Question about Whirlpool GGQ8831L Gas Dryer
Whirlpool gold ultimate care II dryer shuts off then won't start for a while.
  • lucior1230_0 Jun 23, 2009
    It is an electric dryer
    President:
  • 744 Answers
I am assuming this is a gas dryer and it gets hot to start then gas goes off? if so this is a problem with the saftey valve coils, this website will instruct you how to replace them.
http://www.acmehowto.com/howto/appliance/dryer/gdryer/check/gascoil.php
Posted on Jun 23, 2009
  • Mike Price
    Mike Price Jun 23, 2009
    Ok check the venting system tubes from the machine to outside, feel the airflow at the vent outside your house...if everything is clean and you have good airflow you have a problem with the high limit thermostat, you should replace it. Hope this helps
catriver
  • 878 Answers
SOURCE: Whirlpool Gold Ultimate Care II: No heat
didc, on a gas dryer, if the thermal fuse blows it will still rotate, but will not heat. Since this is a gas dryer, see if the ignitor is glowing. If it is, then you know the thermal fuse is good. If not, the thermal fuse may be blown or the ignitor itself and thus the reason for no heat. Catriver.7152136.jpg
Posted on Jan 01, 2008
Maytag317
  • 1136 Answers
SOURCE: Whirlpool Gold Ultimate Care II Electric Dryer
Hi, there sould be a two piece door catch. One piece on the door and another on the front panel that the door closes to. Look at the piece on the door. You will probably find it is bad. You can buy just that piece and change it. I hope this helps. If I can assist you further please let me know.
Thanks
Vic
Posted on May 14, 2009
  • 286 Answers
SOURCE: I have a whirlpool gold ultimate care II electric
first how is the clothes out of the washer? That might not be spinning fast enough in final spin. When was the last time the dryer vents was cleaned. Do you have a flow out the vent? If so then something might be going on with sensors.
Posted on May 19, 2009
  • 249 Answers
SOURCE: my Whirlpool Ultimate Care II dryer does not heat
There's no heat If your dryer doesn't heat, check these: Power from the house Heating element Thermal fuse Wiring Power from the house Check to see whether there's power getting to the dryer. Is it plugged in? Check for blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected. Heating element Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable. Thermal fuse On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.) Wiring A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to.
Posted on Jan 02, 2010
  • 1122 Answers
SOURCE: Have a Whirlpool Gold Ultimate Care II electric
there is a main fuse but check the door switch first,unplug remove the back the main fuse is to your left long and white check it with your meter-mike
Posted on Feb 22, 2010
How to fix a broken belt of motor of whirpool wash ultimate care 2
  • Replacing the Belt in a Whirlpool Ultimate Care II ' Home ... homeguides.sfgate.com > ... > Mortgage-Backed Securities Replacing the Belt in a Whirlpool Ultimate Care II by Rogue Parrish. Email; ... The Ultimate Care II washer, ... it may have a broken belt.
  • Whirlpool Washer: Ulitimate Care II - YouTube www.youtube.com/watch?v=bVmjmSzMXHE
    • BY CHERRY HILL
    • 3 MIN
    • 36K VIEWS
    2012-05-30 · Video embedded · Whirlpool Ultimate Care II: ... This is fully funcational washer. Direct Motor Drive works perfectly through each ... Whirlpool Washer: Ulitimate Care II
  • How to replace a broken dryer belt. Whirlpool Ultimate ... www.youtube.com/watch?v=PU8QZeDRl_0
    • BY BAILSOFSTEEL
    • 5 MIN
    • 3.5K VIEWS
    2015-04-04 · Video embedded · This video shows me replacing a belt in a Whirlpool Ultimate Care II ... a broken dryer belt. ... Whirlpool ultimate care II clothes washing
  • http://www.bing.com/videos/search?q=broken+belt+of+motor+of+whirpool+wash+ultimate+care+2&FORM=HDRSC3
    Jul 15, 2016 | Washing Machines
    My whirlpool ultimate care II electric dryer won't
    There can be many reasons why your dryer will not start or turn...
    The most common causes are the belt breaking or jumping off, or the motor goingbad...
    Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
    Dryer Repair - The Dryer is not Turning
    Dryer Repair - The dryer will not start
    heatman101
    Jul 21, 2011 | Whirlpool Dryers
    I have a Whirlpool Gold Ultimate Care II dryer. The dryer stopped working. It is getting electricity but still won't start. Any idea what the problem could be??
    The first thing you need to check is if you actually have 240 Volts going into the dryer. Sometimes one half of the (dual) circuit breaker opens and only sends 120 Volts down the line. If you hear a buzzing sound when you press "start" but nothing happens, it could be a stuck motor. Or the motor could be running but the belt is broke. There are more possible scenarios, but try this first.
    Jun 08, 2011 | Whirlpool Dryers
    Whirlpoole gold top loader stop working
    Try pushing down on lid switch. common problem for these models.
    May 16, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
    Thanks
    Vic
    May 13, 2009 | LG DLG2524 Gas Dryer
    Whirlpool washer has begun to make a loud buzzing sound when the
    This machine has an end-of-cycle buzzer built in. It may be that it just started working.
    Dec 31, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
    Whirlpool GGQ8831L Gas Dryer Logo
    296 people viewed this question
    Top Whirlpool Dryers Experts
    Dan Webster
    Dan Webster
    Tim Whalen
    Sal DeAngelo
    Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
