Question about iRobot Roomba 4210 Bagless Robotic Vacuum
Why does irobot dock without cleaning room? - iRobot Roomba 4210 Bagless Robotic Vacuum
    Novelist:
    Scholar:
  • 109 Answers
How long does it run before docking? One to two hours is normal. 2 minutes means your battery is dying and it's coming back for more power.
Posted on Aug 14, 2014
Amber flashing light while on home base. New, pulled tab, placed on dock. First time said charge err1, took out battery and replaced. Now just flashes amber. Is this correct?
Your manuals are here. Flashing lights must be covered. A quick look at the site says flashing red is bin full. In fact, I found it. Flashing Amber is CHARGING.
Roomba 600/500 Battery and Charging Overview On some robots, the CLEAN light should pulse red/amber while charging. ... Amber - partially discharged; Red - nearly discharged; Flashing Red - discharged . homesupport.irobot.com homesupport.irobot.com/.../roomba-600%2F500-battery-and-charging- overview LabeledSupport ... clipped from Google - 12/2015 iRobot: Customer Care - Roomba 700 Anatomy homesupport.irobot.com homesupport.irobot.com/app/answers/.../a.../roomba-700-anatomy images?q=tbn:and9gcss8oogw3vmcv_uom0z_pxoi9q5tq9n4aqrcwbsxn0zd1blfvnacictdbyn iRobot: Customer Care - Roomba 700 Anatomy Solid Red = Battery Discharged; Amber Pulse = Charging; Solid Green = Fully Charged; Quick ... The battery indicator blinks when there is a charging issue. homesupport.irobot.com homesupport.irobot.com/app/answers/.../a.../roomba-700-anatomy LabeledSupport ... clipped from Google - 12/2015 iRobot Roomba 500 Series Battery Maintenance homesupport.irobot.com homesupport.irobot.com/ci/documents/.../042809_500MaintBatt_vib iRobot Roomba 500 Series Battery Maintenance Roombas "CLEAN" light should pulse red/amber while charging. ... Green - fully charged; Amber - partially discharged; Red - nearly discharged; Flashing Red - ... homesupport.irobot.com homesupport.irobot.com/ci/documents/.../042809_500MaintBatt_vib LabeledSupport ... clipped from Google - 12/2015 Roomba 400 Series/Discovery Battery and Charging Overview homesupport.irobot.com homesupport.irobot.com/.../roomba-400-series%2Fdiscovery-battery-and- charging-overview Roomba 400 Series/Discovery Battery and Charging Overview Your Roomba's POWER light should pulse red/amber while charging. ... Amber - partially discharged; Red - nearly discharged; Flashing Red - discharged. homesupport.irobot.com homesupport.irobot.com/.../roomba-400-series%2Fdiscovery-battery-and- charging-overview LabeledSupport ...
iRobot Owner Manuals and Quick Start Guides
Dec 31, 2015 | Roomba Vacuums
Why is there no green light or red docking showing it is charging?
Sometimes the contacts between the battery and the iRobot get corroded...you can try using a small piece of sandpaper to lightly scuff/clean the battery contacts. Once you put it back together, try the reset function mentioned previously.
May 26, 2015 | iRobot Roomba 530 Robotic Vacuum
Why does roomba keep docking?
It needs to recharge every time it docks.
I would suggest that you let Roomba run out of the room where it's charger is. Then force it to run until it dies out. Then put it back onto it's charger.. I suspect that it's developed a memory (short) for charging and you need to force it to totally drain down, then charge for a good while. This should force it to develop a "Longer" memory. Works for me anyway.
May 09, 2014 | iRobot Roomba 4210 Bagless Robotic Vacuum
My roomba 530 cleans just great, but it will not return to the docking station--it just stops in the middle of the floor without any warning. I push the dock button, etc. to no avail.
I sometimes have the same problem with my Roomba 530 (named Ethel). Make sure the signal transmittor on the docking station and the signal receiver on the top of the Roomba are clean. You can use a cloth or paper towel with a SMALL amount of window cleaner to run around both of these signal devices. I also like to clean the metal contacts on the station and the corresponding contacts on the bottom of the Roomba at the same time. This won't make a difference for the docking but it just assures that the vacuum will charge efficiently. If this doesn't work, you might need to have the unit cleaned professionally unless you feel comfortable about taking the unit apart and cleaning it yourself. I did this and Ethel has worked fine ever since!
If this helps, please come back and rate my suggestion!
Jun 06, 2011 | iRobot Roomba 530 Robotic Vacuum
Scooba now stops sooner and isn't finished cleaning :-(
I had this problem and contacted irobot. An important fact was left out of the early edition user manual to not leave the battery charging for an extended amount of time. Because of this ommision, they sent me a new battery and a software upgrade for the scooba. I just followed the directions and attached the little device they sent to do the upgrade the scooba and it fixed the battery problem.
Hope this helps.
Jul 17, 2009 | iRobot 5800 Scooba Vacuum
My Roomba does not want to dock
Need more info.
Does the unit go into search mode? "SPOT & CLEAN" flashing? It actually tries to search?
Do you have another roomba to test your dock on to see if IT will dock? If it tries but just cant, then either the dock transmitter, or the roombas receiver is dead. (The round antennae thingys on the dock and the bumper) replace these would be the first point.
Jan 21, 2009 | iRobot Roomba 4210 Bagless Robotic Vacuum
IRobot Roomba (RED) does not start,
Reset your robot by holding down “Spot” and “Dock” together for 10 seconds. this might help
Jan 10, 2009 | iRobot Roomba 560 Robotic Vacuum
iRobot Roomba 4210 Bagless Robotic Vacuum Logo
Top iRobot Vacuums Experts
Are you an iRobot Vacuum Expert? Answer questions, earn points and help others
