Question about Sport & Outdoor - Others
HAYWARD POOL PUMP IMPELLER REMOVAL? - Sport & Outdoor - Others
PartsCenter
  • 125 Answers
SOURCE: Jacuzzi magnum pool pump impeller broke
The impeller on the Magnum pump unthreads counter clockwise as do other impellers. There is a shaft of the motor that runs the length of the motor, on the back of the motor when you take the bell housing off you will see a small silver spot with a **** in it for a standard screwdriver. Put the biggest one in there you can and then grab the impeller and turn it counter clock wise and it should unthread. Sometimes they won't if it has been on there a number of years. You will need to break it off if it doesn't unthread. Then just purchase a new Impeller for the Jacuzzi Magnum Pump.
Rod
US Parts Center
Posted on Feb 24, 2009
  • 156 Answers
SOURCE: The pump only hums when plugged in. Any suggestions?
It sounds like the impellor is locked. Take this part off and then see if the pump is turning but before you do, some of them have a big screw driver slot in the shaft. If it does, turn it to see if you can free the impellor. I have done this many times and they will continue to work for years after. They just get stuck from rust, etc. and also being frozen a little. Hope this helps.
Posted on Jul 06, 2009
  • 136 Answers
SOURCE: I have a hayward 2hp pool pump motor that hums but
your starter capastor has gone bad or got diconnected it`s look`s like round cylender 2 inch by 4 inch dimention`s or it could be an internal (inside the motor) depending how new the motor is
Posted on Nov 06, 2009
Testimonial: "Thank you very much for your help"
tinkerbill
  • 12 Answers
SOURCE: Need Intex Pump model #635 impeller
You know, I have made some amazing repairs on plastic items using nothing more than a soldiering iron! If you have the piece that broke off, you can carefully melt it back together. You can add more to the weld if you match the type of plastic but not too much or you imbalance it. In this case it looks like PVC. To repair it without the missing piece, form it out of epoxy putty, roughly shape it just before it sets up solid, & sand to finish.
Posted on Jan 02, 2010
  • 106 Answers
SOURCE: How to remove impeller on pool pump to replace seal?
First, separate motor and pump. Remove back cover of motor. Drive shaft of motor either has a slot on end for a large screwdriver or a flat on it for a wrench.(usually 7/16) Hold shaft and unscrew impeller.
Posted on Feb 21, 2010
Pool pump is a Hayward pressure is at 10 lbs It
Low PSI is usually the result of air in the system or debris in the impeller. (even a clogged pump basket). If you are sure all else is good, open the pump and make sure the impeller is clear.
Aug 05, 2013 | Pentair Mastertemp Heater
Hayward pool pumps
The impeller on this Hayward pump unthreads counter clockwise.
Take a big flat head screw driver and put it on the center shaft on the back of the motor to hold the shaft solid while you unthread the impeller.
Rod
US Parts Center
May 08, 2013 | Pool & Spa
How to remove impeller case from century centurion pump
take out screw to impeller backwards thread impeller unscrews normally
Sep 16, 2012 | AO Smith Pool Pump Motor Hayward Swimming...
I just put my pump together to start using again(hayward power flo lx pump xp1580pz2) & its running but not doing its job.
THERE MIGHT BE TRASH IN THE IMPELLER, THE PUMP NEEDS TO COME APART AND PICK THE RASH OUT OF THE IMPELLER
Sep 21, 2011 | Hayward Power Flo Lx 1 Hp Pool Pump Sp1580
The water pressure on my Hayward pump on the return is too powerful?
CHANGE OUT THE IMPELLER . HAVE THE HP AND TYPE OF PUMP YOU HAVE ,SAY A SUPER 2 OR A SUPER OR NORTHSTAR. OR BRING YOUR IMPELLER )SCREWS OFF( TO YOUR LOCAL POOL PUMP REPAIR GUY..SAY..The water pressure on my Hayward pump on the return is too powerful? I NEED A SMALLER IMPELLER THEN THIS ONE
Aug 21, 2010 | Pool & Spa
How to disassemble impeller on rs1000 hayward pump
OFF TO THE LEFT FOR REMOVAL OF A IMPELLER BUT SOME MAY HAVE A SCREW IN THE CENTER IT IS A LEFT HAND THREAD SO IT OFF TO THE RIGHT.. BRING IT TO YOUR LOCAL POOL PUMP MOTOR REPAIR GUY TO HAVE IT DONE RIGHT
Jun 29, 2010 | Hayward 1.5 Hp Northstar High Performance...
Hayward pump hums only
Replace your start capacitor ... before you do that ... is the hummng the motor withoug the impeller? Your impeller may be broken.
Jun 25, 2010 | Hayward Pool Products Hayward Power Flo LX...
How to get impeller off hayward power flo sp1525
Once you have the housing apart, 6 screws/nuts I believe, make sure you have the power completely shut off at the breaker. Remove the rear housing on the motor to expose the armature (shaft). Depending on the motor, you will need a 7/16" open end wrench to hold the shaft, be careful not to damage any components, you may have to remove the capacitor or switch to access the shaft. Once the shaft is being held, try to remove the impeller by turning counter-clockwise facing the impeller. If it will not move, you may have to use an impeller removal tool. c85eef7.gifMost pool supply places have them. Be sure to install a new shaft seal, its best to replace the seal anytime you mess with the impeller. Having a good shaft seal will save your motor bearings.
This video helps, although its not the same pump..
I hope this helps....
Sep 18, 2009 | Hayward Pool Products Hayward Power Flo LX...
How do you change a pump seal on a hayward 1hp pool pump
The seal is located behind the impeller. Once you remove the impeller it is fairly obvious how to replace it. Basically, unscrew everything, replace it and put it back together again. There is a decent diagram on page 11 of the Hayward owners manual found here if you need it. http://www.haywardnet.com/products/Manuals/pdfs/Manual113.pdf
May 13, 2009 | Hayward 3/4hp Super Pump Inground Pool...
Sport & Outdoor - Others Logo
13 people viewed this question
Top Sport & Outdoor - Others Experts
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
