Question about Car Audio & Video
1995 lexus sc400 12 disk cd changer reads err on every cd
SOURCE: 6 Disc Changer > Err
Don't waste your money and buy those repair manuals. There is an easy fix for this. The rootcause is most likely related to your disc tray (crooked carrier or broken spring). Just get a small screwdriver and take out the two black srews of the inner faceplate, covering the cassette tray itself. Please make sure you do not drop those tiny screws. Use a magnetic tip screw driver. Take the faceplate off. You will see a litlle lever in the center. Just push it aside and your cassette will pop out with no problem. That simple. So don't waste your money!!!
Posted on Apr 17, 2009
smarthome2
  • 1114 Answers
SOURCE: 6 CD Changer Stuck (Lexus LX 470)
Open the eject door and at the lower right side of the cartridge their should be a small indent that looks like you could poke it with a medium point pen. That's a reset for the changer. If that does not work, you will need to remove the changer from the car, pull off the top, plug the cable back in and hit eject. look for the arm on the backside of the cartridge and give it a nudge. It may just be stuck. Loading mechanisms usually do not fail before the optics or other!. If you need further help, post a comment with any model #'s on the changer and I'll look for info and help some more. Hope this helps.
Posted on Sep 30, 2009
  • 3 Answers
SOURCE: 5 disk cd changer is flashing and cannot select
I also had this problem, but found the solution here... http://www.fixya.com/support/t358730-blaupunkt_idc_a09_5_disc_cd_problem
Give it a good whack...
I did it, and then hit the eject button and the CD came right out. After that, it worked just as it should.
Posted on Nov 27, 2009
jdinse
  • 74 Answers
SOURCE: i have a 1993 lexus gs300 with a nakamechi sound
there is no replacement for the factory changer unit
Posted on Jun 15, 2010
alicantecoli
  • 22156 Answers
SOURCE: i bought a used 6
well something is wrong and it could be a jammed CD ,best advice i can give is to cut losses and fit an aftermarket radio with a usb and SD card player ,that way a 1gb SD card will hold and play 20 or more CDs .they cost about 80 euros here in spain and one with built in blue tooth about 120 euros .I do feel this is a cheaper alternative than messing around with cd changers that inveriably go wrong with age .
Posted on Sep 02, 2010
How to load disks in 12 disk changer in 1995 lexus cl400
Not 100% sure but they normally go in with the written side facing up and the data side down. Hope this helps
Jan 13, 2016 | Lexus Cars & Trucks
CD CHANGER SHOWS ERROR 21
This may be an indication that the CD player has worn out and needs replacement.
May 11, 2013 | Car Audio & Video
Lexus 2001 is 200 6 disc stereo error 1 code shows when trying to play cds
Error 1 - "disc is dirty, damaged, or is inserted upside down"
I quote other solution comments:
I've been getting the Err 1 and Err 3 for a while now, my headunit needs replacing but I haven't had chance yet...
I've found that the cold weather makes it worse as the CDs get that cold they are covered in condensation so the CD has trouble reading them..
In my experience when you get an Err 3 it's basically knacked and needs replacing and Err 1's can sometimes be read problems - what's the disk like?
Mine has started giving Err 1's on brand new CD's (not CDRs) so she's probably having trouble focussing....
If the car is less than 5 years old the headunit should be covered under warranty (ie free).
Hope helps.
Apr 02, 2011 | 2001 Lexus RX 300
HOW DO YOU GET THE CD CHANGER TO PLAY WHEN IT IS READING ERR
I don't think the cd changer mechanism is ok if it reads err continuously or with more than a few cd's.The lens may be dirty, but in many cases it may need a new cd-changer mechanism or another cd-changer altogether.
Oct 05, 2010 | 2002 Isuzu Rodeo
I have the same problem error 4 in my lexus rx330 please help me
I just left the Lexus dealership w/ my ES 330 (my changer reads "Error 3" upon starting my car, it also makes a loud ticking noise); go figure, the mechanic/technician there informed me that I need another motor for my disk changer - Merry Christmas and hello $675!
After turning your car off for about an hour or so, the cd player is supposed to reset itself enabling you to retrieve your cd's. Attribute this to having utilized burned cd's.
Sep 19, 2009 | Panasonic Car Audio & Video
Err message on 1999 Jeep Grand Cherokee 10 CD changer
I had a similar problem which responded to the use of a CD cleaner disc to clean the laser lens reading the CD. The "err" messages stopped and the changer started to work as it had before. Perhaps this will correct your problem too.
Aug 02, 2009 | Jeep AM/FM Cassette with CD Changer...
1994 lexus ls 400, cd player
Hello I just purchased a 1991 Lexus LS400
I have one of those 6 cd changers and got "err" when I started up the CD.
Here is what I tried and the result
1. I took out the CD,s replaced with new ones and it played but only for a bit, then even the new CD's got the err message
2. I then though maybe dust and/ or dirt so I took out the 6 pack of CD's and blasted compressed air into the unit from a can of computer cleaner compressed air. Lost the err message but then came back
3. Read a few other ideas on the problem and then tried the old hair dryer trick. (I am a long term live a board boater and have brought back may mis-behaving electronic devices that have moisture issues with the hair drier) However the hair drier did not do away with the err message.
4. two more boating tricks I thought of... I wiped down each leaf of the CD pack with rubbing alcohol
and actually got a good deal of dirt off the plastic, finally and probably the solution I sprayed some "wire dryer" a light spray then a mist.( Wire dryer made by Gunk is a spray can of a liguid we used all the time to get cars started in the cold weather, even got a better connection by spraying on battery wires to get the sailboat diesel started with an almost dead battery.)
I Waited a few minutes put back the cd holder and it worked.
It has been about 6 hours and it is still running like a champ.
could have been the combination or just the wire dryer...not very scientific maybe it will help
Jan 12, 2009 | 1993 Lexus Ls 400
1992 6 disc cd changer not working
Are you placeing cds face up or face down in the changer, some cd changers will only play with the cds face down.
Oct 26, 2008 | 1992 Lexus Es 300
1994 lexus ls 400 radio reads err when i try to play cd changer.
Hi
How can I find the code for my 1994 Lexus LS400 radio.
Please replyat : shahramanwari@cox.net
With regards.
Sep 16, 2008 | Car Audio & Video
Pioneer P626 car audio in 1991 Lexus LS400
With radio off I pressed the CD button and CD came on with no error code and works fine.
Feb 17, 2008 | Car Audio & Video
Car Audio & Video Logo
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
