line that goes into the fuel tank has disconnected from the back of the bulb. You will need to remove the bulb, find the line that dropped off of the bulb and into the tank, and reconnect the line to the back of the bulb.
Jul 28, 2014 | Craftsman 27cc 2 Cycle Crank Straight...
I bought a Poulan PPB100 at a yard sale for $20.00. I got it home and got it started and running but it leaked gas like no tomorrow. I took it apart to see what was needed and found that all the fuel...
This is an ongoing issue for users, and rightfully so. Small diameter line out of fuel tank (has filter in-tank on end) connects to the side of the carburetor that has the fuel pump....that is the cover without the hole in it. Other larger diameter fuel line out of tank connects to the longer nipple on the external purge/primer bulb. The bulb "pulls" fresh fuel from the fuel tank to the carb and then out of the carb to itself, where it then pushes any air/old fuel back into the fuel tank. The remaining larger diameter fuel line in this setup goes from the metering chamber (has cover with writing on it and a vent-hole) side of the carburetor to the smaller nipple on the purge/primer bulb. Years ago on 2-stroke trimmers, primers were not even used,...you choked the carb with a slide lever and gravity let fuel enter the carb from above...a few pulls, a "pop"...slide it off of choke and away you went.
If the purge/primer bulb is on top of the carb...small line from carb body to small hole in tank with filter. Larger diameter line goes from the bulb on the fuel pump side of the carb to the larger hole in the fuel tank where the line is held in place with a nylon nipple connector that keeps the line from pulling out of the tank.
Please vote on this solution.
Aug 28, 2010 | Poulan/Weed Eater No. Te475 952711797 17"...
Craftsman weed trimmer primer bulb is working in reverse
Make sure the line is near the botto ofthe tank.Thanks you for asking and I hope it helps.Please leave me a 4 thumbs up.
Jul 19, 2010 | Craftsman 25cc Gas Line Trimmer
I have a xt 200 grass trimmer were do the gas lines go from the carb
line in tank has a small filter on it then line goes to carb.
another line goes from carb. to primer bulb.
another line goes from primer bulb to gas tank.
Jun 24, 2010 | Poulan Garden
I need to know how the fuel lines are hooked up in my ryobi gas trimmer. All of the fuel lines rotted out. I took them out and I need to know the correct connection sequences (what goes where).
line runs from little filter in tank to carb.
line from carb. to primer bulb
line from primre bulb back to gas tank.
lines are 2 sizes
need to cut at angle end of lines in tank so you can get them thru holes
and grab with needle nose plyers and pull them thru.
make sure you put the little filter on end before you pull line thru and leave
enough so filter can move around the whole tank.
second line in tank is smaller and need to cut and pull it thru hole in tank to primer bulb
Jun 23, 2010 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
I was given a 31cc craftsmen grass trimmer that starts but won't stay running.When I took it apart it has 2 lines coming from the gas tank.One goes to a primer bulb then the carb and the other line has...
The basics of the fuel line on these and many 2 cycle engines is this, one line from the tank goes to the primer bulb and the other from the tank is the return line from the carburetor. There should be another from the primer to the carb. The primer pushes fuel into the carb and any excess flows through the carb and back into the tank.
I hope this helps.
Jun 21, 2010 | Homelite Mighty Lite Lawn Trimmer
Need to know the fuel line routing including the primer bulb.
The smaller diameter line (fuel supply) goes from the fuel tank (w/filter) to the carb body. Look carefully at the 2 nipples on the carb. You can tell one is slightly larger than the other. Another larger line (purge line) goes from carb body to the right nipple on the primer bulb. Another large line (return line) goes from the left nipple of the primer bulb into the fuel tank. completing the purge circuit. This info pertains to the Craftsman 32cc with Zama carb and may work on the 25cc model as well.
Jun 01, 2010 | Craftsman 25cc Gas Line Trimmer
Replacing fuel lines on ryobi 767r trimmer
The longest, and sometimes smaller in diameter of the two fuel lines, goes from the carburetor to the bottom of the tank. Leave enough slack in this line so that the filter that attaches to the end will rest comfortably at the bottom of the tank.
The other fuel line goes from the primer bulb to just inside the tank, (about an inch). make sure that you get the right size fuel lines. The plastic coupling goes on the end of this line, inside the tank. This keeps the line from pulling out of the tank.
(HINT): When feeding the lines through the tank holes, cut the lines at an angle. They will feed much easier into the holes. You can than cut them off square, once you know that you have enough to work with.
If you need further assistance, just let me know.
Jim
Jul 03, 2009 | Ryobi Garden
Replaced new gas line, new primer bulb, new gasoline. need to find out if gas line routing is correct / trimmer will start, but very hard to start, clean air filter. carb never been adjusted since new.
Line from tank with the filter on it is the supply line and goes to the carb inlet fitting. This is typically on the "bottom" of the carb (with the tank being up) and will usually have a fitting with barbs or a bulge on it to ensure a tight fit. The other fitting on the carb is the return line and is usually a straight tube fitting with no barbs. That line goes the suction side of the primer bulb. The third line goes from the outlet of the primer bulb to the return barb fitting in the bottom of the tank. Fittings have to be removed from tank to properly install the new hoses on them. Remove retainer ring on outide of tank and push fittings into tank, then shake out of the fill opening. More details on replacing hoses are listed in another post about Repairing Ryobi trimmer.
Have you checked the spark plug?
May 12, 2009 | Garden
Ryobi 700r gas trimmer, replace old fuel lines
To leemineres, if hoses are on right and unit still stalls after starting initially you probably need to disassemble carb and clean out using spray carb cleaner. May be sticky needle valve, or partially plugged port or jet.Could also be hole in diaphragm. Gasket and diaphragm kit would be good to add when you take apart, even if diaphragm does not have a hole.
Jan 21, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Garden Logo
90 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
roeb
Are you a Poulan Garden Expert? Answer questions, earn points and help others
