Question about Kodak ESP 3 Multifunction Printer/ Copier/ Scanner
Changed ink cartrige now can get printer to work
Kodak ESP 3 All in one printer, can't get my printer to print. Installed new Ink Cartridge yesterday, red light appears stating that their is a problem. Can you help?
  • th4867 Jun 23, 2009
    th4867
    I follow instruction as directed however no result. Spoke to Kodak andinformed them of my problem, they are sendinga new color cartridge.
    Would a malfunctioning color cartridge result in the black cartridge also not functioning ?
    Sergeant:
  • 239 Answers
Uninstall and reinstall the drivers.check for printer, test manually by pressing the test button on the printer.check the manual for reset the printer settings.if it doesn''t work.check with the manufacturer, there may be some hardware failure.
i hope this will help you to fix the problem.
Posted on Jun 23, 2009
    Genius:
  • 1,847 Answers
Firstly let me know if you are getting any error message?
Try this....
You have to re-install these cartridges, please follow the instructions below:
1) Turn on the printer; take out the old used cartridges
2) Turn off the printer for a few minutes
3) Turn on the printer, when it says "insert inks", and then insert thecompatible cartridges one by one, making sure the cartridges aresitting completely in the slots.
Please shake the cartridges and use the alcohol cloth to clean the cartridge head.
Still no go..
run clear utility fromwww.kodak.com/go/clear
and reinstall kodak software from
www.kodak.com/go/downloads.
Note- Do not connect your printer while installing the software untill installation wizard say to do so
thanks
Kevin
Posted on Jun 22, 2009
Kodak ESP-3 All-in-One-Printer still says black ink catridge is low after I replaced it
There is a sensor in the cartridge which contacts with the printer. See it is clean from dirt. Try reseating the cartridge. If you use cheap cartridge rather than genuine then this could happen.
Check for updates in the Kodak website appropriate for you.
http://support.kodak.com/app/intfSel/intf_redirect/L2FwcC9hbnN3ZXJzL2RldGFpbC9hX2lkLzE3MzAzL34va29kYWstZXNwLTMtYWxsLWluLW9uZS1wcmludGVyLWZpcm13YXJlLS0td2luZG93cy1vcGVyYXRpbmctc3lzdGVtcy9vcmlnX2ludGYva29kYWtfYjJjX2Vu
Dec 01, 2012 | Kodak ESP 3 Multifunction Printer/ Copier/...
Just had new printer again kodak esp 7 and got same problem black ink cartridge not printing
are the ink cartridge you are using refurbished because sometimes the printer wont read them had a simular prob with my printer you might have to just buy new ones for it
Sep 30, 2012 | Kodak ESP 7250 All-in-One InkJet Printer
Purchased Kodak ESP 3250 yesterday. Not printing photographs.
Yes sounds to me like one of your ink cartridge is empty. Replace and try again.
Jul 26, 2010 | Kodak ESP 3 Multifunction Printer/ Copier/...
My printer only prints color..have installed new black cartridge but still only prints color so installed another new black cartridge and still only prints color
Unlike most printers where the print cartridge and printheads are attached and sold together, the ESP 3 has a separate printhead from the cartridges.
Remoe both cartridges. Then look at the place where the cartridges sit. There is a latch you push down in the back. This will release the printhead to allow it to be removed.
Remove the print head
Take a cotton swap and a little alcohol and clean the printhead of all ink. Repeat this until it is totally clean.
Make sure the printhead is dry and clean of all ink and alcohol.
Replace the printhead.
Place cartridges in and test.
If this does not work, then you need a new printhead for this printer.
here is an example of how to remove and replace printheads for thsi unit.
http://faqs.kodak.com/atg/faq/attachments/AUR1780-2.pdf
to gt a new printhead you must contact kodak
http://www.kodak.com/go/contact
probably as expensive or almost as expensive as a new printer.
The seperate printhead from the carts are why kodak can have their ink so cheap. Those other brands cost that extra 15-20$ for the attached new head with each cart.
Jun 12, 2010 | Kodak ESP 3 Multifunction Printer/ Copier/...
Kodak esp 3250 won't print black. Changed cartridge and still won't print black. Just installed new printer.
I fixed my ESP 3250 print problems by removing the cartridges and print head. Using a Q-tip and warm water, added drops of water to each of the print head ink wells until the water / ink from the wells bled thru onto a cleanex. Did this several times. Dryed the print head fairly well. Then added a drop of water to each cartridge for each color. Reasembled and ran an alignment and to my surprise, it works! I hadn't used my printer in a while, so the ink had dryed on the felt for both the print head and cartridges.......
May 15, 2010 | Kodak ESP 3 Multifunction Printer/ Copier/...
Kodak ESP 3 Colors won't print
For that problem kindly try doing the ff:
  • Re-seat the inks both color and black then try printing
  • Re-seat the Printhead of the printer then print again
  • if problem still persist call 1800 421 6699 and the technical rep will replace the printhead
Hope this will help
Thanks
Byron
Aug 28, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
Kodak esp 3 printer won't work
Hope this will help
Thanks
Byron
Aug 20, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
Kodak esp-3 cannot purge air from print head
WE HAVE AKODAK ESP-3 ALL IN ONE.
RAN OUT OF BLACK INK. HAVE REPLACED BLACK CARTRIDGE 2 TIMES BUT CANNOT GET BLACK TO PRINT. WHAT SHOULD I DO NEXT???
Apr 23, 2009 | Kodak EASYSHARE 5500 All-In-One InkJet...
Kodak ESP 3 Multifunction Printer/ Copier/ Scanner Logo
42 people viewed this question
Top Kodak Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
