Question about Carrier Bryant Condenser Fan Motor HC39GE226
Installation of carrier condenser fan
Fan getting very noisy. How difficult is it for me to swap out old with new fan motor? This is a Carrier A/C with OEM part HC39GE226.
pagebor
  • 2785 Answers
SOURCE: Carrier 38YRA 042 Fan Motor Problem?
plz check if there is anything obstructing the fan movement.if not then the motor is the culprit.
It will be better if you leave it for professional
Posted on Jun 07, 2008
  • 116 Answers
SOURCE: My ac fan went out on a carrier ac unit. Need wiring help
use a seperate capicitor for the fan only pick up 1 leg of power from common side of the compressor cap and the other from the contactor or the board in a heat pump situation
Posted on May 11, 2009
  • 5 Answers
SOURCE: Carrier A/C unit blowing hot air and fan not spinning
check the belt drive and refrigerant
Posted on Jul 12, 2009
  • 13 Answers
SOURCE: Carrier Furnance Fan / Blower Doesn't Start (Model 58GP-125-GA)
With power off, locate fan motor capacitor (generally silver in colour).
Rating on capacitor will be in microfarads at specified voltage ( 5mf @
370 volts). Be careful to discharge before handling and return defective
cap. to source of replacement. They can confirm whether or not truely
defective. Replace and secure. Restore power and check operation.
Purpose of run capacitor is to provide starting torque that you are
presently providing by hand spinning. Hope this helps.
Posted on Aug 05, 2009
  • 7 Answers
SOURCE: the condenser fan for carrier xarios 300 is not
there is a run capacitor is probably bad.
you can purchase a replacement one from slakey brothers. However the capacitor will still have a charge after the power and wires are removed. after turning off the breaker use a long bladed screw driver and ground the electrical leads to discharge the capacitor before removing. take it with you to the supply house along with the model and serial number of the condensing unit.
Posted on Apr 15, 2010
My son has a noisy condenser fan on the carrier condensing unit, model is a BRC060360 and Im puzzled on this unit seer rating, any ideas? Also looking for a budget condenser fan for it?
Condenser fans are usually not very expensive, so I suggest you go to a carrier dealer and buy one as a spare part. Have you check that the fan is clean and none of the blades are damaged.
May 19, 2016 | Carrier Heating & Cooling
NOISY SQUIRELL CAGE ON A CARRIER AC/HEAT PUMP OUTDOOR UNIT
Not unless its a belt driven wheel. If not no grease will help just make a big mess. Take the fan assembly out, take motor off the wheel, take wheel out of the assembly wash wheel with hose, dry reassemble. Or just go buy a new wheel but check your shaft on the motor if loose get a new motor also.
Mar 15, 2013 | Carrier Heating & Cooling
Condenser fan replaced one year ago, fan not turning but can hear motor
the answer to your problem is most likely the motor start capacitor. A AC motor can run in both directions. The start capacitor is used to cause the current to lag behined the voltage which determines the direction the motor will turn. Its posible the start and run capacitors are in one can. so changing one will change the other. However look for a wiring diagram. Do not asume that both capacitors are wired in properly. They may be fighting one another causeing premature failure.
Sep 18, 2012 | Carrier 38CKC036 Air Conditioner
Need the motor size on a carrier 38SQ940311
Carriers usually have a 1/4 HP condenser fan motor.
Jul 19, 2012 | Carrier Heating & Cooling
Just had AC tech charge $257 to replace capacitor on carrier 38ckco48300. tech also stated condenser fan motor may have been damaged with replacement cost of $500. can a condenser fan motor for this unit...
I don't know what part of the country you are in, but here in Okla. a condenser motor can be bought by the home owner for around $100. You should be able to go to any appliance supply house and purchase your own motor. Take the model and serial number with you, it may help. If you have a local carrier distributor, they should give you a users manual. Try your best to get a motor close the the same as what you have. Note the horsepower, rpm, voltage and take the fan blade with you in case you need a new one. Hope this helps. Mark
Sep 07, 2011 | Heating & Cooling
We require condenser fan motors for Interclisa Carrier package (rooftop) air conditioner model AAD 250 (1980's model) model. Air conditioner - supply voltage 380 Volts 50 Hz AC. Condenser fan motor voltage...
Hi, this is an odd voltage 380 volts. Is it a 3 phase unit? To get a 220 volt 50hz condenser fan motor, you will have to go through a refrigeration/air conditioning parts house and order this. 60hz you would have no problem finding one in stock. Carrier is a good unit, and have been around for many years. You shouldn't have any problems locating one.
Sincerely,
Shastalaker7
PS You will need to go through a wholesale parts house.
Jan 21, 2010 | Carrier Heating & Cooling
My Carrier Weathermaker 8000 makes a screeching sound when it first starts but quits screeching about 45 seconds later. I turned the heat down today and it quit about 2 seconds after. The blower still...
the screech is probably the condenser or exhaust fan as you guessed. And yes, a decent handi-man can fix it. Check the horsepower, RPMs,rotation,shaft size, and frame # of motor and order a new one from www.grainger.com or a local carrier dealer.
Install the new motor exactly as the old one was and wire according to the motor literature or the graphic on the side of the motor.
Use care when removming the old fan blade. a good file on the shaft and some WD-40 makes the job easier. Also a bit of patience... :-)
I hope that this will help you to solve your problem!
Thanks for using Fixya!!
Heatman101
Dec 17, 2009 | Carrier XHB123D X/Y Series Heat/Cool Air...
Carrier AC fan not working right
it sounds like the capacitor is shot there is usually a duel capacitor one side is for the compressor and the other side is for the condensor fan motor if it is bad the motor will over heat and turn off on internal overload
Aug 25, 2009 | Heating & Cooling
Carrier Synergy 2000 Condenser fan does not turn on
the mfd is stamped on the side of the capacitor.Be careful to kill the power and to NOT touch the terminals.The capacitor is capable of holding a charge even after power is disconnected.
Jul 28, 2008 | Carrier 38CKC036 Air Conditioner
Carrier Bryant Condenser Fan Motor HC39GE226 Logo
22 people viewed this question
Top Carrier Heating & Cooling Experts
Dan Webster
Dan Webster
Donni Steen
Bill Long
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
