Question about Vinci Tab MV VM-5610 Smartphone - Wi-Fi - 3G - Bar TAB 5IN ANDROID 4.03 3G MV DUAL SIM 3000MAH SIM-free - Android 4.0.4 Ice Cream Sandwich - 5" LCD 480 x 800 - Touchscreen - Multi-touch Screen - 5 Megapixel Camera - Quad Band GPS Reciever - USB
How to install sim card to acer iconia 1/b tablet
Can I install split-screen on my Acer iconia 1a810 tablet/
I don't think it has split screen capability.
Sep 09, 2016 | Acer Iconia A1-810
Tip
VOB movies for Acer Iconia Tab A500-Stream DVD VOB to H.264 MP4 to Acer Iconia...
Transfer/Play DVD VOB files to H.264 MP4 for Acer A500 <br />Join multiple DVD vob files into one for Playback on Acer Iconia Tab A500 <br /><br /><b>A VOB file (Video Object)</b> is a container format in DVD-Video media. VOB can contain video, audio, subtitle and menu contents multiplexed together into a stream form. VOB file can contain H.262/MPEG-2 Part 2 or MPEG-1 Part 2 video, MPEG-1 Audio Layer II or MPEG-2 Audio Layer II audio, but usage of these compression formats in a VOB file has some restrictions in comparison to the MPEG program stream. <br /><br />How to convert and play DVD VOB files on Acer Iconia Tab A500? For Acer Iconia Tab A500 can not accept this format. <br />Acer Iconia Tab A500 is also a great media player which supports a lot of media formats including files with XviD, MP4, H.264, H.263 as video format and MP3, WAV, WMA, eAAC+ as audio format. So you need to convert the files before transferring and playing them on Acer Iconia Tab A500. <br /><br />Aunsoft Video Converter is the best <b><a href="http://www.aunsoft.com/video-converter/">VOB to Acer A500 Tab converter</a></b> for you to transfer files to tablet. It makes it easy to transfer VRO files to Android tablet by converting DVD VOB to MP4 for Acer Iconia Tab A500. You may also deinterlace VOB to progressive mode for perfect playback on Acer Iconia Tab A500. <br /><br />Below is the quick step-by-step guide for you to <b><a href="http://canon-videoconverter.com/2011/06/join-multiple-dvd-vob-files-into-one-for-playback-on-acer-iconia-tab-a500/">transfer and play VOB to Acer Iconia Tab A500</a></b> via Windows XP, Windows Vista, Windows 7. <br /><br />Step 1. Load VOB to Aunsoft Video Converter. <br />Run Aunsoft Video Converter as the best VOB to Acer Iconia Tab A500 converter, and click the "Add" button to import the .vob videos. <br /><img src="a500-vob-converter.jpg" /> <br /><br />Step 2: Choose the suitable Acer Iconia Tab A500 format. <br />As we know, Acer Iconia Tab A500 supported video like XviD, MP4, H.264, H.263 format like MP4. Here just take H.264 HD Video (*mp4) for example. Choose Common Video &gt; H.264 Video (*.mp4) as output format. <br /><br />Tips: Click "Settings" to set the Video/Audio Parameters like Size (resolution), bitrate, frame rate, etc to be more suitable for Acer Iconia Tab A500. For example: Set Size/Resolution to 1280*800 pixels. <br /><img src="set-a500-profile.jpg" /> <br /><br />Step 3: <b><a href="http://www.aunsoft.com/video-converter/">Convert/Rip DVD VOB to MP4 for A500</a></b>. <br />After all the above settings, you can click "Convert" to start <b>conversion VOB to MP4 for Acer A500</b>. Only a few munutes later, you can get the generated files by clicking "Open" icon. <br /><br />When the conversion is done, just connect Acer Iconia Tab A500 to Widnows PC via USB cable, and mount the converted videos to Acer Iconia Tab A500. <br /><br /><b>Tips:</b> If you want to <b>join multiple DVD vob files into a large files for smoothy playback on Acer Iconia Tab A500</b>, just check "Merge into one file" to make it.
on Jun 06, 2011 | Sony Alpha DSLR-A580 Body Only Digital...
