Question about LG Home Theatre System 51ch Amp Dvd Cd Player Sub Woofer LHT854 Electr
Sata unplug lg
I can still use the system for everything but DVD watching it says SATA unplug. how do i fix this???
marked
  • 6487 Answers
SOURCE: LG GGC-H20L DVD-RAM Burner won't read any type of disks!
If you have a CD cleaner try running that to that drive because this can be cause by some dirt inside the unit..
Hope that helps....
Posted on Aug 01, 2008
bharrie
  • 158 Answers
SOURCE: pc get shut down when inserted cd
This may be because the signals are getting lost. reseat the cables in the dvd drive and the motherboard.
Posted on Jan 13, 2009
  • 111 Answers
SOURCE: I can't get my computer to recognize my LG GGC-h20l Multi drive
check the jumper for the correct master/slave setting book.png
Posted on Mar 21, 2009
  • 1481 Answers
SOURCE: LG GH22 LS50 (Sata Dvd Writer) Will not write dvd discs
What software do u use to write DVDs on both PCs...
if they are different then that may be the issue....
dont spoil the DVDs....
try DVD RW disks...that way you can erase them later...
i too have the same DVD writer, not had any issue in either XP or Win7....i have dual boot and have made many movie DVDs using both OS...i use Nero and Power2Go of LG(the install disk that came with the LG DVD writer has this great software...."LG Power tool")
try this tool...it should work...
the inbuilt DVD creator in Win7 has some issues with DVD creation....due to non compatibility of graphics card and display drivers (WDDM)....+ you may not have the correct codec required to burn DVDs.....
get the FFDSHOW codec from google.... and install it...shutdown and restart and then try...
let me have a feedback pls...
reg
Posted on May 04, 2010
bronk50
  • 27725 Answers
SOURCE: LG GH22NS50 22X DVDRW SATA
click start control panel,administrive tools,computer management,device manager scroll to cd/dvd rom drives right click properties then properties again then tick enable cd digital cd audio for this cd rom device or scroll to dvd regions select the no _ for your specific area or if this fails to fix the problem
make sure that the dvd burner is getting enough power test all leads that are attached to the dvd burner including electical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or
your drivers may have been corrupted or you might have a virus run your antivrus program
you might have to physically unplug the leads for this cd/dvd burner then plug them back in or
you might have to uninstall then reinstall your DVD/CD or uninstall the driver then reinstall for this device
click start control panel administrive tools,computer management,device manager scroll down cd dvd rom drives right click you can you can update driver,roll back driver,or
select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall
if this does not fix the problem it might be a registry problem
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
if these fail to fix the problem
It could be a problem withthe lens, you should try cleaning the lens, it's already gone bad there is no harm in trying If you take a little risk can solve . follow the instruction: Don't panic its very simply. 1. When running your pc , open the drawer.> 2. switch off the acpower 3. remove powercable & sata or pata cable 4. remove all the screw from the back side 5. press clip to open the font panel 6. reverse the cd/dvd rw 7. just remove the cover 8. clean the optical lance 9. use a little( not much )oil place on two steel shaft 10.cover all the equipment 11.now you can fit to your pc Ifit does the same problem please change the cd/dvd rw because the lance has defected..
hope this helps
dont forget to vote
Posted on Feb 11, 2011
Is a ide a hard drive
You should check what kind of hard drive is using your computer. If it has less then 5 years probably hard drives are sata.
watch this tutorial
Instructions on USB To SATA IDE Adapters Cables
How to connect SATA devices in PATA IDE only PC system
Modding Guide Inline SATA Connectors
How to connect an IDE drive to SATA motherboard
Jul 22, 2015 | Hard Computers & Internet
DVD SATA not boot up
is it possible that cable came unplugged. If it is a new drive on a older system, it is possible that the sata port has been disabled in bios. Some oems only enable the ports that they are using.
Jun 18, 2012 | LG Electronics GH24NS90B 24x DVD Burner
Change my gx620 motherboard with ide connector for dvd rom to a 745 motherboard which has sata connection for dvd rom so i purchased a sata dvd rom and sata cable plugged everything in but the dvd rom wont...
With sata there are two cables, just like ide. One is the power and the other is for data. The data cable goes from the device to the motherboard. The power comes from the power supply. If your power supply does not have a sata connection you can purchase an adapter that will turn an available 4pin Molex into a sata connection.
http://www.ebay.com/sch/i.html?_nkw=ide+to+sata+adapter&_sacat=3667&_odkw=ide+to+sata+adapter&_osacat=42017&_trksid=p3286.c0.m270.l1313
Sep 11, 2011 | DELL 8X Serial ATA Slimline DVD-ROM Drive...
Reads DVD's but fails to burn
do a system restore from the date when you remembered you're pc was not having that kind of problem. start menu >> all programs >> accessories >> system tools >> system restore.
Mar 29, 2010 | LG GH22NS50 22X DVDRW SATA Drive OEM...
Dageezer sdays the LG GH22 dvd writer is a sata
You can refer to the following user manual , for the drive installation
http://support.dell.com/support/edocs/systems/dim3100/en/sm/parts0.htm#wp1244168
Thanks for using Fixya
proton
Nov 08, 2009 | Dell Dimension 3100 PC Desktop
I would like to replace with a blue ray from LG
if it is a desktop this will be an easy change out, make sure to match it up if your old dvd drive is ide you will need an ide blueray if its sata you will need a sata blueray. but as far as i know they only have sata type bluray drives. eitherway open the case remove the screws holding the drive and swap them out. there will be the data cable (sata) and the power cable.
Make sure the pc if off and unplugged when you attempt this. afterwards if any cd's came with the drive you might need to install the drivers.
Sep 09, 2009 | CenDyne (VBT522452X) Burner
A new sata LG dvd room,it work correctly,but i can't boot from it
First make sure that the DVD drive is the only drive listed to be booted from. Make it the first and only drive. Unfortunately most motherboards have an issue with booting from a SATA DVD drive. Secondly turn off Sata RAID if you have it. If this doesn't work then your motherboard isn't capable. It is too old and from what I can tell from the manual it is running SATA 986p, which is only 150mp/s thats not even Sata 1.5. Early Sata controllers couldn't do installations of OSs at all.
Apr 18, 2009 | MSI 661FM3-V SIS661FX LGA775 2DDR 400 2...
Can't get sata connection to work on new blu-ray rom
Oilers5, let's check a few basics first. Double check your dvd's data & power connections first. Everything good? Next, you need to get into your bios. Your blu-ray is connected to the SATA controller on the motherboard. Though I do not doupt the device manager your bios must see the device before windows will. At the main menue in your bios the DVD player should be listed (depending on model # of board) at the main menue. Than make sure the SATA controller is enabled, you'll find this in advanced menue. This is where you'll need your manual. If the dvd is the only SATA connected to the system you should have the option to use the SATA & not the RAID. If you have SATA hard drives connected & your dvd ends up on the RAID end you still should have the option to set the RAID to IDE. This way you will not need to run the RAID software. Once you get the bios adjusted windows should see the blu-ray as a SATA dvd player.
Oilers5 if what I have listed has not helped or fixed your problem could you post back with your model no# of the motherboard. Mfg's name ex; (dell, HP...). Than I can download your manual & check what settings need to be adjusted. Is this the only SATA device your trying to get to run? Is your current hard drive a SATA or IDE? How many?
Thanks Oilers5. I look forward to your next post.
Mar 01, 2008 | Computers & Internet
LG Home Theatre System 51ch Amp Dvd Cd Player Sub Woofer LHT854 Electr Logo
Computer Repairing
Computer Repairing
