Question about Apple iMac Computers & Internet
Previous shutdown cause 128 - iMac Apple Computers & Internet
    Top Expert:
  • Apple Master
  • 14,162 Answers
Posted on Feb 15, 2016
Shutdown problem?
You can take this issue to HP Customer Care or register your complaint for this tablet at Akosha to get it resolved.
Mar 17, 2015 | HP ElitePad 1000 G2 128 GB Net-tablet PC -...
Why is it that my PC (desktop) encountered suddenly shutdown? WINDOWS HAS RECOVERED UNEXPECTED SHUTDOWN Problem signature: Problem Event Name: BlueScreen OS Version: 6.1.7601.2.1.0.256.48 L
You say Windows, but not which version. Regardless, the "blue screen of d??th" is a mighty frustrating issue. There are ways that can help isolate the cause, but they are complex and require additional software. The two things that most often cause crashes are intermittent hardware faults and defective or incompatible drivers. Check to see if you have recently updated and of the component drivers. If so, use the "rollback" feature to go back to the previous driver and see if that helps. Unfortunately, often the only way to solve these problems is to reload the OS. If you can still access your system, now is a good time to back up all your data that you don't want to lose in case the system crashes hard and you need to reformat and reload.
Dec 31, 2014 | Computers & Internet
Previous shutdown 128
A negative shutdown code may be from a hardware problem. (The codes are not publicly documented.)
Please, backup your system and important data before doing anything.
It could be from heat buildup, if your vents look clogged with dust, turn off your computer, then, gently vacuum or blow out any dust or other obstructions from the vents on your computer.
If you have an Intel based Mac, try this:
Intel based Macs Resetting the System Management Controller SMC
If this doesn't work, please consult an Apple Genius Bar:
Apple Retail Store Genius Bar
May 09, 2014 | Apple Mac OS X
How to print auditron report (copy) from workcentre pro 128? Need step by step instructions- have no manual
Printing Service Reports
1. To access Service reports, follow the Entering UI Diagnostics procedure.
2. After entering the Access Number, press the Machine Status button on the Control
Panel.
3. Select the Billing Meter/Print Reports tab on the display.
4. Press the Print Reports/List button.
5. Press the CE button.
6. The following reports can be printed.
• Debug Log Report
• HFSI Report
• Jam Report
• Shutdown Report
• Failure Report
• Protocol Monitor Report
7. Select the required report and press the Start button. The selected report will be printed.
Jun 11, 2010 | Xerox WorkCentre Pro 123/128 Printer
Computer has lots of unexpected shutdowns.
it might be caused by virus, windows gone corrupt, needs new installtion with an updated virus cleaner.
Sep 26, 2009 | Microsoft Windows XP Professional for PC
I have a Mac OSX model 5521 DHHS Code D8 G4 128 MD 12 GB operating system which was previously owned. I do not have the operating boot discs nor do I have the password to get into the system. What can I...
1. Reboot
2. Hold apple + s down after you hear the chime.
3. When you get text prompt enter in these terminal commands to create a brand new admin account (hitting return after each line):
* mount -uw /
* rm /var/db/.AppleSetupDone
* shutdown -h now
4. After rebooting you should have a brand new admin account.
5. Change the password on your old account while logged in as your new Admin account, then log back in as yourself and delete your new Admin account."
Sep 12, 2009 | Apple Computers & Internet
System in hanging
try to replace your RAM
Jan 13, 2009 | Intel Motherboard
Please help need to watch tv
Well this gives you someplace to start!
Symptom: NO POWER
Cause: DEFECTIVE I912
Symptom: SHUTDOWN
Cause: Q777,I901
Symptom: SHUTDOWN
Cause: E994,D724
Symptom: SHUTDOWN
Cause: DEFECTIVE I401
Symptom: SHUTDOWN
Cause: DEFECTIVE I601
Symptom: SHUTDOWN
Cause: DEFECTIVE C715
Symptom: SHUTDOWN/OPEN E995,E996
Cause: DEFECTIVE T702
Jan 29, 2008 | Hitachi 50SBX70B 50" Rear Projection...
Abnormal Shutdown of windows 2003 standard
y cuse its sharing isssas to 1st off way to maby boots 2 max os on hard drive unless u want to fail soon do all your updates
Jan 25, 2008 | Microsoft Windows Server Standard 2003 for...
Power problem
A common failure in these units is Q401, Toshiba p/n# Bz510004 is a 2SA1624 (HV amplifier) which finally fails due to a resistor R408 Toshiba p/n# Bz210285 a .47 ohm/1w metal oxide having changed in value and at last opening...
This isn't an expensive repair for a qualified shop - but I would suggest not continuing to test your shutdown circuit. What's happening is that HV (high Voltage) is builds beyond tolerances and the shutdown circuit turns your unit off to keep from causing any severe damage. If it failed you could likely burn out the SMPS or cause some substantial damage..
Good Luck!
Bill
Dec 01, 2007 | Toshiba MD20F51 20 in. TV/DVD Combo
Computers & Internet Logo
222 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
