Question about EliteGroup 741GX-M Motherboard
AMD sdc2200 w/741GX-M
I can only get the processor to run at 900Mhz...how do I get it to preform at it's peek?
  • OneRoundEye Nov 04, 2007
    The processor is an AMD Sempron SDC2200
  • 640 Answers
Go into the bios,and goto clock speed you can then boost the processor. however your processor will run hotter and could be damaged.
Posted on Nov 04, 2007
What CPUs can I update the system
You have a AMD Mobo, You can ONLY use AMD processors, A list can be found here: http://h18000.www1.hp.com/products/quickspecs/12605_div/12605_div.HTML BE ADVISED, if you haven't done a CPU upgrade before, do some research and crossreference with the Mobo Manufacturer's specs, keep in mind components work together. One component may not give the preformance you expect. That said, it's a easy upgrade along with extra Memory, 4GB for 32bit, more for 64bit, Faster,7200rpm's, HDD and another HDD is inexpensive and easy. Most can be found on Ebay for little money.
Dec 26, 2012 | HP Compaq dx2250 Business Desktop Computer...
Like to replace my processor which is AMD Duron 900MHz to Motherboard Gigabyte 7VM333M-RZ. Which current processors are compatible with this board? Please advise. I want a current fast processor.
Hi, As far as I can see, this motherboard is very old, and the faster processor you could get would be around 1.8 ghz, single core. Here's the list of supported processors:
http://www.cpu-upgrade.com/mb-Gigabyte/7VM333M-RZ.html
What I would suggest is that you buy a motherboard/cpu combo, then you could get a quad core with a recent motherboard for less than 150-200$. Of course you'd have to be willing to change your motherboard, but unfortunately, you're not gonna get a good processor with your current motherboard, and computer parts (like Ram, hard drives, video cards) are going to cost more and more for their rarety, while they are less performant.
Best of luck to you!
Mar 14, 2011 | Computers & Internet
I got this Presario 700 from a friend. it has a
Compaq Presario 700 Memory
Maximum Memory 384MB
Memory Slots 1 (1 bank of 1)
non-removable base memory 128MB
Machine name: Compaq Presario 700
CPU options: AMD Mobile Duron (900MHz)
Chipset: VIA ProSavage KN133
HD Bus: Ultra ATA-66
Front Side Bus options:
Memory Speed options: PC133 144pin SDRAM SODIMM
Hope this helps you out. Have a Happy and safe 4th of July weekend!
Jul 02, 2010 | Compaq Presario 700 470024-192 Notebook
My laptop was need to activation
A Compaq Presario 700US doesn't have the hardware to run Vista.
1.Processor: AMD Duron processor that operates at 900MHz
2.Ram Memory: 256MB of PC133 ram memory, (SDR Sdram that operates at 133MHz)
3.Graphics: VIA S3 Integrated graphics chip
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00255264&lc=en&dlc=en&cc=us&lang=en&product=95525
Your laptop will run Windows XP, but I would advise upping the ram memory amount to the maximum, for the best Windows XP experience. That would be 384MB of ram memory.
Change to Windows XP? Sure. Just buy the full installation disk of Windows XP. (About $95 US online)
Be sure to go into your BIOS Setup, and in Boot Options set the first boot device to CDROM.
Whoever tried to put Windows Vista on that laptop, didn't know what they were doing. That laptop Will Not run it!
Sep 01, 2009 | Compaq Presario 700 470024-192 Notebook
Want to upgrade CPU and Ram on ASUS A7V-ML motherboard
Download a small utility called CPUID from http://www.cpuid.com or use this direct download link "http://www.cpuid.com/download/hwmonitorpro/HWMonitorPro_106.zip". Using this utility you can analyze your system hardware statistics and also you can find the RAM capacity supported in your system along with various other RAM parameters. It will also show you the available free RAM slots to use, as well. I hope this is useful to you.
Aug 04, 2009 | AMD Athlon , 650 MHz (-K7650) Processor...
CRITICAL TEMPERATURE
Hi there
The processor will become critical at around 49c - 54c, but that shouldn't matter.
If you are wanting to overclock it you should be looking at more cooling for the system, a bigger fan and heat sync for example.
also set a fail-safe in the bios for the system to shut down near critical temperature.
Good luck and thanks for using Fixya!!!
Feb 11, 2009 | Intel SL5PY - Mobile Celeron 900MHz...
Processor
hi, from your reference i could get the info that your pc is running with the mainboard similar to FIC - am37,and with that the below mentioned processors are supported. Recommended Speeds: AMD Athlon? XP 2600+ (266 FSB) AMD Athlon? XP 2400+ (266 FSB) Model 10 w/ 256K Cache AMD Athlon? XP 2400+ (266 FSB) AMD Athlon? XP 2200+ (266 FSB) Model 10 w/ 256K Cache AMD Athlon? XP 2200+ (266 FSB) AMD Athlon? XP 2100+ (266 FSB) Model 8 AMD Athlon? XP 2100+ (266 FSB) Model 6 AMD Athlon? XP 2000+ (266 FSB) Model 8 AMD Athlon? XP 2000+ (266 FSB) Model 6 AMD Athlon? XP 2000+ (266 FSB) Model 10 w/ 256K Cache all the best.. sreejith
Jul 16, 2007 | Compaq Athlon XP 2000+ , 1.67 GHz...
EliteGroup 741GX-M Motherboard Logo
97 people viewed this question
Top EliteGroup Computers & Internet Experts
David
David
Alun Cox
Jerry Umali
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
