SOURCE: My tiller won't stay running
this is a two cycle with a walbro carb - probly need to remove carb to flush and put new diaphrams in
SOURCE: won't stay running
The carbeurator needs to be cleaned and probably rebuilt. Start with a spray carb cleaner by putting 3 or 4 shots in the carb. Run it for a minute then let it sit for two hours and run it again.
SOURCE: tiller wont stay running..
Clean out the small fuel inlet ports behind the diaphragm. Sounds like they are clogged up. Use the end of a paperclip to gently make sure the passages are open. Hope this helps. Good luck.
SOURCE: What type of oil goes in my 4 cycle 26cc mini
regular 30whd just like your lawn mower
Good Day.
SOURCE: Yard Machine rear tine 6hp tiller that wont start.
Ok, what's happening, is your carburetor metering hole is plugged. When you place your thumb over the carb, it draws fuel through the primer circuit to feed the engine instead. What you need to do, is clamp off the fuel line, take the nut off the bottom of the carburetor bowl, and clean that nut. Look closely at it; there is a hole that goes down the center of it, and a hole that goes through it side to side towards the bottom. These make a "T" shape inside the nut. You need to make sure that these are completely clear and clean. The one at the bottom is very small, and plugs easily. You usually need a small piece of wire to clean it, such as a single strand from a wire brush. You can use carburetor cleaner to loosen it up a bit, but the important part is to clean that hole out. You also need to make sure that the float moves freely up and down while you're in there. If it sticks in the up position, it will starve fuel as well. Also look closely at the gas that came out when you did this. Was there any water in it? If so, let a bit drain out before putting it all back together.(unclamp the fuel line). Hope you have it back online soon.
Testimonial: "Nut was clogged. Now it starts but acts as it is in choke position, dont think there is a choke. Engine reves, falls, reves falls but stays going."
