Question about Cell Phones
Ariston problems Washing model AQXXD149H panel does not illuminate when powered up. There is power to the machine,electrics appear ok and controll card checked for burn marks ok. any ideas ?.
IFIXALL
  • 868 Answers
SOURCE: No power to my WF 860P front loader washing machine
You have a bad control board,it is the first thing to replace.Whats probably causing it to fail is the off balance tub sensors.
Posted on May 24, 2008
SOURCE: ariston avxl105 washing machine power
reset button
Posted on Jun 29, 2008
futureloginn
  • 734 Answers
SOURCE: ariston washing machine
Door not shut Check that the door is properly shut.Faulty interlock A faulty interlock might not allow the door to shut properly. Find your door interlock here and replace, or contact a qualified repairer.
No power Check the flex, plug wiring, fuse and mains supply for faults.
Faulty on/off switch Check the power light if fitted. Replace your on/off switch.
Water supply disconnected or off If a washer dryer cannot load water it cannot start a wash cycle. Check water supply.
Posted on Dec 03, 2008
SOURCE: My hotpoint wf860 washing machine has no power!
hi guys
Posted on Jun 16, 2009
EsWorld
  • 1618 Answers
SOURCE: Saeco Incarto No Power problem
Check the capacitor which is under the pump and behind the power switch.
Posted on Jun 18, 2009
WHERE ARE THE FUSE FOR ARISTON ASL75CXS NA
There is no fuse in the machine. The fuse is in the electrical panel of your home. If there is power in the outlet then the fuse is not tripped. If there is no power reset the circuit breaker or (very old) replace the fuse. Here is the link to the manual for the machine.
http://www.aristonappliances.us/_pdf/manuals/ASL75_CXS_MANUAL.pdf
Jan 02, 2015 | Ariston Technologies Washing Machines
Would not power up
look for a reset button but I have a feeling its inside the machine. They want you to call service. I would call their help line on that one if its free or go to where you bought it and see what they say. If all else fails, try youtube, sorry. I have an LG and there is no common stuff with anything these days
Feb 20, 2014 | Ariston Technologies Ariston AWD12 Front...
Maytag washer mav7600aww doesnt get power
User Control and Display Board
If the washer won't start, the user control and display board may be defective. Check for power to the washer first.
Enter your model number to see parts for your washing machine.
Help me find my model number
Timer
If the washer won't start the timer might be defective. This part is often misdiagnosed, check other components before replacing this timer.
Line Fuse
If the washer won't start the line fuse might have blown.
Thermal Fuse
If the washer won't start the thermal fuse may have blown. It can be tested for continuity. Watch our fuse testing video for more information.
Line Fuse and Holder
If the washer won't start the line fuse might have blown, or the line fuse holder might be damaged and need to be replaced.
Main Control Board
If the washer won't start the main control board might be defective. This is not common. Check other parts and causes first.
Door or Lid Latch Assembly
If the washer won't start the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Door Lock Motor and Switch Assembly
If the washer won't start the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Incoming Power Problem
If the washer won't start check to see if there is power at the electrical outlet which the washer is plugged into. Plug a lamp or radio into the outlet to check it. If the outlet is dead, check the circuit breakers or fuses for the home.
Power Cord
If the washer won't start, check to be sure there is power to the electrical outlet for the home. If that is OK, the power cord itself might be defective. This is rare. You can check the power cord with an Ohm meter for continuity.
God bless you938a0a02-c262-417d-a982-3a081cef735f.jpg2b39c595-65d9-457a-8ed4-d3bb6d2facd8.giff6783cbc-852f-47b4-98d7-bd94a664080e.gif
May 23, 2013 | Washing Machines
It appears F13 error
hi sir we have ARISTON washer and DRYER model : AQXXMD129EX its a error coming F13 please help me soon
Dec 21, 2010 | Ariston Technologies AWD120 13 lb. Washer...
Ariston A1635 Margherita Control knob spinning
According to the instruction book - it appears the machine has been stopped mid cycle then re-started.
Switch machine off, turn control knob to a solid circle symbol (they are after every set cycle). Switch machine back on and lights will flash and program is reset. You can then select wash cycle as normal.
Jan 22, 2010 | Ariston Technologies AW125NA 13 lbs. Load...
Our Ariston AWD12 keeps cycling through programs. Engineer has replaced lots of parts but problem not fixed. 13 flashes showing as it clicks round.
Th e fault code indicates a problem with the dryer fan or the thermistor as being the cause of the problem. Check for broken wire.
These are located in the top of the washer, access is gained by removing the top cover.
Jan 15, 2010 | Ariston Technologies Ariston AWD12 Front...
Door Stuck after wash completed
You will have remove top cover, and release door latch from inside the front, with a screw driver pushing against the latch to open door.
It does mean that you probably have a faulty door lock, or broken door handle.
Please rate my fixya solution.
Thanks
Jan 11, 2009 | Ariston Technologies Ariston AWD12 Front...
Asking aquestion
Please explain in some detail.. the wiring that was done and the power system in your house ( meaning ..what type of receptacle do you have and and what voltage is the washer set up for 220VAC etc?) I may be able to assist if I have more information... Also.. what actually burned that caused the fire? ( the cord, something inside the washer... please elaborate on that)
Aug 28, 2008 | Ariston Technologies Ariston AWD12 Front...
Fault with Ariston Washer/Dryer
Make sure the filter is clean, its behind the front bottom panel which just pull off, then unscrew the filter thumb wheel until it comes out. Check it is clean and replace, Now unplug the machine and set the programme to your normal start setting leaving the door open. Remove the screws retaining the back panel and unplug all the connectors to the circuit board found in the bottom left hand corner. Turn the power back on ensuring the red LED illuminates and leave for 2 or 3 minutes before unplugging the power again and reconnecting the circuit boards and replacing the back panel. Reconnect the power and turn the machine on, close the door and with luck it will work. If this does not clear the fault repeat the process again or look on ebay for a new machine!
Oct 13, 2007 | Washing Machines
Cell Phones Logo
14 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
