Question about Apple Mac OS X
Previous shutdown 128 - Apple Mac OS X
    Filmmaker:
    Uploaded 5 video answers.
  • 17 Answers
A negative shutdown code may be from a hardware problem. (The codes are not publicly documented.)
Please, backup your system and important data before doing anything.
It could be from heat buildup, if your vents look clogged with dust, turn off your computer, then, gently vacuum or blow out any dust or other obstructions from the vents on your computer.
If you have an Intel based Mac, try this:
Intel based Macs Resetting the System Management Controller SMC
If this doesn't work, please consult an Apple Genius Bar:
Apple Retail Store Genius Bar
Posted on Feb 24, 2015
Shutdown problem?
You can take this issue to HP Customer Care or register your complaint for this tablet at Akosha to get it resolved.
Mar 17, 2015 | HP ElitePad 1000 G2 128 GB Net-tablet PC -...
Standbylightblinks7timestvwontturnon
  1. Seven blinks - High voltage shutdown. The high voltage has exceeded 33k and the unit goes immediately into safety shutdown. Check power supply regulation and horizontal circuits. If you wish to get more details, http://electronicshelponline.blogspot.com/ Pull up previous posts, either by type in the Brand name to your set in its search box, or view it in Mosaic / Timeslide / Flipcard option.
Aug 03, 2013 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Nforce4-a939 board ,my system shows single channel 64 bit but on perchasing it was dual channel 128 bit how can i fix it......
The 128-bit mode is achieved by putting _matching_ sticks of RAM in the RAM-slots. Non-matching RAM will run as "single-channel" (64-bit) mode.
Matching RAM must have the _same_ amount of RAM per stick,
and the same internal "timing" parameters (look closely at the RAM for strings like 3-2-2 or 2-2-2-2).
If you have exactly 2 RAM slots on the motherboard, matching RAM will always run in "dual" mode.
If you have matching RAM, and you have 4 RAM slots, put one stick of RAM in slot #1, and one in slot #2, and leave #3 and #4 empty. Start it up, to see if it is using "dual" mode.
If not, shutdown, power-off, and move the RAM from slot #2 to #3, and start it again. This time, it will run in "dual" mode.
Jul 21, 2010 | EliteGroup NFORCE4-A939 (NFORCE4A93910)...
How to print auditron report (copy) from workcentre pro 128? Need step by step instructions- have no manual
Printing Service Reports
1. To access Service reports, follow the Entering UI Diagnostics procedure.
2. After entering the Access Number, press the Machine Status button on the Control
Panel.
3. Select the Billing Meter/Print Reports tab on the display.
4. Press the Print Reports/List button.
5. Press the CE button.
6. The following reports can be printed.
• Debug Log Report
• HFSI Report
• Jam Report
• Shutdown Report
• Failure Report
• Protocol Monitor Report
7. Select the required report and press the Start button. The selected report will be printed.
Jun 11, 2010 | Xerox WorkCentre Pro 123/128 Printer
I have a Mac OSX model 5521 DHHS Code D8 G4 128 MD 12 GB operating system which was previously owned. I do not have the operating boot discs nor do I have the password to get into the system. What can I...
1. Reboot
2. Hold apple + s down after you hear the chime.
3. When you get text prompt enter in these terminal commands to create a brand new admin account (hitting return after each line):
* mount -uw /
* rm /var/db/.AppleSetupDone
* shutdown -h now
4. After rebooting you should have a brand new admin account.
5. Change the password on your old account while logged in as your new Admin account, then log back in as yourself and delete your new Admin account."
Sep 12, 2009 | Apple Computers & Internet
System in hanging
try to replace your RAM
Jan 13, 2009 | Intel Motherboard
The server shutdown approxmatly every day
if the log says that the shutdown was unexpected, then I'd suspect a power outage at that time. If you're using a managed PDU, check to see if that outlet (or the whole pdu) is set to power cycle. If you have more then one power supply, I'd recommend plugging them into different pdu circuits. If you're pluged in to a UPS, suspect that the UPS is cycling and that there's no UPS management service running. If you're plugged into (yikes) the wall, suspect building power.
Mar 25, 2008 | Dell PowerEdge 1800 Server
Apple Mac OS X   Logo
87 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
