Question about Miele CVA 4062 Stainless Steel
Miele cva 4060 frother - Miele CVA 4062 Stainless Steel
3 Suggested Answers
SOURCE: Miele CVA 4075 brew unit locked
Turn your machine off. Close the door. Depress <clear>, holding it down, press <on/off> then let go of both. Then press <clear> 3 times. On 3rd time, hold it until Service menu appears. Select <brew unit> then press left arrow to turn from <off> to <on>. Then press right arrow by <select> This will turn your brew unit drive to the correct position and you should be able to get your brew unit in/out and your waste container back in. Make sure to turn your machine off/on again to get out of Service Menu. I have a picture of how the wire needs to be inserted to get that back on. It's definitely not intuitive, but send another note with your email address and I can send the pics.
Posted on Jun 03, 2010
espressonist
  • 1711 Answers
SOURCE: MIELE CVA 615 Occational "No
From you description it seems that you have a scale problem. It might that the pump it working by the sound you hear but the scale have make it either dificult to pump out the water from tank since the piping have been narrow.
So first you should perfom descaling with a descaling solution and repeat this a couple of times one every other day. If the scale biuld up is not heavy then this will solve you problem and you have to perform de-scaling every 20-30 days to maintain it clean.
If descaling have not help then you need to desasemble the machine and clean the pump and pipping manualy from scale. This procedure is might sound easy but you should be carefull not to damage any important parts like pump, boiler.
Posted on Dec 29, 2010
Miele cva 5060 when i press on shows 'insert boiling unit.' And stucks there any solutions pls .
any chance you could put up a photo of your brew unit ? something has fallen out of mine and i can't figure out where to put it !
Aug 20, 2015 | Miele Coffee Makers & Espresso Machines
Miele CVA 4066 stopped frothing milk
It sounds like the venturi tube is blocked. Have you ever removed the frothing unit and cleaned in manually? I have a model 4085 and I can reach under where the milk exit tube comes out, twist anti-clockwise (if you are looking up at it) and the whole assembly with the inlet and outlet tube comes out. These pieces can then be individually taken apart and rinsed thoroughly with warm water. If you put it back together (don't forget to twist the connector that locks it back in) and the milk still doesn't froth, take it out again and use a small needle to clear the top of the clear venturi tube which sucks air in to do the frothing. If it is really badly gunged up it might need to be replaced, but mine is 5 years old and still going with regular rinsing. My whole brew unit had to be replaced after 4 years at a cost of about GBP 200, but that's another story.
Nov 21, 2012 | Miele Coffee Makers & Espresso Machines
Cva 4070 drip tray issue
Miele CVA 4066 -Empty drip tray warning would not go off even after draining the drip tray, cleaning contacts, and resetting power. Water was coming out from under the empty tray.
I pulled unit out and removed sheet metal in rear around water inlet. when I attached water line and power cord & turned on power, I could see water dripping out of one of the 2 solonoids on the water inlet valve. $168.00 from Miele and no expensive service call.
May 27, 2012 | Miele CVA4070 Coffee Maker
I'm trying to find a place tp order a replacement part for my 4062. I just need the small rubber gasket that fits over the tip of the main line that inserts into the machine when you close the door....
if you still have your parts kit that came with the machine, there is a spare o ring included. It had a small tube of silicone grease, a pipe cleaner, cleaning and descaling tablets etc in a cardboard box. you should also have a spare air orifice for the milk frother. if you cant find it, just call 800 843 7231, press 0 and ask for parts. tell them what you need and they will mail it to you.
Aug 22, 2011 | Miele CVA 4062 Stainless Steel
The milk frother is not sucking milk from the cup... it appears that the steamer is working as if it is steaming the milk. Any ideas on why the frother tube is not sucking any milk up?
it is clogged with dried milk. Remove the frothing wand from the machine. now press milk froth. you should get a ton of steam blowing out of the hole where the frother used to be. Your frother comes apart for cleaning. pull the chrome tip off, pull the 90 degree fitting and the black milk suction tube off, if it is really dirty you can soak the disassembled frother in hot water with a cleaning tablet. ( the small ones you drop in the brew unit, not the big descaling tab.) also, there is a clear tube with a point on the end of it sticking out of the frothing wand. this is an air admittance oriface. it allows air to enter the hot milk stream and make it frothy and bubbly. if it gets clogged, you will get hot milk but no froth. Your machine came with a spare one in the parts kit.
Jul 04, 2011 | Miele CVA 4062 Stainless Steel
Where can I buy a Miele CVA 615 Expresso Watertank?
The only Miele spare parts are direct from Miele or through a Miele service agent. Have a look on the Miele website for your nearest Miele branch or service agent in your country.
I work for Miele and they only sell parts this way. if you call the Miele spare parts number off the website and tell them you have a cva615 they will be able to mail one to you.
Hope this helps.
Mar 23, 2010 | Miele CVA615 Espresso Machine
Parts list and drawing for a miele CVA 620 coffie machine
you would have to contact Miele spare parts for this information it is not readily available on the internet.
Nov 19, 2009 | Miele CVA610
How can I override descaling on a Miele coffee maker?
how can i override descaling on miele coffee machine cva 2660
Oct 30, 2009 | Miele CVA2660 Stainless Steel Coffee Maker
Says in the display Fault 10 and Fault 17. CVA 4060 built-in coffee machine Miele
I just switched machine off for a few hours and when started, it was OK
Sep 07, 2009 | Coffee Makers & Espresso Machines
Miele CVA 4062 Stainless Steel Logo
Top Miele Coffee Makers & Espresso Machines Experts
Jerry Greenberg
Jerry Greenberg
Michael Galve
Michael Galve
Colin Stickland
Colin Stickland
Are you a Miele Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
