Question about Brother DCP-7020 All-In-One Laser Printer
Why is my brother dcp7030 printing black lines on side, new toner cartridge?
  • 12 Answers
SOURCE: Brother Hl 5240 printer- toner light on
1) Turn off printer
2)Turn back on
3) Remove Drum and Toner.
4)Press Go for 1 second(it appears to do nothing)
5)Put Drum and Toner back in.
6)Press Go for 1 second(it appears to do nothing)
7)Close door.
Try that
Posted on Jul 05, 2008
rylee_smith
  • 8619 Answers
SOURCE: Brother 4070 Printer will not recognize new toner cartridge
Hi
Just cover the eyes (on both sides) that you can see in the bottom of the machine after removing the imaging cartrige with a small piece of electrical tape.
With printer switched on push the switch which is located inside the upper left side of printer (it is a small white switch) and then release it.
Also try resetting the gear, take the cartridge out. On the gear side take off 2 screws, the black gear on top right side, with a small spring underneath. Just take it off and reset it (rotate clockwise) so it is not at the stopping point.
Please do accept this solution and revert for further assistance.
Thanks
Rylee
Posted on Apr 20, 2009
komguy
  • 2306 Answers
SOURCE: Brother HL-2040 toner led stays on, won't print
There is a window on each end of the toner cartridge that you can cover with electrical tape and keep printing, it shines a light thru and when the toner is too low it says it's empty. The weight can be misleading.
Posted on Sep 02, 2009
Sebin
  • 712 Answers
SOURCE: black ink will not print. Colours ok
Get a syringe, remove the needle, remove the ink cartridge and use the syringe to blow air GENTLY through the hole the cartridge connects to. Make sure you have a cleaning cloth to remove ink dislodged from pipe connected at the print head, do this gently to remove any obstruction and there should not be too much mess and can easily be cleaned up.
Posted on Feb 04, 2010
  • 22 Answers
SOURCE: Toner light still on with new toner
Is the printer still asking for a new toner..?
If it is the there is a gear that can be reset on the toner cartridge2_bing.gif to tell the machine its a new toner cartridge. This is normally done by an engineer, but is quite easy to do if you know how. And I do :0
Posted on Mar 07, 2010
My Brother MFC-7420 Printer always prints black lines and splotches down the left side of my paper. This happens whether I'm scanning or printing from my PC. When I looked at my drum, it appears a
If you are seeing vertical streaks/black lines your primary corona wire is dirty and or the fax scanner may be dirty.
1)To clean the corona wire you take the drum unit and toner cartridge and place it on disposable paper to avoid spilling.
2) Clean the primary corona wire inside the drum unit by sliding the blue tab from right to left several times.
3) Return the blue tab and snap it into the home position.
4) Reinstall the drum unit and toner cartridge.
5) Close the front cover.
Caution: if you do not return the blue tab to the home position it may repeat the black lines.
Nov 29, 2012 | Brother MFC 7420 All-In-One Laser Printer
Bad toner cartridge? Wide white line down center of print
If you have a Brother color mfc, it sure sounds like a defective cartridge.
Brother machines do not perform well with generic or rebuilt cartridges and really have problems when you mix generic with Brother toners. It also voids any remaining warranty. Send it back. Good Luck.
Aug 07, 2012 | Office Equipment & Supplies
White lines when printing
Usualy white lines are a signal for you that is time to replace a toner cartirdge.
Your machine may inform you that you need to replace a toner cartridge, but sometimes the toner levels are low and the machine doesn't indicate that.
Another thing that you may try is to clean all toner cartridges using each corona wire.
If you need to replace your toner cartridge check this easy and helpful way to replace toner cartridge.
May 16, 2012 | Brother MFC-9320CW Color Laser Printer -...
I have a printer of Brother quality DCP7030..the toner life end appears on screen.but i have already refill the toner
Refilling printer toners/cartridges never show as full on the screens. Only if you buy a new toner, that will show a full cartridge.
Aug 26, 2011 | Computers & Internet
My mfc-9440cn prints a black line on the rigth side do you know what could that be? maybe needs new drum?
Hi there !
If you are self refilling the toner cartridge, the roller drum can be damage due to wear and tear. I need to replace new toner cartridge other i will getting wider and wider on both left and right of the paper.
Jan 13, 2011 | Brother MFC-9440CN Laser Printer
Black lines when printing brother 9320cw
Vertical black lines means the printer requires maintenance or a new drum. Horizontal lines means a circuit board with problems.
I do recommend maintenance every 6 months at least.
I hope this helps.
Nov 23, 2010 | Brother MFC9320CW All-In-One Printer
Replace cartridge error
i have brohter dcp7030 laser printer .earlier toner is empty si i refiiled the toner but toner giving me not printout.printer is display the message of toner end so plase me suggest the reset of this ptinter
Oct 28, 2010 | Brother DCP-7030 Digital All-in-One Laser...
Printed sheets come out with blackish/greyish lines on the right side
Use follow these cleaning steps for your printer:
1. Open the front cover of the printer and remove the drum/toner unit.
2. Gently wipe the scanner window with a soft dry cloth. The scanner
window is located on the roof of the inside of the printer.
3. On the top of the drum unit, locate the blue tab on the left side.
Slide it back and forth across the drum about 30 times.
4. Remove the toner cartridge (TN430 or TN460) from the drum unit
(DR400). To remove the toner from the drum: hold down the blue lever on the right side of the drum (DR400) and lift the toner (TN430 or TN460) off of the drum unit.
5. Inside the drum unit (DR400) there is a green roller. Wipe the green
drum roller with a dry tissue (i.e. Kleenex). You may turn this roller
by moving the gears on the far left side.
6. If the pages area gray pages or have gray vertical lines, install a
brand new toner cartridge. If pages have dots, spots, smudges or
horizontal lines, install a brand new drum unit.
OR
If you are still experiencing gray pages or gray vertical lines,
please install a brand new toner cartridge (TN430 or TN460).
Brother strongly recommends that customers do not use generic drum unitsand/or toner cartridges, or refill their Brother toner cartridge. Each Brother laser printer is designed to work at pre-set temperatures that are matched exactly to each of our individual toner formulations. Each individual component is designed to work with the other to ensure quality and reliability. Using non-Brother supplies may affect the hardware performance, print quality and machine reliability.
The Brotherlimited warranty does not apply to any problem that is caused by the useof unauthorized third party drum units, toner cartridges or toner.
If I have helped please rate my post...I will always do my best to help
Sep 11, 2009 | Brother HL 1230 Laser Printer
Received "Low Toner" message. Replaced toner with new Brother cartridge still have "low Toner" meaasge and [printer will not print.
Please check if you removed the Plastic Tapes which is placed in the side lock of the new Toner Cartridge.
Apr 24, 2009 | Office Equipment & Supplies
Brother 2140 toner light on, won't even try to print.
To get every bit of toner powder out of the cartridge, first remove the toner unit from the drum assembly. Second, find the little circular window on the right-side of the toner cartridge. Third, place a piece of black electrical tape over the clear window, cannot be clear tape. Fourth, re-install the toner cartridge into the drum assembly. Last, put the complete unit back into your printer. This worked for me.
Apr 05, 2009 | Brother HL 2140 Laser Printer
Brother DCP-7020 All-In-One Laser Printer Logo
47 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
