Question about GT Chucker 3.0
Crank arm keeps falling of my road master - GT Chucker 3.0
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 131 Answers
Posted on Jun 03, 2015
My Huffy Rock Creeks left crank is really loose. Looks like its missing a spacer or something. Where do i get one?
this is the side with out the chain ring, it should use a Allen wrench or socket wrench. if this is a mountain bike or road bike a crank arm it usually takes a crank breaker tool to remove arms so if it is loose it sounds like it should be replaced. anyway if it does come off, clean it with any cleaning solution and put grease on the bottom bracket<if you don't have grease you can use Crisco or petroleum jelly> put crank arm back on and then tighten bolt back. this is for a three peace crank, if it is a one peace then its a matter of tightening bolts.
Jan 22, 2013 | Cycling
Tip
How to replace a chain with master link on a Schwinn Airdyne
Airdyne Chain Replacement with Master link
This video will demonstrate how to replace the chain with master link on a Schwinn Airdyne.
  • First remove the cotter pin and clevis pin from the user's right handlebar. Then lower the connecting arm and handlebar.
Caution: be sure to hold the handlebar as it will come loose after removal of the above parts.
  • Remove the connecting arm and pedal and crank arm by removing the wedge pin. To simplify this process loosen the nut and tap on it with a small hammer until the pin is loosened.
  • Remove the nut, wedge pin, crank arm and connecting arm.
  • Next remove the chain guard; there are three screws attaching it as shown in the video.
  • Remove the chain by locating the master link. Remove the lock pin and the cover, and then disconnect the chain.
  • Place the new chain on the sprockets as shown in the video.
  • Install the master link, cover and lock.
  • Re-install the chain guard and attaching screws.
  • Re-assemble the connecting arm to the handlebar and eccentric.
  • Be sure the brass bushing is installed in the front inner side of the connecting arm before installing the clevis pin and cotter pin.
  • Install the crank arm with pedal.
Be sure when completing this step that the crank arm is installed in the opposite position as the users left side crank arm.
  • Install the nut onto the wedge pin and tighten.
  • This completes the procedure.
Replacing Schwinn Airdyne Chain with Master Link
on May 23, 2016 | Schwinn Airdyne Exercise Bike
I have a 2000 mercury cougar. when i drive on a rough road or the road is wet the rear of the car slides to the right and i feel like the back end is going to fall off. this started after having the car...
I would check the rear sway bar links first.This is what keeps the car from going all over when turning and on bumpy roads.This is not an expensive fix.The control arms are a lot more.
Dec 23, 2009 | 2000 Mercury Cougar
The crank arm is stripped on the left side of the bike
Yes, the crank-arm could be replaced.
1.You would need to remove the flat nut holding the crank to the frame. And then take out the bearing.
2. A special open-ended wrench is required to remove this nut. Please visit your local bicycle shop for a new crank-arm, and the required tools, also.
3. Put in new crank-arm and its bearing.
4. Grease the bearing.
5. Tighten nut.
6. Give it a test ride.
Dec 10, 2009 | Schwinn Mesa Gs Mountain Bike
GE dishwasher arm keeps falling off. what is the
you should replace 3 parts in diagram,these are the upper spray are,the bearing,and the holding screw the #s are AP3191593/AP3794248/AP3425295 they coincide with the above parts and are all G.E. part numbers
Sep 10, 2009 | GE Tritonr XL GSD6260JCC Dishwasher
Rod dropsfrom master cyc to petal
Not a good thing. Is there a pedal arm stop missing? Is the master cylinder fully returning?
May 18, 2009 | 1989 GMC Sierra
Bike pedal arm keeps falling off as i pedal.
You need a new crank arm. If you ride with the nut loosened what happens is the square part of the bottom bracket shaft wears the hole out in the aluminum crank and it no longer fits snugly no matter how much you tighten it down.
Mar 03, 2009 | Cycling
1996 ford ranger pickup-splash wiper motor replacement
YOUR VENT COVER SHOULD COME RIGHT OFF GIVING YOU ACESS TO THE WIPER MOTOR AND THE CLIP AND NUT THE CLIP IS VERY TRICKY TO PUT BACK ON BUT WITH COVER OFF YOU SHOULD NOT LOOSE THE CLIP IT WILL JUST FALL IN CAVITY UNDER NEATH WIPER ARM ASSEMBLY GOOD LUCK
Oct 22, 2008 | 1997 Ford Ranger SuperCab
Top spinner arm of dishwasher keeps falling off
did you solve this. we have the same problem. the piece that the arm is connected to is slightly broken. I don't want to pay for a service call. let me know what you did.
Sep 07, 2008 | Dishwashers
GT Chucker 3.0 Logo
65 people viewed this question
Top GT Cycling Experts
tomar33
ray gallant
David Payne
David Payne
Are you a GT Cycling Expert? Answer questions, earn points and help others
