Model wf8802rpf comes up with error code tE2 when first starting up
SOURCE: how to remove sda cuck from hilti te2 110v drill
Manual for Hilti Te2 is here.
Per Page 11, "Pull the chuck release ring towards the front and remove
the chuck completely. When fitting the chuck, pull the
release ring towards the front and hold it in this position.
Push the chuck onto the guide tube as far as it will
go and release the ring. Rotate the chuck until it engages
and the ring snaps back into its original position |3|. The
TE-C interchangeable chuck or quick-release interchangeable
chuck may be tited to the TE 2-M with chuck
interface |2|."
If this helps, please vote. Thanks!
SOURCE: hilti te2-a both battery's won't charge
IF you live in the US you can send it into Hilti tool repair and let them evaluate your batteries. Or you can take it to any Hilti Center to be checked out. You can call1-800-879-8000 to locate the nearest Hilti Center to you or arrange to send into tool repair.
SOURCE: I have a thatcham TE2-1331/0305 I want to fit in
My 2005 Dodge Caravan head lights and dome lights stays on a little longer then the norm. Also the chime indicator that lets you know that you left the lights on or you left the keys in the ignition comes on as soon the door is open.I have had one battery go dead on me . Can't afford to be replacing batteries when they go dead on me! Can you help?
SOURCE: A part of my te2s side handle broke where can I find a new one
Try any tool retailer, parts for the TE10 haven't been made for a while. You should find that one of the side handles for current machines will fit.
