Question about Technics SA-DX930 Receiver
SA-GX690 clicks - sound quits. Slap the side and it works again
My system also clicks (as it does when it comes on) and the sound quits.  There is no error message and I used to be able to slap the side a couple times and it would come back on.  Without slapping, it may click and come back on in 15 to 30 minutes.  Lately, slapping doesn't work and it stays off longer.  I took the cover off and the fuse is good but the fan is not spinning.  I don't know if I found the culprit, but I tapped on one of the OEG BLUE SQUARE MODULES and it came back on.  Any expert ideas?  Thanks.
  • keenem Jul 07, 2009
    I added this problem on June 22, 2009. It's now July 7, 2009 and I have not had a reply yet.
5 Suggested Answers
  • 583 Answers
SOURCE: Problem with subwoofer and one off the speakers.
just check if the wires are cut off somewhere or the internal connections loseened up.check this out.
Posted on Mar 13, 2009
davesoucy
  • 148 Answers
SOURCE: receiver sa-590: audio 'cuts out' and now stay
Sounds like the relay are worn. Its small plastic box. You can gently open the cap with precision screwdriver and use fine sand paper, or your gf nails sanding tools and pass it on the contact. If you could unsolder it, its much more easier to open...
Posted on Aug 05, 2009
  • 1527 Answers
SOURCE: Technics SA-AX7 OVERLOAD problem
hello there are 2 big capacitor behind the metal heatsink see if one has swelled up if so change them both then check the output chip to see if there are any dry joints then when you've check all and still the same then you may have to change the output transistor g ood luck
shaun
Posted on Oct 01, 2009
  • 47 Answers
SOURCE: my Tchnics Sa-Da10 shuts down on what appears to
Ahh technics. Technics always had overheating problems, trust me. Every since they started, their amps would get so hot they would hurt to touch. The reason the fan is not coming on seams to be something inside the circuit board. I'm sure that technics could fix this. If the fan works out of the receiver, then it must not be the fan. ;P
I would maybe get a computer fan, and just put it on top of the receiver and turn it on, or send it in for fixing. Also, do you have to crank the volume to get the speakers to play at your volume, and does the impeadence match the receiver. Because you may be pushing the receiver too hard.
Posted on Oct 11, 2009
How to reset Technics SA-GX690
See pages 5 & 22 of the manual at... http://www.manualslib.com/manual/119553/Technics-Sagx390.html#product-SAGX690
Jul 04, 2014 | Audio Players & Recorders
You can hear the heat trying to kick on but only blows cold air. If I slap the side of the unit - the heat comes on and heats the room to the temperature on the thermostat and shuts off. When the unit...
Sounds like you have a heat pump with either a stuck reversing valve or a loose wire going to the reversing valve solenoid. Open it up and take a look. Keep slapping it and you'll break something!
Dec 03, 2013 | Amana PTC153B50AM Split System Air...
Speaker hookup for sa gx690 technics
http://www.hifiengine.com/manuals/technics/sa-gx690.shtml
Register for free and download the manual. It's pretty straightforward and everything is marked.
Jul 14, 2011 | Technics SA-DX940
Truck makes clicking noise just after starting up!
The smoke if it's white and goes away is just condensation in the exhaust system evaporating and the clicking noise could be the famous GM Piston slap. You can take it to the GM Dealer, there is an upgrade ECM program to help eliminate the piston slap noise when the engine is cold. You can also try adding some Lucas engine treatment to your engine oil to help with the piston slap problem. Start with that and hope it's not overdue for an oil change or low oil level in the engine.
Thank you for using Fixya
Mar 15, 2010 | 2004 GMC Sierra
Whirlpool refrigerator side by side freezer won't freeze
your over-load/contactor is defective, un plug it from compressor and shake it if it rattles its bad
Oct 28, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Hi a have too same problems vhen i start reciever, reciever dont " click" and sound isn´t out.Than 15min to 2 hour later reciever "click" and all is o.k. I moved reciever to my friend. He is very good...
There is an internal "timer" circuit that controls the delay of the output relay. The capacitor in this circuit may be defective. Since it is part of an RC circuit, poor solder connections can effect this as well. Look closely at the board for any solder connections that appear grainy or have rings and resolder them. That may resolve the problem. If not, please update this with your findings and I will look up the service manual for this and list the probable defective components in the delay circuit.
Dan
Oct 15, 2009 | Technics SA-DX930 Receiver
Technics SA-DX930 Receiver Logo
235 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Ben Armstrong
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
