Question about Kenmore 600 7965 Dryer
How can I replace the heater element on a Kenmore 600 7965 Dryer?
catriver
  • 878 Answers
SOURCE: replacing the heating element Kenmore dryer 110 64892
nestor, on the posted model, you want to drop the lower front panel. Take a puddy knife and push in on the clips on each side and it will pull off. Kill the power to the dryer. On the right you will see the heater housing. The housing will have a front deflector. You can remove that deflector by removing the screw on the bottom or simply just bend it down out of the way. Remove the 2 wires on the left that attach to the element itself. On the left side of the housing there will be a quarter inch screw that holds the element in place. Use a small socket set to get it off. Now the element will pull right out of the housing. Sometimes they are difficult to pull out but it will come out. Did you ohm out that element to make sure that was the culprit? Catriver.
Posted on Dec 09, 2007
SOURCE: changing heater element in kenmore dryer (110.60702990)
the orange wire is for the timer if you do not connect it then the cycles wont work.the timed cycle will but not the other cycles.
Posted on Nov 13, 2008
SOURCE: where is heaing element located on kenmore dryer
http://www.davesrepair.com/DIYhelp/DIYreplacingWPLdryels.htm
Posted on Mar 30, 2009
jumptrout51
  • 3361 Answers
SOURCE: replace heater element
Unplug the dryer.
Open the lower front panel.Use a putty knife to push in thclips on top of the lower front panel. They are about 2 inches in from each side.
Lower the panel. The heater will be in front of you on the bottom right.
Are you sure the heater is bad?
It may be another part.
Posted on Apr 12, 2009
jsrock516
  • 5911 Answers
SOURCE: How do you replace the heating element on kenmore
Have you confirmed the heating element is bad? There's more to the dryer heating circuits that can cause a no heat problem besides the heating element.
If your dryer runs, but does not heat, the following link explains how to troubleshoot an ELECTRIC dryer with a no heat problem:
http://www.fixya.com/support/r3576548-dryer_runs_but_does_not_heat
First, begin by unplugging the dryer and verifying the voltage at the wall receptacle. You should read 220-240VAC across the two Hot terminals (left and right slots). If the voltage is incorrect, check to make sure you don't have a breaker tripped. Some homes use 2 separate 120VAC breakers to provide power to the receptacle vice using one 240VAC breaker.
If the voltage IS correct, leave the dryer unplugged and remove the cover plate on the terminal block in the back of the dryer (this is where the power cord is installed). Plug the dryer back in and take a voltage reading across the two hot (RED and BLACK) wires at the terminal block. You should read 220-240VAC. If the voltage is good, you have an internal heating problem. If the voltage is bad at the terminal block, but good at the receptacle, you have a bad power cord.
NOTE: If the wires at the terminal block are not color coded, the outer two wires (left and right) are the hot leads. The center conductor is neutral or ground.
The reason a dryer will still run if the input voltage is incorrect, is because the drive motor only uses a portion of the 220 service. The motor runs off 110-120VAC, while the heating circuits require 220-240VAC. So, if you are missing 1/2 your input voltage due to a tripped breaker or bad power cord, your dryer may exhibit these symptoms.
If you determine the problem to be internal, the heating circuits will either be located in the rear of the dryer on the right hand, or under the dryer drum on the right hand side. Usually, an easy way to determine is by the location of the lint screen filter. If the filter is on top of the dryer, the heating circuits are in the back of the dryer. If the lint screen is in the door, the heating circuits are located under the dryer drum.
The Heating Element is located inside a heater box. The Thermal Cut-Out (TCO) will be located on the outside of the heater box on the end opposite the heating element terminals. The Hi-Limit Thermostat will be located adjacent to the heating element terminals.
If either the TCO or Hi-Limit Thermostat are determined to be bad, replace BOTH components at the same time. That is why these components are commonly sold as a set. Failure to do so may result in premature failure of any parts you replace.
Replacement parts (if required) can be found at the following websites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
The average cost of these components varies, so shop and compare.
Now...if you have determined the heating element is definitely bad, and this is a Kenmore Elite as the one you posted this question under, the following link explains how to access the heating element and replace it: http://www.fixya.com/support/r3677025-elite_duet_dryer_heating_element If you need further assistance, please post back with your complete model number (located on a nameplate around the door opening) and let me know. I hope you find this information helpful.
