Question about Whirlpool Duet GHW9150P Front Load Washer
Front door is locked and can't get it open. - Whirlpool Duet GHW9150P Front Load Washer
  • 5,911 Answers
First, try unplugging the washer for at least 30 minutes in order to reset the Central Control Unit (CCU). Sometimes this is all that is required to reset minor glitches with the unit. If the washer is still locked following a CCU reset, then you will need to use the manual release. The following link explains:
http://www.fixya.com/support/r622155-kenmore_elite_whirlpool_duet_door_jammed
If you still need assistance, please let me know. If the problem reoccurs, take note of any error codes that may appear and also let me know. I hope this helps you.
Posted on Jun 22, 2009
Front Doors LOCKED OPEN.. How to close?
Lift the door handle as if you were opening it
Hold the handle & use a round phillips to hook
& rotate the white door latch to the open position
May 18, 2014 | 2009 Honda Odyssey
Central locking 2005 subaru liberty stopped working on 2 doors
1. Replace battery in remote
2. Replace sensor at rhf door lock (it is inside of door)
Apr 30, 2014 | Cars & Trucks
WE have Kenmore elite He3t Model Nol. 42926 203. We get an error code dL F. How do we correct this?
It is a door lock failure and it flashes after the door locking routine fails to lock the door after 6 attempts. Replace the door lock/latch assembly (part number 8182634) to solve the problem.
Disconnect power to the washer and open the door. Remove the door gasket retaining hoop by stretching apart the retaining spring at the bottom of the door opening. Gently peel the part of the door gasket near the door lock/latch assembly off the lip of the right side of the door opening. Remove enough of the door gasket to access the door lock/latch assembly behind the front panel.
Remove the three screws securing the door lock/latch assembly to the front panel and slightly lift it then pull it back off the front panel. Pull the door lock/latch assembly out of the washer and disconnect the wiring harnesses.
Connect the wiring harness to the new door lock/latch assembly and install it back in place behind the front panel. the door lock/latch assembly and put the eased part of the door gasket back into position over the lip of the door opening.
Check that the door gasket is properly seated before putting back and securing the retaining hoop around the lip of the door opening and the door gasket.
Jan 07, 2011 | Kenmore Elite 45986 Front Load Washer
Machine flashes F then dl. What can we do?
There's a fault detected with the door lock and switch assembly. The door lock is not working or the door lock switch is not activated. This indicates that the door lock and switch assembly is malfunctioning and needs to be replaced to address the problem.
Disconnect power to the washer and open the door. Remove the door gasket retaining hoop by stretching apart the retaining spring at the bottom of the door opening. Using needle nose pliers, start where the spring and wire are connected and pull the wire out of the groove of the door gasket.
Remove the three screws securing the door lock and switch assembly to the front panel.
Gently peel the part of the door gasket near the door lock and switch assembly off the lip of the right side of the door opening. Remove enough of the door gasket to access the door lock and switch assembly behind the front panel.
Slightly lift the door lock and switch assembly then pull it back off the front panel and out of the cabinet.
Transfer the wiring harnesses to the new door lock and switch assembly one at a time then install it in place behind the front panel. Secure the
door lock and switch assembly and put the eased part of the door gasket back into position over the lip of the door opening.
Install the retaining hoop with the spring positioned at the bottom of the door gasket.
Sep 11, 2010 | Whirlpool Duet GHW9150P Front Load Washer
My door lock has locked with the door open , how do i get it to unlock ?
There is a manual unlocking tab located at the bottom of the door lock and switch assembly. Disconnect power to the washer before accessing it.
Remove the three screws attaching the toe panel to the cabinet then pull the panel down and off the cabinet. Prop up the bottom front edge of the washer or cushion and lean it against the wall for an easy access of the screws.
Reach up along the inside of the front panel and locate the bottom of the door lock and switch assembly on the right side.
Locate the tear-drop shaped tab then gently pull it down until a click is heard, and then open the door.
The door lock and switch assembly may need to be replaced if the problem persists. Disconnect power to the washer and open the door. Remove the door gasket retaining hoop by stretching apart the retaining spring at the bottom of the door opening.
Pull the door lock/latch assembly out of the washer and disconnect the wiring harness.
Secure the door lock/latch assembly and put the eased part of the door gasket back into position over the lip of the door opening.
Jul 03, 2010 | Whirlpool Duet GHW9150P Front Load Washer
My Whirlpool Duet washer will not start. I keep getting a "dl" and an "f" signal. I assume it means door lock failure. I've tried unplugging and opening and shutting the door before restarting but it won't...
It is indeed a door lock failure. Replace the door lock/latch assembly (part number 8181700) to solve the problem.
Mar 01, 2010 | Washing Machines
Driver's side door won't open in the cold
Power Door Lock Operation (Front Doors)
The front doors do not have traditional door lock actuators. They have electronically controlled door latches that will operate depending on the status of the door lock system. This status is determined by the front door modules and the last known state of the lock system. If the last known state is LOCK, the latches will not release when the door handles are operated. If the last known state is UNLOCK, the latches will release when the door handles are operated. The front doors are also equipped with red door lock status indicators. The front door modules will supply power and ground to the indicators to illuminate them when the lock system is in a virtual state of lock. The indicators will not continuously illuminate when the vehicle is locked. They will illuminate for approximately 5 seconds after a lock switch activation or after a door handle has been operated and the front door modules are in a virtual state of lock. For further information on the front door latches, refer to Power Door Latch Description and Operation .
I would assume they check for DTC'S - diagnostic trouble codes ?
DTC B3062 Front Door Key Lock Switch Circuit
• DTC B3067 Front Door Key Unlock Switch Circuit
DTC B3849 Exterior Door Handle Switch Circuit
The left front exterior door handle and right front exterior door handle switch signal circuits provide inputs to the driver door module (DDM) and passenger door module (PDM) when an exterior door handle switch is activated. These inputs allow the door module to detect a door open request. The door modules provide voltage to the door handle switches. If the door module detects that a ground is applied for greater than 30 seconds continuously, a DTC is set and the door module will ignore the door handle switch input.
Free wiring diagrams here http://www.bbbind.com/free_tsb.html
Enter vehicle info. year , make , model and engine size . Under system click body & accesories .Then under subsystem click power locks . Click the search button then the blue links
Cadillac CTS Door Handle Repair Micro Switches Replacement 2nd Gen
Aug 10, 2017 | 2006 Cadillac STS
Hotpoint wm63 door locked
The door lock has failed in the locked mode, only way to open door is to force it open.
Remove top cover, screws at rear , slide cover back away from you.
Down at the front right side you will see the lock, it is reddish brown in colour, with 3 wires attached.
Force a long handled screwdriver or similar between lock and cabinet front, and force the lock, you may have to break it, but it does not matter as it is faulty anyway.. The door will then open.
Remove the 2 screws holding the rest of the lock , and pull up with wires still attached, .
Transfer wires to new lock on the same connectios, and refit.
Test it, if it still does not work then you may have to fit a new door latch and or spring.
Plz rate this solution and if you have any further probs, plz let me know.
Dec 20, 2008 | Zanussi WJS1265W Front Load Washer/Dryer
Door locks open by themselves randomly
some possibilities
The power door locks may self-activate or cycle on some vehicles. This may be caused by a misadjusted front door lock linkage, excess solder in the front door power window switch, water infiltration of a potential open wire harness connector inside the front doors, wiring harness chafe on the door check strap, or a damaged Remote Keyless Entry (RKE) key fob.
Nov 16, 2008 | 1996 Mercury Sable
Whirlpool Duet GHW9150P Front Load Washer Logo
102 people viewed this question
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
