Question about Air Conditioning Condenser 2006 Mercury Milan
Where is location air conditioning condenser 2006 mercury milan
Key stuck in ignition in park. Check charging system comes on. Dealership says it might be a fuse.
Key Stuck in Ford Fusion (2006 model) - YouTube
? 1:21
https://www.youtube.com/watch?v=3LVQttFOzGA
Jun 18, 2014 - Uploaded by Jessica East
#Ford #Fusion #Key #ignition #Stuck #FordFusion2006. ... i have a 2006 mercury milan and my key got stuck in there last night,... it to park with a little bit of force. will see what happens next time. good video, nice to know.
Key Stuck in Ignition While in Park
www.2carpros.com/.../2007-ford-fusion-key-stuck-ignition-while-park
Dec 16, 2012 - KEY STUCK IN IGNITION / SHIFTER BINDING CONDITION FORD:2006-2007 Fusion LINCOLN: 2006 Zephyr MERCURY: 2006-2007 Milan
Nov 06, 2015 | 2006 Mercury Milan
How do I know if it is the real main seal that is leaking on my 2006 mercury milan? The oil pan gasket was just replaced and it is still leaking
The best way is to take it to a shop that can put dye in the oil and then use a black light to see where it is leaking.
Mar 10, 2015 | 2006 Mercury Milan
Where is the horn located on mercury milan 2006
Safely raise and support front of vehicle, The diagram shows the tire removed, right front. Remove 4 screws in splash shield, pull down on splash shield to reach horn. The horn is number 4.
Just make sure the horn is the problem and not wiring circuit issue, somewhere.
Any time your working under a vehicle there are safety issues, safety is your responsibility.
Jul 25, 2012 | 2006 Mercury Milan
I was told that I need a discharge sensor 2006 Mercury Milan. The AC blows but they said the sensor in the dash is not telling the AC to come on. But when I try to buy this part no one knows what that...
There are two sensors; Climate Control Sun Sensor located on the dash or rearview mirror, and an Ambient Air Temperature Sensor located by the climate control panel. I believe the one you're looking for will be the Ambient Air Temperature Sensor.
Mar 24, 2011 | Mercury Milan Cars & Trucks
2006 Mercury Milan key stuck in ignition.
There's a TSB published by ford for this condition. It's caused by a binding shifter button.
adobe.gif Printable View (73 KB) TSB
07-14-7
  • KEY STUCK IN IGNITION / SHIFTER BINDING CONDITION
Publication Date: July 6, 2007
FORD: 2006-2007 Fusion LINCOLN: 2006 Zephyr MERCURY: 2006-2007 Milan
This article supersedes TSB 07-2-1 to update the Part List. ISSUE: Some 2006-2007 Fusion, Milan and 2006 Zephyr vehicles built before 9/4/2006 may exhibit a customer concern of the ignition key getting trapped or a shifter slider binding condition. Most of the key trapped conditions are caused due to a binding shifter button which does not allow the pawl to contact the park detect switch.
ACTION: Follow the Service Procedure steps to correct the condition.
SERVICE PROCEDURE If the key will not release from the ignition cylinder lock follow the Key Trapped procedure. On vehicles with a hard-to-shift shift lever into park or slider bunching/binding then follow the Shifter Slider Binding procedure. Key Trapped:
  1. Actuate knob button 5-10 times, observe for binding or sticky condition.
  2. Replace knob assembly if the knob sticks following Workshop Manual (WSM), Section 307-05. NOTE: WHEN REPLACING THE SHIFT KNOB DO NOT REUSE THE SCREWS. REMOVE AND DISCARD THE SCREWS. INSTALL TWO NEW SCREWS AND TIGHTEN TO 18 LB-IN (2 N-m). DO NOT OVER TIGHTEN THE SCREWS OR DAMAGE MAY OCCUR.
Shifter Slider Binding:
  1. If shifter slider is bunched up or binding, replace bezel assembly following WSM, Section 307-05. NOTE: WHEN REPLACING THE BEZEL, CARE NEEDS TO BE TAKEN TO ENSURE THAT THE BRAKE SHIFT INTERLOCK OVERRIDE TAB IS PROPERLY ALIGNED INTO ITS GUIDE. REFER TO FIGURE 1.
