Question about Caterpillar American Construction Equipment 1:87 Scale
High pressure oil line blew off on 3126 cat
Now I need to remove the aluminum block it was attached to not exactly sure what the block is named / need to drill &tap / or heli coil/or do I need to replace the block $$$ Also to remove the block what else do I need to remove and mark to do so
3 Suggested Answers
SOURCE: I'm working on a 3126 cat engine. Problem oil in
Sounds like high pressure oil used to actuate the injectors is bypassing one or more injectors internally. There was an issue with this on engines with 7AS / 8YL serial number prefixes. There is no real way of isolating the problem, so the fix would be to replace all six injectors.
Posted on Jul 18, 2009
  • 19 Answers
SOURCE: have cat 3126 with new turbo and will not build
check the air to air u will have to pressure the system i will say it is there
Posted on Aug 24, 2010
1998 cat 3126 when warm surges at idle. not under load and not when cold?
surging at idle indicates air in the pump affecting the governor operation
or
low fuel pressure in the pump having the same affect
Call a cat service agent and discuss the propblem
Dec 23, 2017 | Cars & Trucks
Change oil pump
What you really want to do is have a technician remove the oil sending unit and attach a pressure gauge of known reliability. Only then can you know if your pressure is good or bad.
If you have to change an oil pump, you can have problems reaching it. You may be able to find a Video or text online for your exact model. The Capri series covers a lot of Years and the engines may be different and one year may be a front wheel drive while an older one may be rear wheel drive.
One of the biggest problem is having clearance to remove the oil pan. Sometimes in the closest clearances turning the crankshaft can help make room to drop the oil pan.
Front wheel drive units can have a cradle which blocks pan removal. You need to find out the requirements for your exact year.
The pressure test will help diagnose other problems. Bad bearings can leak so much oil that pressure will behave exactly like you describe.
Feb 06, 2014 | Mercury Capri Cars & Trucks
Cat 3126, Oil press. drops off from 50 psi. to 17 psi as it warms up
According to their website the minimum oil pressure is 41 psi at idle. I'd suggest verifying the oil pressure with a manual gauge directly plumbed to the engine. If it is 17 psi when the engine is up to temp. then you may have issues with the bearings. You should take an oil sample and find out what the metal levels are in your oil to determine if the bearings are going
Nov 27, 2012 | Cars & Trucks
1994 olds cutlass ciera air conditioning low pressure sensor
The low pressure cycle switch is located under the air filter housing. It is attached to the accumulator drier. the drier is a canister with two aluminum lines and this sensor attached to it .
Aug 06, 2012 | Cars & Trucks
Cat 3126 using oil
If turbo charged it could be the center section oil seals.
Oct 27, 2009 | 1999 Ford Super Duty F 450
Had coolant Bypass line break on the road just got it home had 0 oil Pressure fixed the hoses the next day started it noticed the coolant being pushed out of radiator im guessing a Blown head gasket...
sorry for the delay. if it is like that than your head gasket is bad. that is the only two common points other than the head and cylinder wall! if you do the head gasket make sure to take it to the machine shop to be pressure checked and resurfaced just because it's aluminum.
good luck and if you need any more help please ask
Sep 25, 2009 | 1989 Ford Probe
I'm working on a 3126 cat engine. Problem oil in the fuel tank. Would would cause this? I already reseal all 6 six injectors. Need help... Thanks
Mar 25, 2009 | Caterpillar American Construction...
Oil filter adapter lines from block adapter to remote oil filter
The lines can be disconnected from both ends and the bracket removed but to remove the lines from the front (they cannot be removed to the rear) loosen and remove the drivers side engine mount bolt. Use a block of wood between a floor jack and the cast aluminum oil pan and jack the engine assy. up slightly (just enough to "snake" the oil filter adapter lines by the drivers side engine mount. Leave engine jacked up slightly while you "snake" the new lines into position and install the end at the engine oil filter adapter. You can then lower the engine reinstall engine mount bolt and finish the install of the lines by installing the oil filter end of the adapter lines and attach the bracket (that comes with the GM lines) to the block.
Nov 15, 2008 | 1997 GMC Sonoma
I have a 2000 Pontiac Firebird with 90,000 miles on it. I put in Gunk engine cleaner and ran it for 5 minutes as directed then drained the oil. I then did an oil change (Quaker State 10-30) and put in...
The sensor can show high pressure when that is not the case, they fail high not low, take the sender out and plug in a mechanical guage to verify this, that is the only way to be 100% sure.
Sep 29, 2008 | Pontiac Firebird Cars & Trucks
Caterpillar American Construction Equipment 1:87 Scale Logo
530 people viewed this question
Top Caterpillar Toys Experts
fordexpert
DROPNDEAL
DROPNDEAL
Are you a Caterpillar Toy Expert? Answer questions, earn points and help others
