Question about Konica Minolta Office Equipment & Supplies
Why report is truncated - Konica Minolta Office Equipment & Supplies
  • Konica Minolta Master
  • 6,161 Answers
What model machine?????
Posted on Dec 29, 2015
Why does Xerox 7335 truncates output from Oracle PDF?
It may not be the printer and I did some research on Oracle and this seems to be a common issue.
I pulled this information off an Oracle knowledgebase it may not resolve your issue and there is more info on the following site if you want to investigate further:
http://docs.oracle.com/cd/E23943_01/bi.1111/b32121/pbr_uxprt009.htm#RSPUB75727
NOTE:
If you're printing to the Xerox MFD with a PS (postscript printer driver) you could try installing and printing using the Xerox PCL driver for your computers operating system. If you printing reports from a mainframe this may be an issue at the mainframe level in which case I would engage your companies IT department for assistance.
Any one of a number of possible causes may account for the truncation of fields.
  • Check the field and determine if it is allowed to expand.
    1. In Oracle Reports Builder, double-click the field in the Paper Design or Paper Layout view to display the Property Inspector.
    2. Find the Horizontal Elasticity property.
    3. If it is set to Fixed, you should change it to Variable or Expand.
    4. Run the report to the printer.
    5. If it still truncates, it could be that the field requires multiple lines.
    6. Return to the Property Inspector for the field and check its Vertical Elasticity.
    7. If it is set to Fixed, you should change it to Variable or Expand.
    8. Run the report to the printer again.
  • If the right most fields on the page are always the ones truncating, it could be an issue with the printable area of the printer. If you are using a PCL printer, then you will have to estimate the size of the printable area and resize your margins accordingly:
    1. Open the report in Oracle Reports Builder.
    2. Go to the Paper Layout view.
    3. Click the Margin tool on the top tool bar. A thick black line appears indicating where the body of your report ends and the margin begins.
    4. Click and drag the black line to the left approximately 0.5 inches.
    5. Save and run the report to the printer again.
    6. If necessary, repeat steps 4 and 5 to determine approximately where the printable area boundary is located and then ensure that your report body fits within that area.
  • If you are using a PostScript printer, you can get the printable area boundary to appear in the Paper Layout view as follows:
    2. Choose File > Page Setup.
    3. Verify that the margins are small and that the orientation is correct.
    4. Click OK. The Paper Layout view should now be able to read the boundary.
    5. Go to the Paper Layout view.
    6. Click the Margin tool on the top tool bar. A thick black line appears indicating where the body of your report ends and the margin begins. A black hashed line also appears indicating the boundary of the printable area.
    7. Ensure that the thick black line is inside of the black hashed line. If it is not, click and drag the black line inside the printable area.
    8. Click the Margin tool to leave margin mode.
    9. If necessary, reposition your fields to fit within the new body boundaries.
    10. Save and run the report to the printer.
  • For PCL, if it is still truncating, try using a fixed space font instead of a proportional font. Sometimes PCL printers have problems interpreting proportional space fonts and it leads to truncation. You should try using a fixed space font, such as Courier, and possibly font aliasing.
    Note:
    Default layouts are built against a generic printer. Each printer has its own printable area. As a result, you may have to reset the report to fit the printer. Ideally, if you know the various printers you will be using, you can design the report from the start to fit the printer with the smallest printable area.
Mar 10, 2015 | Xerox Office Equipment & Supplies
Need to change the heater element
1) Unknown which product. Fixya truncates questions the expert receives.
2) Copy following link for replacing element on tank-type water heater.
http://waterheatertimer.org/How-to-replace-water-heater-element.html
3) Feb 2013. Add comment and describe exact product type, model, and brand name for possible location of product manual or resources.
4) Repost question and include brand name, model and type.
Attach a photo for better identification of problem, but fixya degrades image seriously and fine detail cannot be viewed by expert.
5) Repost question and include video that fixya may also truncate and downsize-degrade so it might be useless.
6) Post video on utube and send link.
Feb 04, 2013 | Water Heaters
Using MS Access, I am printing labels to a Zebra 110XiIII printer. The output truncates the label to 2" instead of the 3.5" I have the report page settings saved as. I have been through the setup...
First check printer. Change setting "Print Width" to maximum width, save. Switch off. Hold down pause key while switching on (untill all but power light turns off). the subsequent prints should print across the full width. If this is OK fault is with label format.
If you are using windows printer driver check settings there this can over ride printer settings. If using ZPL the problem is most likely in the label format.
Jul 05, 2011 | Zebra 110XIIII Thermal Label Printer
Bought in Nov 2007 online from circuit City. Has
Change printheads,Issue will not get fixed then its a hardware failure.
Jul 11, 2010 | HP Officejet Pro L7780 All-In-One InkJet...
Files are getting truncated on my WD my book hard drive
scandisk, check for errors.
format, and scandisk again.
if it have bad blocks, then it's replace time.
if it does high pitch sound or clicking sounds, the drive is faulty, then it's replace time.
May 31, 2010 | Western Digital My Book Home Edition 500...
Cannot open file. Access Denied.
Well unfortunately, it looks as though the area of "Damaged Files" was in the place that your pictures were stored, unfortunately, the software has detected a problem, in that exact area, and have "Locked Out" that area from EVER being used, once marked as "Bad" I am sorry, that's it. Now you may try to open some of the files, in the recovered files directory, but usually, that too is no good. Also sounds like your drive is not healthy either, i advise you back up as soon as possible, and keep any eye on that drive.
Feb 25, 2010 | Kingston Technologies 512MB DataTraveler I...
MY OMNI 3200 PRINTS THE FULL CREDIT CARD # AND EXPIRATION DATE
Call your merchant services provider IMMEDIATELY, you MUST truncate the customer copy by law. see FTC rules on truncation.
Feb 19, 2009 | VeriFone OMNI 3200 (P092-101-10) Printer
My display is truncated on the right side
right click on desktop, goto display settings.
You will have 2x monitors displayed.
Click on monitor 2, and look below for the tick box and click extend desktop.
This should sort it.
Had the same thing on a Tosh' TE2100
Feb 08, 2009 | Toshiba Satellite 1415-S173 Notebook
Truncating links
I noticed it only matters when posting a solution. Firefox for example posts the link as text only.
Yeap, well if the users asks why the link isn't working in that case I would provide a embeded link.
So far haven't got any complaints or then I just don't remember.
Jun 01, 2008 | Vivitar ViviCam 35 Digital Camera
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
David Burkhart
David Burkhart
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
