Question about Bosch Drills
Why bosch 11240 no hummer
No hummer
3 Suggested Answers
puertobori
  • 7733 Answers
SOURCE: How to replace brushes on a Bosch 11240 Hammer
eReplacementParts.com : Power Tool Parts and Tool Repair
Posted on Nov 02, 2010
  • 4 Answers
SOURCE: I have a bosch 11240 and the tool holder will not
"CHUCK" is full of dust, clean with a good cleaner lubricant, white grease before using again
Posted on Nov 07, 2010
Bosch sds oil the kit came with 50 ml do I need more
No its a little white plastic bottle between 45 and 50 ml comes with the consumables kit by some type of drills , for new readers of this old question be aware and pay attention if you service this kind of machines there is on the manual a great problem there is needed an extra ring of pos 102 the ring between gridring pos 47 and ring 51 sometimes it is delivered with 2 rings 102 and sometimes not but its fitted perfect its running smooth for longer time a gap must between 0.08 and 0.22 mm tolerance because 1 ring is wrong look also on the drawing of the gbh4-32dfr there is again a new and wrong positioning of this 2 rings pos 102 the 2 rings are not in that drawing between the pos 47 and 51 but there are 2 rings and in your machine 11240 you should have also 2 rings and thats correct if its only one then order a ring extra for doing a good service job
Apr 23, 2014 | Bosch 1 916 SDS Max Rotary Hammer Drill...
How to change brushes on bosch11227e rotary hammer
Disconnect the power cord from power supply first---ON most electric machines the brushes are under a small threaded button on either side of the motor case near the end. They are plastic and when unscrewed will have a spring around a copper wire attached to the brush. Just pull out and push in the new units ensuring that any curve of the brush will fit around the armature. Retighten the plastic cap.
Jul 09, 2012 | Bosch 11240 1-9/16" SDS Max Combination...
Where can I find a 240v Bosch 11240 SDS Max Rotary Hammer drill that I can take and use in Ghana
You'll be hard pressed to find one that doesn't run on 110v. You might be able to look on ebay and buy something from the UK like this for example:
http://www.ebay.com/itm/Bosch-GBH4-32DFR-NEW-Multidrill-4Kg-Rotary-Hammer-With-Accessories-240V-/160648807099?pt=UK_Home_Garden_PowerTools_SM&hash=item25676a42bb
Or you could just get a power adapter. Make sure they will work for the amount of amps that the tool will be pulling.
Mar 20, 2012 | Bosch 1 916 SDS Max Rotary Hammer Drill...
I have a bosch hamer drill 11241 and i am looking for a repair kits or some parts. becouse the hamer is not working. the drill works ok i live in toronto canada
The kit you are looking for is what Bosch calls a service pak the P/N 1617000430. It comes with all the o-rings, brushes and oil to do a complete overhaul. Go to Boschtool.com and look under "find a service center" then find one in your area.
Jan 09, 2011 | Bosch 11240 1-9/16" SDS Max Combination...
I have a bosch 11240 and the tool holder will not hold the tool, is there an easy fix
Oct 19, 2010 | Bosch 11240 1-9/16" SDS Max Combination...
No hammer function
if the tool still runs and you have inserted the proper bit, what I would try first is jamming the bit into the concrete to see if the striker is stuck and if still no hammer it would need to be taken apart and rebuilt with all new o rings and seals. if you try this yourself make sure you buy the small bottle of oil and some lube the the seals.
Sep 23, 2010 | Bosch 11240 1-9/16" SDS Max Combination...
Broken Connecting rod in Bosch hummer GSH 11 E
you can go to Boschtools.com and download a parts breakdown for this tool with the explosion showing the assembly. Let me know if you need more assistance.
Jan 02, 2010 | Bosch Hammering
Programmin my remote
Direct TV Remote Codes 506 or 127 Direct TV (Remote Model RC-64RB) Remote Codes 11144, 11240, 11331, or 11610 Direct TV Remote Codes 506 or 127 Direct TV (Remote Model RC-64RB) Remote Codes 11144, 11240, 11331, or 11610 Direct TV Remote Codes 506 or 127 Direct TV (Remote Model RC-64RB) Remote Codes 11144, 11240, 11331, or 11610 You could try the one below..
I know the new HD boxes and DVR HD Boxes have the new remotes and they included Olevia on it and it works with the new models of Olevia's
Jul 15, 2009 | Olevia LT32HVM 32 in. LCD Television
Drills Logo
29 people viewed this question
Top Bosch Drills Experts
Matt Olenzek
Matt Olenzek
woodzowl307
Are you a Bosch Drill Expert? Answer questions, earn points and help others
