Question about Electrical Supplies
Why is my 2007 15 kva harrington generator going into overspeed after 20 seconds after it starts?
This model has akubutu v1505 engine and has done 5500 hours
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 124 Answers
Check speed regulater
Posted on May 09, 2014
CarlGehrke
  • 169 Answers
SOURCE: 10kw Generac shut down overspeed
Make sure that the throttle linkage is all there and not damaged/misadjusted, then get a manometer and check your inlet gas pressure. Gas pressure should be 8 inches of water column and stay there running or not.
Carl
Posted on Apr 06, 2009
SOURCE: COLEMAN powermate 5000 generator w/a Subaru engine
Check the vent in the fuel cap to make sure its free to breath. It could be creating a vaccume in there and starveing for fuel. Maybe run it with the gas cap off and see if the problem gos away.
Posted on May 06, 2009
  • 26 Answers
SOURCE: Attempted to start Generac Guardian 15 kw air
I work on these every day. Its either gonna be the rotor or stater, the voltage regulator, but most likely its a bad stepper motor which is the throttle motor, or control board. Thats all that could be causing that so its one of those. If its the rotor or stater thats bad it causes the generator to RPM up because it thinks its not producing enough power due to that. I had the same problem with the same one we just fixed and it was the slip rings on the end of the rotor so bad rotor.
Posted on Jul 09, 2009
  • 4 Answers
SOURCE: 5500 generator stopped producing eletric after
First check with the dealer and see if it is still under warranty. If it is not, make sure nothing is blocking the air flow around where the control modules are located. This could cause the voltage regulator and other electronic parts to overheat. Next check the brushes and make sure they are free of any dust or build up preventing them from making contact.
If everything is OK the next thing I would do is change the voltage regulator.
Posted on Nov 25, 2009
SOURCE: Generac Guardian 15 kw overspeed fault
Did you remember to set the overspeed shutdown threshold on the control board?
Posted on Jun 07, 2010
How do you fix generator from going into overspeed?
you have a stepper motor issue. thats why its overspeeding
Nov 13, 2017 | Electrical Supplies
What is the general specification of Genset 20kv?
Generally 20 Kva power generator can produce more power. The voltage used in this 20 kva generator is 3 phase with frequency 50 Hz. 20 kva generator engine is already very enough for use on buildings that require large electrical power or public places such as shops. According to me HARGEN provides the best high quality genset.
To fill the fuel tank to the full required 62 liters of fuel in order to use this 20 kva generator engine with more leverage.
20 kva generator engine is also issued a noise that can reach 61.7 db or can be heard up to a distance of 7 meters away from where this generator is located.
Sep 11, 2017 | Cars & Trucks
HOW DO I BRING THE IDLE SPEED UP
sounds if no throttle cable is connected and your running it off the govennor to be asking this question ,(if it had a throttle cable increasing it would bring speed up) the govenor speed is adjustable by the little screw on the top of carbarator that is connected to silver half moon (looking clip) use care to not overspeed engine if done while running , and a little bit goes a lot on the screw
Oct 03, 2014 | Kohler Command OHV Horizontal Engine with...
How to fix the problem of overspeed on desiel generator
Check the mag pickup speend sensor that is screwed in where the flywheel bolts tot he alternator. Sometimes they can pick up chips etc. Unscrew wipe off, screw all the way back in by hand slowly until it makes contact with the flywheel teeth. Then back out 1 turn. Check voltage on sensor wires during cranking, it shoupld be approx 2V AC. If not replace sensor.
Aug 27, 2012 | Taylor Mobile Generator Set 80 kW, 480...
How to fix over speed fault in desiel generator?
On the flywheel is a small sensor you should see it, like a threaded bolt with wires, that goes into the housing. This is the mag pickup speed sensor, it can get metal filings on it causing this fault. Unscrew it and wipe it off, screw it CAREFULLY all the way down with your fingers until it touches the flywheel then back out one turn, it is a small gap. Crank engine and measure the voltage on the sensor wires will be approx 2 VAC if it is working, if not replace sensor
Generac Guardian 12 KW Model 04456-2 shuts down on overspeed in cold weather
Leigh,
See my 5/22/12 comments on my "overspeed fault" problem resolution [Generac 43903 standby Generator overspeed indicator on starting] . If it only runs for a few seconds and then quits, you may have a similar condition to the one my unit had. A good technician should be able to diagnose the problem and determine if you have a similar failure to the one I had, or one of the other causes suggested by RSG000.
Jan 20, 2012 | Generac 13,000 Watt / 13,000 Watt Home...
I have a Kohler generator set model KT17 that was not run for several years and was full of old gasoline. It would not start at all so I replaced plugs, cleaned fuel pump & filter, then cleaned carb...
Check the genset controller for a fault, low oil psi, no output voltage, overspeed, overcrank / no crank disconnect signal / starter staying engaged, high engine temp.
Jun 26, 2011 | Kohler Electrical Supplies
Apr 03, 2009 | Generac 13,000 Watt / 13,000 Watt Home...
Electrical Supplies Logo
54 people viewed this question
Top Electrical Supplies Experts
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
