Question about Brother SE-270D Computerized Sewing Machine
I have a brother SE 270-d. my only problem is that while embroidering, the bobbin thread is showing through the design on the top. I have tried adjusting the top thread tension but no matter how I adjust it, the bobbin thread still shows through. Any suggestions? Thank you!
Try making the material tighter in the hoop and check your bobbin to be sure it's a L (look at your instruction manual...it will show you which bobbin works and which does not. I say this because you have a tension problem...dont we all, Ha Ha!
Posted on Jun 23, 2009
Why is my bobbin thread is showing while embroidering
Your tension on top can be loosened. If this causes your stitch to be too loose then tighten your bobbin tension. Just think of the top and bottom tensions as a tug of war. They must be even to get the stitch in the middle of the material.
Jul 31, 2014 | Baby Lock Sewing Machines
I have a new Brother se400. Recently, when I am embroidering, the machine is picking up the white bobbin thread and either stitching the entire design in the bobbin thread or putting colored thread in the...
Sound s like top tension too high, bobbin tension too loose, or a needle issue - dull or incorrect one for the fabric.
Change the needle, check tensions.
Have you stabilised the fabric?
Oct 15, 2013 | Brother Sewing Machines
When emroidering, the thread from the bobbin is showing through on the top embroidered pattern. Any suggestions
Make sure to use bobbin thread for machine embroidery, it is heavier and pulls the top thread slightly to the back of the design.
You could loosen the tension or use a double layer of stabilizer.
Mar 05, 2010 | Brother PC8500D
I'm new to embroidering. I have BrotherSE-270 Disney. I have read through the manuel several times and am confused about the bobbin thread. Do I use tread specficaly for embrodering or will regular thread...
Your machine probably came with brother embroidery bobbin thread (one spool, white)...I used it until it was gone and did buy more embroidery bobbin thread at a regular superstore (it wasn't brother brand though)...however, I have since used regular thread and not had problems. HOWEVER, be sure it is good, quality thread - none of that $.50/spool stuff. That knots up and simply doesn't look good if it does work. Good luck!
Jul 08, 2009 | Brother SE-270D Computerized Sewing...
Bobbin thread comes out on top
You need to read the section of your manual that talks about thread tension. That occurs when your thread tension is off.
Dec 12, 2008 | Brother SE-270D Computerized Sewing...
Thread tangles under throat plate while embroidering
Could the little hook that is stuck over the bobbin area be the thread cutter? My thread cutter gets stuck there and I have to turn my machine off and then try to use the cutter to reset it to its "resting" position.
Nov 23, 2008 | Brother SE-270D Computerized Sewing...
Bobbins for se 270-d
I have the same problem! I also have the same problem with the ULT2001. The SE270D is a class A bobbin if I'm not mistaken. I've tried ALL kinds of bobbins and did not repair the problem. I stopped embroidering w/it for a while and only used it for sewing. It started embroidering ok for now. As far as oiling - I researched this last week when the motor locked up. You should be keeping the bobbin area (pop the plates under the sewing foot off) and make sure you don't have lint building up there. But the best I found, DON'T OIL. I couldn't find anything anywhere that would tell me where to put oil. What I did find was that you should take your machine in to be serviced about every 300-500 hours of use.
Aug 18, 2008 | Brother SE-270D Computerized Sewing...
Thread adjustment
Sounds like the bobbin tension is loose. Look at this website on their "repair" page where it explains how to adjust the bottom(bobbin) tension.
www.sewusa.com
Mar 05, 2008 | Brother SE-270D Computerized Sewing...
Top thread wraps around bobbin
Is it birdnesting under the bottom or it is actually getting tangled inside the bobbin case? I've had my machine for almost a year and don't think I've had your exact issue. Sometimes, when you do a stich over a already stitched portion, you may have a problem with the bobbin and I just generally stop and start it again. It is important that you use the correct needle and also use a good embroidery thread and stablizer. Another thing suggested is changing the needle after about every 5 designs. Also, check the bobbin case to make sure there's no fuzzies caught in it. I use "canned air" like you use on computer keyboards. I also only use 40 weight emboidery thread for the top and actual bobbin thread for the bottom. Other threads can really jam everything up. So it's been trial and error to find the right combinations. Good Luck!
Oct 30, 2007 | Brother SE-270D Computerized Sewing...
Bobbin Thread
I have had the same problem. I always just used the same color of bobbin thread as on the top. It is a pain to change inbetween each block, but the designs usually look perfect. I will have to try playing with the tension.
Sep 24, 2007 | Singer CE-200 Quantum Futura Computerized...
Brother SE-270D Computerized Sewing Machine Logo
183 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
