Question about Kitchen Ranges
F08 code on viking oven - Kitchen Ranges
F08 error code
F08 error code: Door open when program started
May 01, 2015 | Bosch Washing Machines
How do I fix error code f08 on a zanussi zpb 120 built in oven
Fo8 is heater fault. Check element first
Nov 17, 2014 | Ovens
I have a Viking Oven and the code F o8 has shown up. What does that mean?
Hall effect sensor in cooling fan issue. Shut down and power up again . Or call tech assist at 888/845-4641. Hope this helps
Oct 20, 2014 | Viking Ovens
Light is flashing reading Err 08 on electric oven model EW93 cuts main oven off?? why is this
Error code F08 is indicating that the heater relay is not being activated.
You need to check all the connections on the module, the pressure switch, and the heater element.
Mar 18, 2011 | Hotpoint Ovens
We have a westinghouse wall oven PON783 and the error of F08 comes up on it regularly not allowing us to use it. It now turns on & off by itself and personally i reakon its dangerous. What needs to be...
Hi Paulahogan_1, We have had the same F08 error code with our Westinghouse oven. The repairman said its because of two holes drilled in the upper casing of the oven which allow steam to get through to the motherboard - messing with the thermostat I think. The quick fix was pulling out the oven unit by undoing two screws, then undoing two more screws to lift up the motherboard, and filling the two holes with silicone. However, the steam coming through over the last year or so has caused some corrosion of the motherboard, so they're going to replace that given that the oven's still under warranty. Sounds like your oven might have the same problem, but may have suffered more corrosion over time, thereby messing up the controls? Good luck! Hopefully you've already had it fixed by now :)
Jan 23, 2011 | Ovens
ERROR MESSAGE F 08 SHOWING ON WHIRLPOOL OVEN AK2456/1X
Jul 17, 2010 | Whirlpool AKZ159IX Oven
Kitchen Ranges Logo
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
