Question about Boating
How to install a evenrude outboard water pump
Where are the water exhaust ports located on a outboard marine motor
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,190 Answers
The exhaust ports start from the side of the engine block 2hp -90hp then v4 and v6 and v8 are between the v blocks ! from there they go down the leg unit , top rear of leg have an outlet for tickover then the main outlet is either through the prop or above it on small or old type engines !
Posted on Jun 06, 2014
2 Suggested Answers
alicantecoli
  • 22326 Answers
SOURCE: mercury outboard 3.5 motor stalls
not sure here as i normally answer car questions but if this engine is of the new generation and its all electronic then it has to be plugged in to locate the fault .My outboard was playing up like this with loss of power and the dealer wanted a small fortune to repair the pump which feed the fuel injection system so i took it apart and made a new valve for it out of a piece of fishing hook plastic wrapper and a bit of copper wire hook type thing i made and that was about 5 yrs ago and its still running fine
Posted on Apr 13, 2012
How do I winterized a 40hp evenrude 2stroke
There are videos all over YouTube that cover this subject quite nicely.
winterizing an outboard motor YouTube
Nov 15, 2014 | Boating
WHY WOULD A B LACK OILY DISCHARGE DRIP FROM THE EXHAUST PORT BEHIND THE PROP?
oil /fuel mixture has too much oil in it . What the engine doesn't burn it pukes the rest into the water from the exhaust.
May 31, 2014 | Boating
Evinrude troubleshooting
6hp evenrude blue/ white fishermen motor dark brown oil is coming out water out let hole, is it a lower unit seal by the water pump?
Jan 05, 2014 | Boating
I have a evinrude 28hp outboard which is not pumping water. drive shaft seems in place and impeller in good nick. have put hose at bottom of inlet pipe and water runs through motor and out outlet. water...
Check pump housing and plate for wear,make sure aluminium housing not corroded under plate. Suggest fitting electric drill to drive shaft and emerse lower unit in bucket of water.make sure drill doesn't get wet.is motor going into gear,maybe splines are rusted off in crankshaft,could also have holes in inner exhaust side plate
Sep 04, 2013 | Sierra International 18-4310 Marine...
Mercury 850 Thunderbolt outboard
call mercury don't think they had a place for water pressure hose in the 70s on there motor
Aug 30, 2013 | Boating
I have a 1973 Evenrude 50 hp outboard motor, when i turn the key nothing happens
it is either a wire broke or the the starter solionde is broken check with volt meter at starter + and - if it shows up voltage its the brushes in the starter motor
Jul 13, 2011 | Boating
Water does not come out of the port hole all of the time.
you might just have dirt in the water view port try a real smal drill bit BY HAND to clean the hole . if the morot doesn't run hot then you really don't have a problem
Apr 27, 2010 | Boating
Boating Logo
80 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