    Figure 1 - Article 07-14-7
    NOTE: WHEN REINSTALLING THE SHIFT KNOB DO NOT REUSE THE SCREWS. REMOVE AND DISCARD THE SCREWS. INSTALL TWO NEW SCREWS AND TIGHTEN TO 18 LB-IN (2 N-m). DO NOT OVER TIGHTEN THE SCREWS OR DAMAGE MAY OCCUR. NOTE: IF OVERRIDE CAP IS DAMAGED DURING REPAIR, IT IS AVAILABLE SEPARATELY.
PART NUMBER PART NAME 6E5Z-7D443-B Bezel Asy-Black w/FNR5 Trans (Fusion-Milan) 6E5Z-7D443-C Bezel Asy-Black w/Aisin F21 Trans (Fusion-Milan) 6H6Z-7D443-A Bezel Asy-Satin Nickel (Zephyr) 6E5Z-7213-C Knob Asy-Black (Fusion-Milan) 6H6Z-7213-A Knob Asy-Charcoal (Zephyr) 6H6Z-7213-B Knob Asy-Charcoal-OD (Zephyr) 6E5Z-7A214-B Override Cap-Black (Fusion-Milan) 6H6Z-7A214-A Override Cap-Satin Nickel (Zephyr) W790088-S901 Screw (2 Req)
WARRANTY STATUS: Eligible Under Provisions Of New Vehicle Limited Warranty Coverage
IMPORTANT: Warranty coverage limits/policies are not altered by a TSB. Warranty coverage limits are determined by the identified causal part.
OPERATION DESCRIPTION TIME 071407A 2006-2007 Fusion, Milan And 2006 Zephyr: Replace Knob Assembly, Includes Time To Diagnose And Verify Repair (Do Not Use With 04536A, 04536B, 7213A) 0.3 Hr. 071407B 2006-2007 Fusion, Milan and 2006 Zephyr: Replace Bezel Assembly Includes Time To Diagnose And Verify Repair (Do Not Use With 04536A, 04536B, 7213A) 0.4 Hr.
DEALER CODING BASIC PART NO. CONDITION CODE 7213 69
NOTE: The information in Technical Service Bulletins is intended for use by trained, professional technicians with the knowledge, tools, and equipment to do the job properly and safely. It informs these technicians of conditions that may occur on some vehicles, or provides information that could assist in proper vehicle service. The procedures should not be performed by "do-it-yourselfers". Do not assume that a condition described affects your car or truck. Contact a Ford, Lincoln, or Mercury dealership to determine whether the Bulletin applies to your vehicle. Warranty Policy and Extended Service Plan documentation determine Warranty and/or Extended Service Plan coverage unless stated otherwise in the TSB article. The information in this Technical Service Bulletin (TSB) was current at the time of printing. Ford Motor Company reserves the right to supercede this information with updates. The most recent information is available through Ford Motor Company's on-line technical resources.
Copyright © 2007 Ford Motor Company
2010&c18=non-tab%20view&c21=07-14-07&c35=tsb%2c07-14-07&s=1366x768&c=32&j=1.3&v=y&k=y&bw=778&bh=347&ct=lan&hp=n&[aqe]
Mar 08, 2011 | 2006 Mercury Milan
Where is the coolant thermostat on a 2006 mercury milan.
WELL YOU DID NOT GIVE ENG SIZE BUT THE ARE AT THE TOP OF ENG FOLLOW UPER RAD HOSE AND IT SHOUL LEAD YOU TO THE THERMOSAT HOUSING HOPE THIS HELPS
Mar 16, 2010 | 2006 Mercury Milan
Upgrading 2006 Mercury Milan's sound system with MP3 jack.
Even though your current radio has an AUX button the radio is not programmed to utilize it.
There is no 'easy' way to add the '07 Job 2 and later year model's factory Aux input.
You will need to buy an aftermarket solution. Something like this http://pac-audio.com/productDetails.aspx?ProductId=821&CategoryID=24
Oct 02, 2009 | 2006 Mercury Milan
Air Conditioning Condenser 2006 Mercury Milan Logo
12 people viewed this question
Top Air Conditioning Condenser Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
Are you an Air Conditioning Condenser Heating and Cooling Expert? Answer questions, earn points and help others
