Dayton 4b228d air compressor manual - Office Equipment & Supplies
2 Suggested Answers
  • 1388 Answers
SOURCE: Hi. I have a Dayton Air Compressor, operated by
I have a similar compressor from grainger. Same motor as yours with 10hp speedair compressor, however a newer model. The graninger number of my pump is 5z405. and can be seen at the link below:
http://www.grainger.com/Grainger/SPEEDAIRE-Two-Stage-5Z405
If your pump looks similar then contact grainger and ask them for info relating to your serial number. Every time I call grainger for info or parts, they ask for the grainger number of the complete unit. These pumps do not change much over the years so maybe the info above will be helpful. Good luck
Posted on Mar 29, 2011
How can I adjust the torque settings?
PDF]SD Compressor Service Guide - Sanden
www.sanden.com/productlibrary/manuals/sd_service_guide_rev_2.pdf
6.6.2 Suction Gas Condition. 6.6.3 Ambient ... Internal compressor pressure can be relieved by removing shipping caps ... Never leave PAG oil exposed to air for a prolonged time. Tightly ..... Place rotor pulley shaft protector (Puller set) over the exposed shaft. 4. ... Replace retaining nut and torque to specification. 1/2-20: 20- ...
Speedaire Air Compressors - About Air Compressors
www.about-air-compressors.com/speedaire.html
when i try to start my gas compressor it backfires why 5.5 speedaire by dayton, serial ... cant find cylinder head torque specs for 35w347 need the torque specs to properly break .... I also need to know how to change the oil on the 1z943b motor ...
[PDF]80 Gallon Industrial Air Compressor - Mi-T-M Corporation
Dec 08, 2015 | Air Tools & Compressors
How am I getting oil in the hoses?
Hello Aaron, It sounds as though the piston rings in the compressor pump are not seated in the cylinder. Could they be worn out from use?
Jul 01, 2015 | Dayton Wire Wheels Dayton 2VKY3 Evacuation...
What will cause my Kohler Command Pro 12.5 Engine on an air compressor to shut down after the tank fills instead of going to an idle. Carb is new.
Does this have the solenoid on the bottom of the carb? That is a automatic shut off device installed in the pot of the carb to shut off the gas if the carb is overflowing with gas. If the carb is new, is the solenoid? Also, is there a bleeder line for condernsation to the tank on the bottom of the air tank? If so, sometimes that is a problem. Too much water inside the air tank. I don't know if it would cause this problem though.
Sep 29, 2014 | Dayton Audio Dayton Speedaire Air...
I need Pressure Regulator for Speedaire 3Z355H
The pressure regulator does not have to be specific for your compressor. You just need to get the right line size and pressure range you are needing. You might be able to get one from Home Despot or Lowest, but I would look on Amazon. I am sure you can get it from Grainger, but you will pay a premium price. If you are on a budget, check Harbor Freight if you can.
Aug 27, 2012 | Dayton Audio Dayton Speedaire Air...
I need i shop manual for a dayton speedaire model 3z244d
The dayton brand is sold by Grainger.
Check for the manual at grainger.com they also have a cust. service number that maybe can help you...
heatman101
Sep 28, 2010 | Dayton Audio Dayton Speedaire Air...
Parts lists (i.e. rods, crankshaft, rings) for
Information about your unit can be faxed to you by calling the number below:
From the USA, please contact us at 1-800-323-0620
It may be easier however to look for the model number of the pump only as the 3z497 reference number is of the the complete unit. Look for model number or information on the pump itself and check that number at www.grainger.com. I believe that you have a two stage pump that may still be sold seperately. Good luck on your repair.
Jul 22, 2010 | Dayton Audio Dayton Speedaire Air...
The motor runs continuously and the pressure is low. What are the possible causes for this?
You haven't given any model number information, but typically on any air compressor if it won't build pressure, either you have a leak in your piping, tank, hose or the compressor cannot move the required cfm of air. Could be a valve problem or piston, relief valve? Do you hear any air leaking. There are som many different models from cheap throw away compressors to thousands of dollar models. HArd to say without more information
Jul 19, 2010 | Dayton Audio Dayton Speedaire Air...
jasbo
jasbo
