Question about Epson LQ-2090 Matrix Printer
HOW TO configue LQ2090 TO PRINT CHEQUE - Epson LQ-2090 Matrix Printer
Can't print payroll checks for intuit, get support code 2101 message
Is the paycheck form the same size as the plain paper? If not adjust the paper guides (and size selector if there is one) to the edges of the cheque form.
Aug 14, 2014 | Office Equipment & Supplies
Fault: misaligned cheque prints after 20 pages
If it gets off by a full line you have a problem in you print job. If not I've seen the tractors and spline shaft cause this issue.
Oct 31, 2013 | Printronix P7220 Matrix Printer
Hello i had dvd burner ordered from city soft ware since 15/04/. 2011 they cannot deliver so they reimbursing my bank account.what is a epay cheque?.i was not connected with paypal when i ordered the...
Cheque: A cheque (or check in American English) is a document/instrument (usually a piece of paper) that orders a payment of money. The person writing the cheque, the drawer, usually has a current account (British), or checking account (US) where their money was previously deposited. The drawer writes the various details including the money amount, date, and a payee on the cheque, and signs it, ordering their bank, known as the drawee, to pay that person or company the amount of money stated.
Similar to a electronic pay check.
Apr 27, 2011 | ASUS SDRW08D1SU DVDRAM Burner
I'm trying to print the item description on my simply accounting cheque. It prints on the stub but not the actual cheque.
Check this out http://printerinkquestions.printcountry.com/category/Printer%20Settings-12.htm. There will be advance setting that you can set as you print.
"Please Post back to let us know if we helped "
Kindly rate this article.
Hope this helps :)
Mar 15, 2011 | Computers & Internet
Is there any spacific printer for cheque printing
no - you can print with any printer.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Sep 06, 2010 | Tally T2250 Matrix Printer
How do I read the meter on Ricoh AP3200 printer
The meter is on the configuation page.
Menu > List/Print > configuation page
once printed out it is in the upper right of the page (usually)
Mar 23, 2010 | Ricoh Aficio AP3200 Laser Printer
Paper is out of range Samsung printer when printing in word it always says paper out of range
Check your default margins on the printer. Open Word, open a document, click on File then Print. When the printer's printing window opens, click on properties. You should now be able to see the Margins or a Margins tab in the window. Check you margin settings. If they are below .5" in any of the 4 margin settings then you printer probably cannot print the document. Change the settings and save them as the default settings.
You may also try updating your printer driver, too, depending on how old your printer is.
You should also check the settings for the paper type you are using. If it is not the normal 8.5" X 11", then you will need to change this setting as well.
Hope this answers your problem.
Sep 04, 2009 | Office Equipment & Supplies
My printer giving blank paper in epson lq2090 dot matrix printer
Either your ink ribbon is worn out or it is broken, or it is put in wrong, or your print head isn't working. Pull the print head the whole way toward the paper (With the adjustment lever) and run a test sheet. Look at it closely. If you see imprints, it's the ribbon. Id you don't, it's the print head.
Sep 03, 2009 | Epson Office Equipment & Supplies
Sugest my problem
Will printing 4 lables and then will skip 4 lines and then print again
Mar 23, 2008 | OKI MICROLINE 320 Turbo Matrix Printer
Epson LQ-2090 Matrix Printer Logo
Top Epson Office Equipment & Supplies Experts
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