Download user manuel
Whether it's a *.pdf file or not, as soon as 1 programme can display the content of the manual, the same programme should be able to print it. e.g. print from adobe accrobat reader directly. Otherwise install the "open office" suite (costs 0) to open the manual file. that software should be able to print the content. (make sure the printer is correctly installed on your system.)
Aug 12, 2014 | Acer Iconia B1 7-Inch Tablet Black Dual...
How to switch off the demo mode of a tablet acer iconia b-1 710
Have you tried contacting tech support, its possible it will only take a minute or two and they may even steer you in the right direction to download a guide.
Dec 13, 2013 | Computers & Internet
Acer iconia a500 tablet freezes at the boot screen and does not go any further
The following info from
http://community.acer.com/t5/Tablets/Iconia-A500-frozen-at-Acer-logo-boot-screen/td-p/7171/page/28
might be helpful:
"How do I perform a Factory Data Reset if my Acer ICONIA TAB A500 does not boot?The following steps will erase all of your personal information, all stored contacts and any programs you have installed on your tablet.
1.Power off the tablet.
2.Press and hold the Volume up button, which is located closest to the touch screen lock switch.
3.With the Volume up button held, press and hold the Power button for 3 seconds then release it. Continue holding the Volume up button.
4.Once the tablet vibrates, switch the touch screen lock switch on and off repeatedly while still holding the Volume up button.
5.Release the Volume up button and stop switching the touch screen lock switch once the "Erasing Userdata..." message appears in the upper left corner of the screen.
6.Once the factory reset has been completed your tablet will load to the Welcome screen. 7.Your Factory Data Reset has completed now follow the onscreen steps to setup your tablet."
Good Luck!
Oct 18, 2013 | Tablets & eReaders
My acer iconia android tablet refuses to startup
Perform a Factory Data Reset of Acer ICONIA
The following steps will erase all of your personal information, all stored contacts and any programs you have installed on your tablet.1.Power off the tablet.
Aug 24, 2013 | Acer ICONIA Tab W500PC52G03iss
How can i transfer pictures from acer iconia to memory card
This Tablet Personal Computer [PC] takes Micro Secure Digital [SD] Cards. To transfer pictures from a Digital Camera to this PC, if the Camera also takes Micro SD cards, is simply a matter of removing the Micro SD card from the Camera and installing it in the PC's Micro SD Card Slot and then waiting for the PC's AutoPlay function to serve up the photo files stored on the card, which can then be Dragged and Dropped into a photo folder on the PC.
If the Camera takes SD Cards, then a Micro SD to SD Card Adapter is required so that the PC's Micro SD Card can fit in the camera before pictures are taken and then disconnected from the adapter afterwards, for re-insertion in the PC.
If the Camera takes a different type of Memory Card, then a Multi Card Reader might be required, which would be connected to the computer's USB Port and the Memory Card slotted into its matching slot in the Card Reader.
See Acer Iconia Tablet PC Specifications here (or on similar specification pages):
http://www.amazon.com/Acer-A500-10S16u-10-1-Inch-Computer-Aluminum/dp/B004XZL980
USB MULTI CARD READER
MICRO SD CARD TO SD CARD ADAPTER
Nov 29, 2011 | Acer Iconia A50010S16u Tablet Computer
Vinci Tab MV VM-5610 Smartphone - Wi-Fi - 3G - Bar TAB 5IN ANDROID 4.03 3G MV DUAL SIM 3000MAH SIM-free - Android 4.0.4 Ice Cream Sandwich - 5" LCD 480 x 800 - Touchscreen - Multi-touch Screen - 5 Megapixel Camera - Quad Band GPS Reciever - USB Logo
79 people viewed this question
Top Vinci Photography Experts
Tony
Are you a Vinci Photography Expert? Answer questions, earn points and help others
