Question about Sharp Aquos LC-13B4U-S 13 in. EDTV-Ready LCD Television
Reset button for sharp tv lc-46le820un - Sharp Aquos LC-13B4U-S 13 in. EDTV-Ready LCD Television
SOURCE: remote control tv codes for sharp lc-32sb24u tv
I need the remote codes for sharp LC-32SB24U tv. Thank you!
Posted on Nov 23, 2008
  • 8457 Answers
SOURCE: sharp LC-26d4u tv won't turn on/power light is off
Check ur power source,unplug replug if not work,Ur tv power board ic inverter it dead needed to be change.
Posted on Aug 17, 2009
satavlad
  • 405 Answers
SOURCE: No sound from TV - Sharp TV LC-32GPIU
Make sure that output (audio) set to "fixed" not "variable", to verify that go to menu-option-output select-?
Posted on Oct 23, 2009
satavlad
  • 405 Answers
SOURCE: sharp flat panel tv,need manual for lc-19sb25u
http://www.sharp.ca/manuals/default2.asp
Posted on Oct 24, 2009
DVIroyce
  • 64 Answers
SOURCE: OWNER'S MANUAL AND A REMOTE FOR A SHARP SHARP 46'' TV MODEL lc-46s
The mauual you can get from the internet by Googling it will be in PDF format that you can print. The remote use a Universal cheap GE is good and program with one of these codes....
0079, 0123, 0063, 0020, 0004, 0009, 0226,
0266, 0006, 0095, 0122, Low cost approach.
Posted on Nov 08, 2009
Why dose my sharp aquos lc-40d78un power on then turns right back off
No reset button. Probably a problem with the internal power supply.
Jun 09, 2014 | Sharp LC40D78UN 40 in LCD TV
How do I reset the secret code for a lcd Sharpe aquios LC-C5277un
Factory Default Reset:
- Unplug the TV and count to 10 slowly.
- Hold down the power button on the TV (not the remote.)
- Plug in the TV while holding power button.
- Count to 10 and release the power button.
- Turn it on and hope for the best.
Sep 24, 2010 | Sharp Aquos LC-45GD4U 45 in. LCD HDTV
SHARP LCD TV LED SLEEP AND TV BLINK I and I can't reset whith vol - and chanel down when i plu ac cord someone have an idea ?
- Hold down the power button on the TV (not the remote.) ;))))))
Sep 24, 2010 | Sharp Aquos LC-37G4U 37 in. HD-Ready LCD...
Sharp lc-c5277un, tv turns on but no picture, switched the cable to the blue ray input and worked but no other inputs work. Happened before, Costco had me do some kind of reset and worked till today.
your main board that takes all the input is the cause to this problem. you can try to reset the tv by disconecting it from the power outlet, then press the power button on tv (not on the remote) and hold it down for 30 seconds
Aug 24, 2010 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Hi Folks, I've got a sharp LC-26SA1E.The sound problem I have is that it only has 3 sound levels.None, Loud(30) and house shaking loud (60).There is an error code that has come up in the top left hand...
While tv is off press and hold buttons on tv VOL(-), A/V and switch it on, release buttons after 5sec.
Suppose to get back to normal state then.
I checked on my old sharp lcd lc-32ra1e and worked.
Oct 29, 2009 | Sharp Aquos LC-32GD4U 32 in. LCD HDTV
No Picture
If your TV is a SHARP LC-45GD5U,
Try using the reset buttons on the back of the TV. It should be below your digital audio output port.
If that doesn't work, ( this is only a guess) the power supply for the LCD screen may have burned out.
Feb 15, 2009 | Sharp LC-45GD5U 45 in. LCD Television
HDMI connection problem
Your TV doesn't like your laptop I guess.
There should be 2 reset buttons behind your TV.
Press the reset button first.
If that doesn't work, try the system reset button next.
If that doesn't work, you'll have to call 1-800-BE-SHARP to help you with the possible software problem with the TV
Good Luck
Feb 12, 2009 | Sharp Aquos LC-32D40U Television
Sharp LCD LC-46D64U
Try resetting the TV. Here's how to do it - Unplug the TV's power cable. Keep the Channel Down and Volume Up buttons on the TV pressed and plug the power cable back into the outlet. You will hear a click when you plug it back in if the reset is successful. Hopefully this should restore your video and audio.
Dec 25, 2007 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
My sharp 26"lcd tv stuck in standby,wont turn on
I had a same problem with sharp LC-40LE340E. The service told me to change motherboard but I decided to buy a new LG TV. The sharp TV I left unplugged for a 50 days and after that when I tried again the tv started normally. I was Really surprised. Don't spend money just wait and check again. shkelzen65@gmail.com
Oct 12, 2007 | Sharp LC-65D90U 65 in. LCD Television
Sharp Aquos LC-13B4U-S 13 in. EDTV-Ready LCD Television Logo
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
