Question about Canon imageCLASS MF5750 All-In-One Laser Printer
Canon mf5750 countter tool download - Canon imageCLASS MF5750 All-In-One Laser Printer
3 Suggested Answers
Crankstart
  • 696 Answers
SOURCE: i need a driver for canon laserbase MF5750 for Mac
Sorry to inform you but this printer was only designed for Windows, although there are drivers for all current versions of windows Canon does not support this printer on Macintosh.
Looks like you may have to try a different printer,
Chris
Posted on May 20, 2009
  • 92 Answers
SOURCE: canon image class mf5750 legal size paper
Hi ...
If you wish to print using a paper size which is different from the normal one A4, you need to specify the same to the printer else it will not recognize or will not accept the paper ...
Below are the steps that you can follow to:
1) Specify paper size
2) Specify paper type ..
Specifying the Paper Size At the factory, the paper size has already been set to [LTR]. Normally, you can make copies in this setting. When making copies on other sizes of paper, you need to specify the paper size according to the following.
  1. Press <Menu>.
  2. Press <la.gif> or <ra.gif> to select [COMMON SETTINGS], then press <Set>.
  3. Press <la.gif> or <ra.gif> to select [PAPER SETTINGS], then press <Set>.
  4. Press <la.gif> or <ra.gif> to select [PAPER SIZE], then press <Set>.
  5. Press <la.gif> or <ra.gif> to select the appropriate paper size (LTR, LGL, EXECUTIV, A4, B5, ENVELOPE, or FREE SIZE), then press <Set>.
    black_dot.gif When [ENVELOPE] is selected: white_square.gif Press <la.gif> or <ra.gif> to select the type of envelopes (COM10, MONARCH, DL, or ISO-C5), then press <Set>.
    black_dot.gif When [FREE SIZE] is selected: white_square.gif Press <la.gif> or <ra.gif> to select [VERTICAL SIZE] or [HORIZONTAL SIZE], then press <Set>. white_square.gif Use the numeric keys, or press <la.gif> or <ra.gif> to specify vertical and horizontal sizes of the paper in millimeters (mm).
    Available range in [VERTICAL SIZE]: 127 mm to 356 mm (5" to 14")
    Available range in [HORIZONTAL SIZE]: 76 mm to 216 mm (3" to 8 1/2") white_square.gif Press <Set>. Repeat the steps above to specify both vertical and horizontal sizes of the paper.
  6. Press <Stop/Reset> to return to the standby display.
Specifying the Paper Type [PLAIN PAPER] is selected as the default paper type. When making copies on paper other than plain paper, you can specify the paper type according to the following. Specifying the paper type can prevent poor copy quality, or the printout not being printed correctly.
  1. Press <Menu>.
  4. Press <la.gif> or <ra.gif> to select [PAPER TYPE], then press <Set>.
  5. Press <la.gif> or <ra.gif> to select the appropriate paper type, then press <Set>.
    You can select from the following paper types: - Plain paper (17 lb to 24 lb (64 g/m2 to 90 g/m2 )): [PLAIN PAPER] - Heavy paper (25 lb to 34 lb (91 g/m2 to 128 g/m2 )): [HEAVY PAPER], [HEAVY PAPER H]*1 - Transparency: [TRANSPARENCY] - Label*2 : [HEAVY PAPER], [HEAVY PAPER H]*1 - Envelope: [HEAVY PAPER], [HEAVY PAPER H]*1*1 If print fixing is not sufficient when printed with [HEAVY PAPER] selected, select [HEAVY PAPER H].
    *2 A label that can be loaded in the cassette is a standard type (label standard card) only.
Please vote if this helps ... Cheers :)
Posted on Jul 27, 2009
How can we download 5750 canon printer software
Hi.
Below the link to the download page for this printer. Scroll down Canon page and find Driver download link and the rest of the software for this model:
MF5750 - Canon Download Centre
Regards.
Ginko
Aug 20, 2011 | Canon imageCLASS MF5750 All-In-One Laser...
I have Cannon MF5750 and need its driver download. How to get it and from where?
Hi!
You can get driver for Cannon MF5750 at the link below, please select your Operating System(Windows XP, Vista 07) before downlaoding.
http://www.usa.canon.com/cusa/support/consumer/printers_multifunction/imageclass_series/imageclass_mf5750#BoxContent
Also, I believe it came with a cd, if you still have it you can also get the driver from it. Hope this helps.
Apr 28, 2011 | Computers & Internet
Where is canon mf5750 driver
Hi there Mehta,
Here is where you can download the driver:
http://www.usa.canon.com/cusa/support/consumer/printers_multifunction/imageclass_series/imageclass_mf5750#DriversAndSoftware
you just have to choose for your correct windows operating system for driver compatibility.
Hope this helps. Please let me know if you are able to download it. Thank you for using FixYa.
Oct 15, 2010 | Canon imageCLASS MF5750 All-In-One Laser...
Can i use this printer with win vista??
hello. Yes you can but you will have to download a driver for it. just google canon image class mf5750 vista driver then download it and run it.
Jan 30, 2010 | Canon imageCLASS MF5750 All-In-One Laser...
I need a driver for canon laserbase MF5750 for Mac
Chris
May 20, 2009 | Canon LaserBase MF5750 All-In-One Printer
I need to download and driver for my canon mf5750
You can go directly to the Canon site and download the latest dirvers for that printer.
I would suggest making a backup copy of them in case you need them in the future.
Here's the site
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=335&modelid=11148
It also has manuals, and firmware updates
Nov 14, 2008 | Canon imageCLASS MF5750 All-In-One Laser...
Canon Laserbase MF5750 Multifunction
@all: Firmware Update
Download the Canon MF Update Tool from the Canon Homepage.
Connect your Canon Laserbase MF5700 series to your PC and flash the Firmware.
Worked at my Canon Laserbase MF5750.
Had the same problem like you.
Nov 03, 2007 | Canon LaserBase MF5750 All-In-One Printer
Canon imageCLASS MF5750 All-In-One Laser Printer Logo
27 people viewed this question
old marine
old marine
