Question about Jazz JDC25 Digital Camera
Driver unknwn device
I would like to know the codes for operating telefunken tdv 500ua dvd using a paktech rm 303e remote controller
paktech rm 303e remote controller should ba a so called "universal remote" Look up in it's manual the code for your DVD. If not there, follow directions for unknwn cde.
If still can't turn on your DVD, you should look for another remote or buy the proper remote of your DVD
Apr 28, 2015 | Televison & Video
Perihale blootooth driver
To resolve this issue, you will need to install the device driver for your Bluetooth device. If the device came with a CD or DVD containing device drivers compatible with your version of Windows, insert that disk into the disk drive and follow the instructions to install the driver.
If your Bluetooth device did not come with a driver installation disk, you will need to go to the device manufacturer's website and download and install the latest driver for your device. To do this, go to the hardware manufacturer and search on the latest version Bluetooth driver for your device. Follow the instructions.
Windows 7 Compatibility Center
Windows Mobile Devices
If youre using a Windows Mobile device, follow the steps below to updte to the latest version of Windows Mobile Device Center 6.1
  1. Go to the Microsoft Windows Mobile Device Center 6.1 site
  2. Click Continue.
  3. If prompted, download the Windows Genuine Advantage software.
  4. Click Download, then click Run.
  5. Follow the onscreen instructions to install Microsoft Windows Mobile Device Center 6.1.
  6. Click the Start button, type device manager in the Search box, then click Device Manager.
  7. Expand Unknown Device, right click on Bluetooth Peripheral Device, then click Update driver software.
  8. Click Browse my computer for driver software, then click Let me pick from a list of device drivers on my computer.
  9. Select Bluetooth radio from the list. Under Company name choose Microsoft Corporation, then under Drivers, choose the latest version of Windows Mobile-Based Device Support.
  10. Click Next. If any warnings should appear, click Ignore, then when prompted, click Finish.
  11. Restart your computer.
Nov 09, 2013 | Lenovo Computers & Internet
Did not install drivers for this device (Code 28)
Windows error code 28 indicates a missing or damaged driver file, which can keep devices connected to your computer from working correctly. This code appears in Windows XP, Windows Vista, Windows 7 and Windows Server editions. In most cases, you can stop this code from appearing by installing a new driver or by removing the old driver and replacing it with a different one.
Drivers
A driver is any piece of software that controls such devices as your graphics card, keyboard or printer. Windows operating systems come with many device drivers, and installs them automatically. Specialty devices, such as scanners, cameras or add-on cards, usually have their own proprietary drivers, which must be installed from a disk or downloaded file. b> Troubleshooting b> When any modern version of Windows can't find the driver to operate a device, it displays error code 28. You can find out more about the problem by opening Windows Control Panel, then choosing "System." Select the "Hardware" tab, then choose "Device Manager." From the Device Manager, select the problem device. In most cases, the device will have a small yellow exclamation mark next to its listing in the Device Manager. Right-click the device and choose "Properties" to see more information about the problem. Driver Installation b> You can install a missing driver on your own from the Properties dialog. Click the "Reinstall Driver" button and choose to install the software automatically. If automatic installation doesn't work, and you have a downloaded driver or one on disk, choose to install the driver from a specific location, then direct Windows to the correct file. If you don't currently have a driver for the device, visit the support section of the manufacturer's website. Most companies offer downloadable, updated drivers for all their devices. b> Considerations b> Sometimes Windows doesn't correctly recognize a device, even after you've installed a driver. This could happen because you used the wrong version of the driver or a driver meant for a different model of the device. Your existing driver may also be damaged and require reinstallation. In some cases, a fault in Windows may cause it not to recognize devices correctly. Microsoft offers an online diagnostic tool called Microsoft Fixit that can scan your operating system and tell you why code 28 is appearing.
Click start control panel administration tools computer management device manager scroll through all of your devices If you see a yellow question or exclamation mark ? ! or a red X you will need to update the drivers for this device right click select update driver/reinstall driver if you can see your usb device but its not working scroll to Ports(Com&Ltd) right click to update driver If you computer came with a motherboard disk the drivers could be on it. Rather doing a driver hunt which can take hours http://download.cnet.com/slimdrivers-free/3000-18513_4-75279940.html Windows XP/Vista/7/8
it might take some time being a freeware driver solution Note: it will find all of your outdated drivers
This will automatically search for and find the correct driver you will have to update every driver individually once you update you might be asked whether you want to restart or make a system restore point.
Click no to both of these then continue updating each driver free then restart once all of the drivers have been updated.
Hope this helps.
Mar 15, 2012 | Microsoft Computers & Internet
I am form the United states, just recently my face book changed to an unknwn, to me differnt lanuage,. I cannot get on my facebook because of this problem I am an American acnnot log in with my password to...
When you go to www.facebook.com is that page in a different language? If so, all you need to do is scroll to the bottom of the page and change the language back to "English (US)".
Feb 13, 2010 | Facebook Computers & Internet
DLL error
Please follow the instructions here.
If that doesn't work you can do one of the following:
1. Remove the ms07-017 update (
Microsoft Update Security Update K925902) at Add or Remove Programs in the Control Panel.
2. Remove
BricoPack Vista Inspirat (if you have it installed) at Add or Remove Programs in the Control Panel.
Jan 07, 2008 | Computers & Internet
Jazz JDC25 Digital Camera Logo
Top Jazz Cameras Experts
Pavel Pranovich
Pavel Pranovich
Are you a Jazz Camera Expert? Answer questions, earn points and help others
