Question about Nikon Office Equipment & Supplies
Canon mf8500c printer does not print colors correctly
5 Suggested Answers
Mark Ivan
  • 4 Answers
SOURCE: My Canon mp190 printer doesn't print after changing cartridges
it can not recognize the cartridge due to careless or mishandled.... so you will clean the cartridge using the tisue, be careful 'coz it is sensitive...
Posted on Nov 28, 2009
komguy
  • 2306 Answers
SOURCE: I have all the correct color cartridges on my
Just make sure the right colors are in the right place, photo magenta is not interchangeable regular magenta. Also run the nozzle check to make sure all colors print, if after 2 deep clean cycles you don't have all colors you may need a new printhead.
Posted on Jan 10, 2010
  • 164 Answers
SOURCE: Canon Pixma MP750 prints blank pages but prints correct test page
Start by making sure your ink cartridges are full and the correct or recommended crtridges. If ok try routine maintenance by doing the following:
1. Clean your print head using denatured alcohol solvent which can be purchased from most hardware stores. If unavailable, use 91% Alcohol (isopropyl alcohol (first aid antiseptic) which is available for less than a dollar at most Walmart pharmacy departments.
*Warning: You may want to use a pair of latex exam gloves as this is a messy process and can stain your fingers.
Time necessary 45-50 minutes
Supplies needed:
Isopropyl Alcohol or denatured alcohol
paper towels
latex gloves
sink, bowls and or basin
can of compressed air
very small screw driver
tablespoon or baby bulb type syringe
warm water
PROCEDURE:
1. Lift print head from printer. It pulls out easily because it is held in with the same down lever that holds the cartridge in place.
2. Put two layers of paper towels in the bottom of a dish to protect sensitive sprayer heads.
3. Put enough solvent in dish to cover the screens on which the cartridges sit when in use.
4. Take the two small screws out that hold the white ceramic piece
5. Gently, pry the ceramic piece back and away , to reveal the underside (No need to pull away the glued points on the sides.)
6. Gently, move head up and down to slosh solvent around it the best as you can. Use a table spoon or syringe to pour solvent over all orifices in the print head, turning it upside down and then back a few times.
7. Use canned air with a plastic straw to blow into and through all orifices, alternately sloshing/swishing and pouring solvent over head (be careful not to touch any of the holes, screens, or sprayer heads with anything)
8. Empty dirty solvent from bowl and replace with paper towels and clean solvent. Soak for approx 10 minutes. Rinse again with clean solvent poured directly on all parts, letting solvent overrun and fall into dish or basin.
9. Gently shake the solvent off the head, take it outside and spray with compressed air into all orifices to clear out and help evaporate any remaining solvent. Let sit on a clean paper towel for approx 20 minutes. (There may be a little ink bleeding out of the head, but once it dries completely it does not present any problems.
10. Reinstall head, cartridges and it will print like a new printer.
Posted on Mar 07, 2010
SOURCE: my canon mp 130 printer will not print color i
Check to see that the "Greyscale" tab hasn't been set, and it is set for color printing this is in printer properties.
Posted on Mar 22, 2010
My mp610 Canon printer will no longer print email documents (black)- leaves page blank, except for email address (in blue print)., But printer will still print satisfactory color pictures (Photos). B
Get the latest driver from Canon's web site. Then uninstall the printer. Remove the driver from your computer. Use regedit to remove any traces of your printer from your registry. Install the new driver. That should do it.
Jan 10, 2015 | Canon MP610 Photo All-In-One Printer
Canon MP470 prints colors light on Mountain Lion
So go back to former driver since this one does not work. A no brainer!!!!!
Aug 28, 2017 | Canon PIXMA MP470 All-in-One Printer
I changed two colour ink cartridges on my Canon iP4200 printer. Now it won't print colour. The pattern check does not print any colour.
You might want to double check to make sure that your printer takes two color cartridges? If I remember correctly, the Pixma takes one black and one color cartridge? If you put a color cartridge in the black ink assembly that would cause it to stop printing.
Double check and make sure that you have one black cartridge in the correct place and one color on the other side.
Apr 22, 2011 | Canon PIXMA iP4200 InkJet Photo Printer
Canon mp830 printing pinkish instead of blue
Hi
You have stick residue in the print head. Just run the print nozzle for 2-3 times to get the correct color.
Also, be sure that all ink cartridges are full because if one of the color is empty, you cannot achieve the correct color when one ink color is missing.
Please let me know if you need more help
Mar 08, 2011 | Canon PIXMA MP830 All-In-One InkJet...
I have all the correct color cartridges on my MP530 color printer. All of the sudden it coated a blue tint to my color printings. My print out look blue. Any suggestions I can correct the printer to print...
Jan 10, 2010 | Canon PIXMA® MP530 All-In-One Printer
Canon S900 Now prints murky and dull
Printing is Blurred/Colors are Wrong
? If a specific color does not print, check whether the corresponding ink tank is
empty. Replace if necessary.
? Print the nozzle check pattern to ensure that ink is ejected correctly.
If the nozzle check pattern does not print correctly, clean the printhead.
? Printing the Nozzle Check Pattern
? Printhead Cleaning
If the problem is not resolved after cleaning the printhead several times, the printhead
may be worn out. Contact the Customer Care Center.
Note ? Always ensure that you dispose of the protective cap and protective tape
from a printhead.
? Ensure that you are printing on the correct side of the media.
You can only print on one side of certain media.
Nov 16, 2009 | Canon S900 InkJet Printer
Canon pixma ip4000 color not printing correctly with full inks
In both cases be sure using correct ink. Use of generic ink can lead to leakage of catrridge seats do to crossion from inferrior ink quality (per Cannon). Be sure ink in proper locations - see manual. Run the maintenance proceedures: cleaning then print nozzle pattern. If all colors are not proper after two or three cleanings, perform deep cleaning. Print nozzle pattern after each cleaning. This should clear up problem. If not, print head may need replacement.
Feb 09, 2009 | Canon PIXMA iP4000 InkJet Photo Printer
Cannot clean Canon i960
The print driver might not be sending the correct color profile for photo paper. Check that your selection of the paper type "sticks", that is, that it doesn't revert to plain paper when you click on the print button.
If the print dialog is not working properly, then please get in touch with Canon's tech support to resolve this.
Jul 26, 2008 | Canon I960 InkJet Photo Printer
Purple Color Printing in b&w mode
When you do nozzle cleaning there is a print test that canon performs. I think it prints out each color. Did the Colors come out correctly? Cuz from there I think you can determine which color is really clogged. I have the solution somewhere but I need to know if the test print comes out correctly or not.
Jul 22, 2008 | Canon MultiPASS MP730 All-In-One InkJet...
Faded color photos
HAve you tried uninstalling Canon's software and reinstalling?
Sep 14, 2007 | Canon PIXMA iP1600 Printer
169 people viewed this question
Top Nikon Office Equipment & Supplies Experts
Jerry Greenberg
Jerry Greenberg
David Darrow
Level 1 Expert
Tanvi Thakur
Are you a Nikon Office Equipment and Supply Expert? Answer questions, earn points and help others
