Question about Kenmore 54501 Dehumidifier
Cost of kenmore dehumidifiers model 251.50501012
Tip
Technical service manual for the 54501 Dehumidifier
Again, this is shown as a Goldstar LD50EL. But, it is the same model as the Kenmore and is the actual unit built FOR Kenmore. Below is the url for the tech service manual. http://136.166.4.200/contents/Files/Dehumidifiers/DH404E/DH404E_service_manual.pdf
on Jul 31, 2007 | Kenmore 54501 Dehumidifier
My Kenmore Elite Dehumidifier model 42-99701 runs but does not cool enough to collect water. Not a drop. found this page where I can order parts but I don't know what part I need to replace. Please help....
Dehumidifers are cheaply made and most likely it has formed a refrigerant leak. It would cost more to repair than to replace with a new one. They are basically a disposable appliance.
Oct 12, 2013 | Kenmore 54501 Dehumidifier
Kenmore model 580.54351800 ices up quickly, doesn't defrost, and as a result doesn't dehumidify. Bad thermistor?
Here is a tip that I wrote that will help you understand why and what you cando with a dehumidifier that ices up.
Dehumidifier is Freezing up and not working
heatman101
Sep 12, 2011 | Kenmore 54701 Dehumidifier
I have Kenmore dehumidifier 580.54701 70. Connected to external drain. Showing 01 code in humidity setting screen. Will not run. Approximately one year old.
Your model Kenmore Dehumidifier, I believe was was made my Haier, for Sears under the Kenmore name. In which case "01" indicates a circuit failure shutdown and needs to be repaired by an authorized Sears service technician. As it may still be in warranty.
Hope this helped you and thanks for choosing FixYa.
Aug 06, 2011 | Kenmore 54701 Dehumidifier
Kenmore dehumidifier does not collect water and I have cleaned the coils but it didn't fix the problem
Check to see if the compressor and fan are running. If this is true, additional diagnosis will have to be done by a technician. Usually the cost of repair for this type is far more than replacing it.
Oct 03, 2009 | Kenmore 54501 Dehumidifier
Our Kenmore dehumidifier (Model 580.53650200)runs but no water collects in the reservoir bucket. What could be wrong?
There are many reasons for a dehumidifier2_bing.gif to not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier2_bing.gif.
Dehumidifier is running but no water is in bucket
http://www.fixya.com/support/r4662409-dehumidifier_running_but_no_water_in
heatman101
Sep 18, 2009 | Kenmore 5365 Dehumidifier
Kenmore 54501 Dehumidifier no water in bucket
may have lost ref charge check name plate for type of ref with 12 and 22 cost of gas cost proh. check tubing in rear should be ice cold to gather condensate if not probably lost gas
Aug 09, 2009 | Kenmore 54501 Dehumidifier
if the compressor is running it sounds like a refrigerant problem or dead compressor in both cases its not cost efective to repair dan
Jul 05, 2008 | Haier HDN655E Dehumidifier
Kenmore 54501 Dehumidifier Logo
101 people viewed this question
Top Kenmore Dehumidifiers Experts
Bill Long
Mike Squire
Are you a Kenmore Dehumidifier Expert? Answer questions, earn points and help others
