Question about Video Cameras
My Insignia HD DV hdmi camcorder wont charge
The unit is plugged into the computer through a USB connector. Left for several hours, it will get warm to the touch but it will not charge up
You must use original wall charger... i have the same one. says in users manual
Posted on Aug 20, 2009
I had same problem.Best Buy replaced it. Same problem with the replacement.Best Buy doesn't even carry this model any more.Is it posible that it is just a piece of junk?
Posted on Mar 03, 2010
I have a GR-D295U camcorder. Can I get a cable that connects the mini USB connector on the camcorder to a regular USB connector on the computer? Thanks, Rene
The USB connection for this camcorder only allows still image transfers. To transfer video you will need a DV cable (JVC VC-VDV206U or VC-VDV204U depending on the type of DV connector on the PC - 4 or 6 pins)
Jul 13, 2011 | Video Cameras
I just got a brand new flip video mino hd and it wont turn on. i've charged it for atleast 4 hours. when it is plugged in the red light comes on. that is the only response i get from it. any...
I had to charge mine for 7 to 9 hours the first time, and make sure computer is left ON or it won't charge and the red light stays lit until it is fully charged. make sure the red light isn't blinking if it is, plug it into a different USB 2 port and don't use extension with it unless it is a powered USB extension.
Dec 28, 2010 | Pure Digital Flip Video Ultra Camcorder
I have a problem similar to some posted but not exactly..My unit doesn't turn on unless plugged into usb, red light comes on and screen flashes green "insignia" welcome screen then goes blank. no buttons...
If memory serves, this unit requires the battery to be in place and functional to have the camcorder work properly...so your prognosis of a failed battery would be appropriate.
Go Here: http://www.batteriesplus.com/products/546-0/6354-Camcorder-Batteries/437138-Insignia/NS--DCC5HB09/1.aspx
This should be the correct battery for the camcorder.
hope this helps!
Jul 17, 2010 | Insignia NS-DCC5HB09 High Definition Flash...
I have the Insignia HD camcorder, this is the second one I have and the second time I have this problem. The first couple of times it charges, then I don't use it for a couple of months, try to charge it...
Have you tried using an AC to USB charger?
I know that some products that charge through a USB port are not able to completely and correctly charge from the computers USB port because it is undervolted for what the device needs. (I have the same issue with my cell phone).
Also, may of a computers USB ports will power enough for data transfer, but not enough for charging the unit.
Try using an AC to USB power supply and not the computers USB ports.
Hope this works!
Apr 07, 2010 | Insignia NS-DCC5HB09 High Definition Flash...
New 840XHD Vivitar Camcorder. Can't get it to turn on.
Can you get into the main menu with the power converter? If so try to set all settings back to factory default.Or try using the power from the computer to do the same via USB.
Aug 17, 2009 | Video Cameras
Charging
same problem.. plug USB port .. not charging???
Apr 27, 2009 | Pure Digital Flip Video Ultra Camcorder
Insignia 5.0 mp hd camcorder. How do I charge the battery?
Make sue the text side of the battery is facing up. Not the pure black side... I was having this problem until I decided to flip the battery around and it worked just fine...
Jan 09, 2009 | Cameras
I have a jvc model number GR-D770U AND IM TRYING TO TRANSFER what is on the cassette to my computer with the usb cable how do i do it.
Your camcorder is only able to transfer still pictures with usb,if you would like to transfer a video you must use a DV input on a computer.If you would like instructions on how to transfer still pictures using the usb.Install software that was included with camcorder then make sure your using the adapter instead of battery otherwise you may run out of power,then make sure your unit is turn off then plug in usb cable to computer.After plug unit in turn on camcorder and use software provided to transfer pictures.Never pull out memory card when plug in to computer and make sure you do not unplug cable while arrow signs pointing right and left on view screen.I hope this helps you out happy picture taken.
Jul 29, 2008 | JVC Cameras
Jazz DV 179 Camcorder
I believe that the camera will not charge directly from the computer - testing this theory myself... however I went to Radio Shack tonight and they have them there for 30 bucks (a bit outragious if you as me)
Jul 24, 2008 | Jazz DV-179 Digital Camera
Issue connecting HD Video Camcorder HV10 to MacBook
The USB cable is only for downloading still pictures from the camcorder. I don't know of any way to download movie unless you have a computer with the necessary IEE1394 (DV) terminal. Sucks as I have a Macbook Pro and can't download the video!
Jul 14, 2008 | Canon HV10 HD Camcorder
Video Cameras Logo
3,334 people viewed this question
Top Video Cameras Experts
Marvin
Marvin
Are you a Video Camera Expert? Answer questions, earn points and help others
