Question about DeLonghi PAC T110P Portable Air Conditioner
What does ft mean - DeLonghi PAC T110P Portable Air Conditioner
How many cubic yards for a 20x12 slan 4 inches thick
Assuming that 20x12 means 20 feet by 12 feet, then you take the three values in feet - 20, 12, and .333 (4 inches is 1/3 foot).
Multiply these three numbers to get the cubic feet:
12 x 20 = 240
240 x .333 = 79.92
Now that you have 79.92 cubic feet, to get cubic yards you divide by 9 since there are 9 cubic feet per cubic yard.
79.92 cu. ft. divided by 9 = 8.88 cubic yards (round up to 9).
Jul 27, 2016 | Building Materials
How many feet is 27.19cu.ft.?
There is no direct conversion, ft being length, and cu ft being volume.
Do you mean how many liters maybe?
May 08, 2015 | Frigidaire Refrigerators
How many yards will it take to cover 30ft by 40 ft ,4inches deep
Do you mean how many cubic yards it would require to fill a volume occupied by an area of 30 ft by 40 ft by 4 ins deep? If this is what you mean then it would require 11.1 cubic yards. Hope this helps.Sorry I can't help with the cost.
Mar 26, 2015 | Pottery Barn Adair Floor Lamp, Bronze...
To find percent of a number
I assume you mean the total space is 151,250 sq ft and you want to know what percentage of that is 76,000 sq ft?
Divide 76,000 by 151,250 then multiply by 100.
Feb 01, 2014 | Office Equipment & Supplies
What is the cu.ft. for Kenmore Freezer Model number 253-21201102
The 3rd number after the 253 indictes your cu. ft. so the 3rd number on yours is 8, that means yours is an 18 cu. ft.
Best wishes,
TF
Jun 03, 2011 | Kenmore Freezers
Dear expert What are the cylinder head bolt torque settings for the 4.0L MFI straight 6 engine? Regards Dave
Here are the specs and sequence:
Install the cylinder head and bolts. The threads of bolt No. 11 must be coated with Loctite® 592 sealant before installation. Tighten the bolts in 3 steps, using the correct sequence:
  1. Tighten all bolts to 22 ft. lbs. (30 Nm).
  2. Tighten all bolts to 45 ft. lbs. (61 Nm).
  3. Retighten all bolts to 45 ft. lbs. (61 Nm).
  4. Tighten bolts 1 through 10 in sequence to 110 ft. lbs. (150 Nm).
  5. Tighten bolt 11 to 100 ft. lbs. (136 Nm)
  6. Tighten bolts 12 through 14 to 110 ft. lbs. (150 Nm)
May 04, 2011 | 1996 Jeep Grand Cherokee
WHAT IS CYLINDER HEAD BOLT TORQUE ON A 1988 JEEP CHEROKEE LTD. 4.0?
Torque settings are 110 ft LBS for nine of the ten bolts one bolt is 100 ft LBS /#1 Tighten all bolts in sequence 1 to 10 at 22 ft LBS #2 tighten all bolts 1 to 10 at 45 ft LBS #3 tighten all bolts 1 to 6 at 110 ft LBS #4 bolt #7 at 100 ft LBS #5 BOLT 8 TO 10 AT 110 FT LBS . HEAD TIGHTEN SEQUENCE - standing at front of car bolts down left side are 8/4/1/5/9 bolts down right side are 7/3/2/6/10. left side meaning distributor side.
Oct 07, 2010 | 1988 Jeep Cherokee
Instruction book in English for Family Chef model FT 338 Purchased in France this week by English family.
It seems there is no English language instruction book for the Wirlpool microwave FT 338. However, the nearest UK equivalent is the FT 337, and the only difference is the lack of the "Crisp" plate.
I suggest you download the FT 337 instruction book in English from the Wirlpool.Uk website, and also the FT 338 insytruction book in French from the same source, which means you only need to translate a few lines of French into English to have the full instructions.
Feb 19, 2010 | Microwave Ovens
Just want to retorque the head bolts hopeing to get lucky and solve a minor head gasket leak but dont know the specs
Torque settings are 110 ft LBS for nine of the ten bolts one bolt is 100 ft LBS /#1 Tighten all bolts in sequence 1 to 10 at 22 ft LBS #2 tighten all bolts 1 to 10 at 45 ft LBS #3 tighten all bolts 1 to 6 at 110 ft LBS #4 bolt #7 at 100 ft LBS #5 BOLT 8 TO 10 AT 110 FT LBS . HEAD TIGHTEN SEQUENCE - standing at front of car bolts down left side are 8/4/1/5/9 bolts down right side are 7/3/2/6/10. left side meaning distributor side. A four cylinder engine has ten (10) bolts. A six cylinder has fourteen (14) bolts.
Feb 16, 2010 | 1998 Jeep Cherokee
I LOOKED UP THE TORQUE SETTING FOR THR HUB NUT FOR A 1999 FORD TAURUS.IT IS 184/250 ftlbs/NM. CAN YOU EXPLAIN WHAT THE ''NM'' MEANS ? ALSO, WHAT IS THE TORQUE SETTING FOR THE 3 HUB BOLTS?
What "NM" means is Newton Meters; it's the metric measurement equal to the standard measurement. You interpret the torque settings like this 184 ft lbs OR 250 Newton Meters.
The three hub bolts should be tightened to, I believe, 80 ft lbs OR 110 Newton Meters
Oct 23, 2009 | 1999 Ford Taurus
DeLonghi PAC T110P Portable Air Conditioner Logo
35 people viewed this question
Top DeLonghi Heating & Cooling Experts
Paul Carew
Donni Steen
Are you a DeLonghi Heating and Cooling Expert? Answer questions, earn points and help others