Posted on Jan 06, 2010
Where is the heating element for a Kenmore heavy duty 60 series soft heat large capacity?
How to Replace Your Electric Dryer's Heating Element
How to Replace Your Whirlpool, Kenmore, Roper, or Kitchenaid Electric Dryer's Heating Element. Here's a common job that many folks are afraid of, but it's ...
Whirlpool / Kenmore Dryer Heater and Thermostat Test ...
? 7:40
https://www.youtube.com/watch?v=KZY9CQ_CqvY
Sep 13, 2010 - Uploaded by Bill Newberry
Basic checks for a Whirlpool made dryer. ... Whirlpool & KenmoreDryer Repair - How To Diagnose No Heat ...
Whirlpool - Kenmore - Maytag Dryer Not Heating Repair ...
? 2:42
https://www.youtube.com/watch?v=i95okOr2rOI
Mar 1, 2011 - Uploaded by ApplianceAdvice
It will explain step by step instructions on how to test the thermostats, fuses, and heating element inside the ...
How To Fix Dryer With No Heat ' Dryer Repair - PartSelect
Dec 12, 2015 | Kenmore Dryers
How to replace heating element in kenmore elite dryer model 11065922400
FIRST UNPLUG dryer from wall then remove the back of dryer and you will see the square heater and two screws holding it in place,remove wires and replace heater and reconnect the wires.
Aug 30, 2014 | Kenmore Dryers
Kenmore dryer model # 110-60212990 heater element not working. replaced element, thermal fuse, thermal cutoff
Hello
Check high limit thermostat continuity. If ok ,Check for voltage at thermostat side of the heater element.If voltage present timer ok.Most likely centifugal switch at motor.Motor has to be running for element to work.
It's all fixable!
Jul 28, 2011 | Kenmore Dryers
How to find the heating element on the Kenmore 80 series... Model 67832794... trying to replace myself but can't figure where the heating element is located
remove the back of dryer,unplug,look to the right and you will see the heater box,the lower half is the heating coil,remove the 2 wires and 2 screws and pull the heater off,also you need to check the heater box fuse located on the upper left side fg heater box-mike
Feb 19, 2010 | Kenmore 63942 Dryer
Kenmore Dryer, heating element doesnt turn off
remove the back of dryer and remove the heating element from the heater box,check to see if the wires in the box are touching the heater box walls any where,this would make the element stay on all the time,also check the high temp thermostat on the left side bottom,this is the on off thermo for the heating element-mike
Feb 16, 2010 | Kenmore 63942 Dryer
Replace heater element
Unplug the dryer.
Apr 12, 2009 | Kenmore 63032 Electric Dryer
Changing heater element in kenmore dryer (110.60702990)
Nov 13, 2008 | Kenmore Dryers
Heating element
The model number you provided suggests that the lint screen is on top of the dryer, right? If so, the heating element can be accessed from behind the dryer by removing the rear panel. Of course, you should know this already since you stated you've already replaced the thermostat and fuse. The heating element is located on the right-hand side as you are looking at the dryer from the rear. There are TWO components on the heater housing. One is the high limit thermostat, one is a thermal cut-out. Are these the components you mentioned replacing? BOTH should read a short (0 ohms) when measuring resistance with the dryer turned off. If you haven't replaced both of them, double check to see if they are both good. The high limit thermostat will be located closest to the ceramic heater connection. The thermal cut-out will be mounted to the heater box. Perform a resistance check of the heating element as well. Measure across the leads of the heating element at the ceramic terminal connection. It should read between 8 - 13 ohms if good. If your readings prove that the heater is bad, it can be removed by using a 5/16" hex drive. The heating element should slide out the bottom of the heater box housing. Sometimes removing the heater box, and then removing the heating element is easier.
Your dryer is also equipped with an electronic cycle control board under the control panel that goes bad from time to time. This also may affect the dryer heating circuits. Inspect the small circuit board for any obvious signs of burned components.
I hope this information is helpful to you. If I'm wrong about your dryer configuration, please post back with comments, so I can give you proper instructions.
CAUTION: Make sure you UNPLUG the dryer prior to making any resistance checks. Dangerous voltages are still present with the dryer turned off.
PS I hope I'm not insulting your intelligence, here. As a rule, I tell everyone this information because some are not as savvy as others.
Feb 23, 2008 | Kenmore 63942 Dryer
Kenmore 600 7965 Dryer Logo
32 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
