Question about Safe International Digital Electronic Safe Lockbox Gun Jewelry Lock Box Tool
Stramm digital safe, where do I insert the key?
Inserted incorrect drill bit into my stramm 800w rotary hammer now i cant get it out what can i do
Hold the drill bit with bench wise jaws at up wright way and keep a piece of wood log with chuck head & give it a hammer shot opposite way.Be sure to loosen chuck fully anti-clock wise.If your drill chuck pull releasing type you have to pull it and put a brake on it.
Jun 23, 2017 | Rotary Drills
Where can I get spares for stramm welder
I just did some serious searching to answer your question, and have come to the conclusion that you will need to start in South Africa for your answers.
South Africa was the only place I found any names of such a machine.
God bless your efforts.
Jan 09, 2017 | Welding Tools
Sentry S 3110. Combination lock with 3 numbers. How do I open it?
First insert the key into the lock, if there is a keyhole, and turn it until the plunger pops out. (You must have the key to unlock the safe for the keyed version of the safe.) Remove the key.
Set the dial to zero. Turn the dial to the right (clock-wise) three times (pass zero three times) then stop at the first digit in the combination. Turn the dial to the left twice and stop at the second digit given in the combination. Turn the dial to the right again and stop as soon as you reach the third digit. The safe should open.
Sentry has the manual available for the S3110 safe on the product page: http://www.sentrysafe.com/Products/36/S3110_FIRE-SAFE_Home_Safe . The direct link to the manual is http://www.sentrysafe.com/pdfs/OwnersManuals/514472.pdf . The directions for opening the safe are on page 2.
If you do not have the key and your safe has a keyhole, you probably need to contact Sentry or a locksmith.
I hope this helps.
Aug 30, 2015 | Home Security
Manual for stramm digital electronic safe manual
The Stramm safe we have is a small one that we use to store keys for our drivers. To change the combination, open the safe with the current combination. Sorry, can't help you if you don't know that. Inside the door is a plastic panel covering the batteries. Pinch the plastic catch at the top and open the panel. There is a small red button which you can press to change the combination. When you press it, you will hear a double beep. Enter your desired new combination. The trick is that the last digit must be either an "A" or a "B" which signals the end of your combination. For example, if you want your new combination to be 123456, you can't do that. The closest you can come is 123456A or 123456B. Hope this helps. Steve, Mbeya, Tanzania
Apr 06, 2013 | Safe International Digital Electronic Safe...
I have a 99 a6 quattro i have the code for the radio but when i press rbds and pscan buttons nothing happens it is in safe mode and wont let me do the steps to get out of it!
First of all be sure that your four digit security radio code is correct. If you had attempted three times without success to exit from safe mode by inserting the code, radio is blocked in safe mode for a while. Now turn ON the radio (in safe mode), and let it turned ON for one hour, then follow this procedure.
The sequence of VW radio gamma programming is:
1. Push simultaneous "SCAN" and "RDS" keys until on the screen will appear "1000" displayed.
2. Release keys. No more push on "SCAN" and "RDS" keys because otherwise number "1000" will be considered as first safe code attempt.
For example: we have the security code "5079". Then:
3. By the no.# 1 key you will set up the first safe code digit. Push 5 times on the no.# 1 button. The "5" number will be setted.
4. By the no.# 2 key you will set up the second safe code digit. Push 10 times on the no.# 2 button. The "0" number will be setted.
5. By the no.# 3 key you will set up the third safe code digit. Push 7 times on the no.# 3 button. The "7" number will be setted.
6. By the no.# 4 key you will set up the four-th safe code digit. Push 9 times on the no.# 4 button. The "9" number will be setted.
7. Then push again simultaneous "SCAN" and "RDS" keys for confirm this safe code. On the screen will be displayed "SAFE" notice. Release keys! For few seconds a radio frequence will be displayed.
The radio is now ready for use!
Jul 30, 2011 | 2000 Audi A6
How do i insert code for audi a6 2002 ? i have the code but i don-t now which button to press simultaneously.
IMPORTANT NOTE: You must have the security anti-theft code for your Audi radio from the car manufacturer, or from an Audi dealer!
The sequence of programming for Audi radio is:
3. By the #1 key you will set up the first safe code digit.
4. By the #2 key you will set up the second safe code digit.
5. By the #3 key you will set up the third safe code digit.
6. By the #4 key you will set up the four-th safe code digit.
7. Then push again simultaneous "SCAN" and "RDS" keys for confirm this safe code. On the screen will be displayed "SAFE" notice. Release keys! For few seconds a radio frequence will be displayed. The radio is now ready for use!
Nov 11, 2010 | 2002 Audi A6
My sentry safe will not open after entering the code it reads "err"
You have to press the program / enter button after you enter the code How to open electronic sentry safes.
Locksmith opening instructions manual for sentry fireproof electronic security safes. Insert the tubular sentry key into the lock to the left of the key pad. Turn the key all the way to the right until the plunger pops out. Press the five-digit factory code. The green Proceed light will come on. Pull the handle down; to crack the sentry door open
Aug 10, 2008 | Sentry Fireproof Safe
How to open my safe with the code
Apr 18, 2008 | Sentry Fireproof Safe
Forgot how to open my fireproof lockbox
Locksmith opening instructions manual for sentry fireproof electronic security safes. Insert the tubular sentry key into the lock to the left of the key pad. Turn the key all the way to the right until the plunger pops out. Press the five-digit factory code. The green Proceed light will come on. Pull the handle down; to crack the sentry door open.
Nov 03, 2007 | Sentry Fireproof Safe
Safe International Digital Electronic Safe Lockbox Gun Jewelry Lock Box Tool Logo
Top Safe International Locks & Locksmithing Experts
Jim London
Jim London
john h
Are you a Safe International Lock and Locksmithing Expert? Answer questions, earn points and help others
