Question about Vehicle Parts & Accessories
Holden commmodore vl problem starting
Car turns over but wont fire
    Master:
  • 710 Answers
Check coil.
Posted on Sep 01, 2014
Where in New Zealand can i buy a holden vectra octopus hose
2001 Holden Vectra Reviews - Carsurvey.org
www.carsurvey.org > Holden > Vectra
  1. Cached
  2. Similar
Aug 4, 2016 - 2001 Holden Vectra GL 2.2 from Australia and New Zealand ... 'Octopus' coolant hose blew. This is stupidly designed by some idiotic engineer ...
PartsWorld : Holden Vectra Parts - Right Parts, Right Service, Right Price
https://partsworld.co.nz/parts/holden/vectra
  1. Cached
  2. Similar
Not logged in ( login ' register ). PartsWorld is New Zealand's Largest Auto Parts Recycling Chain ... Holden Vectra Parts - Select a Series. help. Don't know your ... Missing: octopus
Search Results for radiator hose js vectra - Telstra Media Search
search.media.telstra.com.au/?location=&searchIndex=australia...hose...vectra
  1. Cached
  2. Similar
Products 1 - 20 of 103 - TBAP Radiator HOLDEN Vectra JR/JS 2.5L/2.6L 6Cyl Auto . ... /catalogues/hose-application-catalogue-aus-nz-october-2012.pdf.
Holden Vectra Heater Hoses ' Sparesbox
https://www.sparesbox.com.au/vehicles/holden/vectra/heater-hoses-category
  1. Cached
Shop Holden Vectra Heater Hoses online at Sparesbox Australia. FREE Shipping on orders over $50. Missing: zealand ‎octopus
Too expensive to repair - what next? - Servicing - Automotive ...
forums.whirlpool.net.au > Automotive > Servicing
  1. Cached
  2. Similar
Jan 5, 2011 - Rather than scrapping, get the bottom hose fixed (Should be like ... If you do end up buying a new car, always buy japanese or commodore/falcon. ..... Holden vectra, If it is V6 vectra i can tell you right now it wont be the head gasket. .... broadband · Regional · Last century; International: New Zealand ISPs.
Holden ' Car parts & accessories ' Trade Me
www.trademe.co.nz > Trade Me Motors > Car parts & accessories > Holden
  1. Cached
  2. Similar
Holden for sale in New Zealand. Buy and sell ... Holden Commodore VL, Manual steering Rack & Inter shaft .... Holden VT-VZ Front Electric Window Regulator.
New Zealand can buy holden vectra octopus hose Google Search
Nov 11, 2016 | Holden Cars & Trucks
I have a 2001 holden astra that yesterday took a couple of turns of the engine to start. Up until then it started first time. When I went to start it thismorning it turned over but would not fire. All the...
strange starting can be the oil line pressure sensor failing.if this sensor doesn't work correctly it turns the ecu spark off (oil light doesn't turn off when engine is turned over). as long as when you are turning over the engine and the rev counter is moving. if not it can be the crank sensor filed this also turns off the ignition spark. falling all that the coil pack has gone, but to check this you need a meter to check the connections.
Feb 19, 2018 | Holden Cars & Trucks
Holden ute on dedicated gas wont start
It sounds like the timing is out if it it is backfiring and now wont start reset the timing and your problem could be solved
Jun 06, 2013 | Holden Cars & Trucks
Rodeo petrol starts but wont rev
Holden Rodeo 1989 2.6mpi , start and only runs for 2 or so seconds themselves stalls, after putting on a fuel peesure gauge, fuel looked okay and slowly dropping, found the ECM relay was intermittently switching on and off, gave it a tap and the engine kept on running, relay not repairable, replace with new part. Located in the fuse and relay box on the right hand side of engine bay next to battery. Hope this helps.
May 24, 2012 | Holden Rodeo Cars & Trucks
I have a holden vx clubsport when i turn key so dash lights are on there is threebeeps then it wont start, if i turn straight to start it fires up beeps three times then dies
it sounds to me like hsv key / immobiliser problem. if you have other keys try them. otherwise its an auto electrician to find fault. hope this helps
Dec 22, 2011 | Cars & Trucks
I have a VL Holden Commodore (australian gmh)with a Viper 1000 alarm. it started fine then cut out then the engine only turns a few revolutions and doesnt start the starter doesnt keep turning could this...
yep definately sounds like the immoboliser, are you using the remote to disengage it? if not there should be a cut off switch for the system, try disengage it and check to see if it fixes the propblem.
Nov 25, 2009 | 2006 GMC Acadia
Car keeps loosing its power. has drained the battery and starts but has no power and then stalls. it is a holden commmodore ute, (vs) there was no listing for holden utes in the catagory
I have a VS ute also so am familiar with the car. If it is losing power it could be an electrical problem to do with the computer. On the dash panel there is an engine light - does it come on? If so that is a warning light which if you take it to a Mechanic with the right equipment will be able to tell you exactly what it is. It could be the ignition coil. If the car starts okay then just cuts out you will probably find it is the IAC in the throttle body. If you remove the Throttle body and clean it out with a cleaner from Supercheap Auto (for about $20) it should fix the problem. I had the same problem where it just died on trying to accelerate. I cleaned mine out with petrol and removed the two electrical components from the throttle body and cleaned them and made sure the tunnels to them were clean also. Luckily with mine I run on Duel Fuel so managed to get by on LPG when it played up on Petrol. Hope I have helped you - let me know how you go..
regards
Bryan
Aug 21, 2008 | Ford Fairmont Cars & Trucks
Vehicle Parts & Accessories Logo
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
