Why Maytag bravos lid locked? - Washing Machines
  • 113 Answers
SOURCE: maytag bravos
You have a broken lid switch, get me the model # and ill post a schematic and part #, thanks Dave www.washermd.com
Posted on Dec 17, 2008
  • 220 Answers
SOURCE: Maytag Bravo Washer flashes F50 code
Most likely a bad machine control,can also possibly be a motor per whirlpool but I have never had to change a motor,changed a lot of machine controls.
Posted on Sep 01, 2009
  • 56 Answers
SOURCE: Any problems with Maytag Bravos mvwB750w?
you would be better off with a front load. they (bravos) dont sell all that well and probably wont be around too long
Posted on Feb 07, 2010
  • 4 Answers
SOURCE: I was trying to use the Maytag Bravos but the lid
my wife says just push down on the front of the lid when it is trying to latch
Posted on Feb 08, 2011
KevinWhite
  • 1902 Answers
SOURCE: have a maytag bravos quiet
Hello & Welcome to FixYa
Ld means long drain and is displayed when it takes longer than 5 minutes to pump out the water to a point where the pressure switch resets. To solve this problem make sure that the drain filter pump assembly located inside the bottom front panel is clean and after cleaning if the error returns then the pressure switch needs to be tested and if bad then it needs replacement. Please get back to me if you have any other questions.
Kevin
Posted on Jun 25, 2011
I can not open the door on my Maytag top loading washer
Many new washer use a lid lock instead of a brake to keep people from reaching into the spinner before it stops. You probably have a
bad lid lock. Have a repair man open the top cover and repair or replace the lid lock.
Jul 06, 2016 | Maytag Washing Machines
Maytag bravo mvwx500xw does nothing lights come lid locks then nothing
check the inlet hoses are connected and tap is set to on.
Aug 25, 2014 | Maytag Washing Machines
Lid lock broken can I overide?
Washer not starting Cycle:
I would have to slam the washer lid before the washer recognized the lid was shut.
What I did to fix:
1. Ref the link below for Schematics
http://blog.kennyluong.com/Tricking-A-Maytag-Bravos-Washer/
2. Looking at the Lid Lock section of the Schematic:
Place a jumper between pins 2 and 3 of J15
This engages the 1st switch (Lid Lock) so, I don't have to slam the lid anymore
3. Since my Lock switch (2nd switch), which is engaged with a magnetic, is working, my work is done.
If you find that your machine is still not starting the cycle, you will need to
replace the Lid Lock mechanism or ref the above link for temp bypass.
Mar 30, 2014 | Maytag Bravos Top Load Washer
Maytag bravos x lid lock overide or bypass
dpthom's wife is the smartest woman on earth! :)
Feb 11, 2013 | Maytag Bravos Top Load Washer
Lid lock button is flashing and wont unlock
I u unplugged the machine and it stopped blinking, the lid unlocked but when I tried starting it again the same thing happened. I cleaned the contacts on the lock but that did not help.
Jan 08, 2013 | Maytag Bravos MTW6600T Top Load Washer
My maytag bravos washer is flashing DL, what does this mean, its not spinning!
The "dL" error code appears when an item inside the washer prevents the lid from locking properly. Open the washer and readjust any items that may be hitting the lid. The error code should go away once you properly close the lid
May 03, 2012 | Maytag Bravos 3.8 Cu. Ft. Washer
Maytag Bravo Top Loader Lock will not work
There is likely to be a problem with either the door/lid solenoid/lock or the 'door/lid closed' sensor requiring a service engineer's attention I suggest ;-0(
If this has assisted and/or clarified the situation for you please consider a 4 thumbs up on our rating.
Thanks and good luck!
John C
Jul 03, 2011 | Maytag Bravos MVWB400V Washer
Our Maytag Bravos washing machine will not unlock. The lock light is not lit up. We ran a load twice and it still did not unlock.
du is the code for cannot unlock,,,,is there excessive weight on the lid, such as a basket of laundry? Excessive weight will keep the lid from unlocking. Press POWER/CANCEL once to clear the code.....
Dec 11, 2008 | Maytag Bravos 4.5 Cu. Ft. Washer
Washing Machines Logo
13 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
