Question about Dell Latitude E5400 Notebook
What are the litt up symbols above the keyss?
I NEED TO WRITE IN SPANISH-LIKE WHEN WRITE ESPANA need the litte thing above the n
You need to download the language packs from microsoft for the spanish language. Or in microsoft word, you can INSERT the character you need by clicking on INSERT /CHARACTER
Jun 02, 2012 | Toshiba Computers & Internet
I need to know how to use the number symbol key on the brothers typewriter em530. It has two symbols above the number 3 key a / and # I want the # sign. When I press the shift and press number 3 it gives...
On brothers there is usually words written above the top row of keys. One of them usually says KBII
Press CODE and that key and you will select the second set of symbols.
DickyO
May 11, 2011 | Brother EM-530 Typewriter
I forgot my password
first try a soft reset or try a default password 1234
if that doesnt work you will need to do a hard reset. this is how there are two ways here is way number one
To do a hard reset its a bit of a pain
while pressing and holding both soft keys which are the two dashes just bellow the screen push the stylus into the reset hole pic above
Keep pressed until the warning appears. continue
If the device just starts up quickly then you have done a soft reset only.(as mentioned above)
Try again all three things must be done at the same time and held until the hard reset message appears.
If you succeed in hard re-setting but the password is still asked for then we may need an extra few steps to ensure the registry is cleared. .
way number two..
press and hold the left &right soft key, and at the same time, use the stylus to press thereset button at the bottom of your device.
release the stylus but continue pressing the 2 soft keys until you see a message on your screen
Release the two soft keyss, and then press the green call button on your device.
To perform a hard reset using Clear Storage if you can access it
1. Tap Start > Settings > System tab > Clear Storage.
2. Type "1234" in the box and tap YES.
please let me know if that helps
Mar 15, 2011 | HTC TyTN II Smartphone
I can not get the at symbole or the pound sign
hold down the shift key, and press the number 2 for pound Symbol, or 3 for at sign
Mar 06, 2010 | Computers & Internet
What is the symbol above the "change bag" symbol?
When the bag is full, the "full bag" light will come on and will turn itself off. Replace bag (make sure there is no clog) and try again.
Hope this helps.
Aug 17, 2009 | Electrolux Epic 6500 Vacuum
Car wont start on ocassion
the V.A,T.S. ignition lock cylinder is starting to fail , will need ign, cylinder and two new keysS.R. Peace
Apr 05, 2009 | 2001 Buick LeSabre
2000 ford windstar anti theft light flashing vehicle won't start
This means that your key is not being recogonized.Ethier the chip in the key is bad or the patts transciever at the lock cylinder. Do you have a spare key? If not you will have to get 2 new keyss cut and programmed.
Feb 15, 2009 | 2000 Ford Windstar
Samsung ML2510
Do you have paper in the tray? No paper loaded is one reason for the red light.
Apr 30, 2007 | Samsung ML 2010 Laser Printer
Dell Latitude E5400 Notebook Logo
Alun Cox
