Vacuums Logo
A
Anonymous Posted on May 09, 2014
How can I change the bag in a Wertheim ET2000 vacuum cleaner?
2 Related Answers
Anonymous
  • Posted on Mar 25, 2009
SOURCE: how to open the case of a wertheim b20 vacuum cleaner
Take out all the obvious screws around the base and coloured top using the appropiate driver.   There is one screw under the flap used to hold the dust filter in place.   The flap is spring loaded and can only be removed (as I see it) once the top is taken from the base.   To remove the screw I used a pair of long nose pliers and some patience.   Once the top is clear of the base, other screws can be easily seen and removed.
My problem was a badly worn bearing at the commutator end of the motor.   There was so much movement that the brushes would not follow the commutator with a result of excessive noise and sparking.   The brushes had dug into the commutator segments and chipped etc.
The bearing is permanently pressed into the motor end and cannot be replaced.   This means a new motor which, in my part of the world, was quoted as $250.00.    My neighbour will be purchasing a new vacuum cleaner but after 15 years with the old one he hasn't done too badly!
SmartAlec
VacuumSpot
  • 171 Answers
  • Posted on Aug 02, 2010
SOURCE: How do you open a wertheim 2000P vacuum cleaner?
SmartAlec from NelsonVacuums.com.au here. The ET2000 has a latch that is located at the very end of the machine lid (about 6 cm in front of where hose clips in. If you sit the machine up on its back end you should see the black lever that needs to be pushed in. Now I will also say that it is possible that you have actually been pushing this but the lid still wont open, this is because every now and again the whole latch moves itself out of alignment by about a milimetre. The easy fix for this is a gentle screw drive to assist the relesing of the catch, this needs to be gently pushed in at the same time as squeezing the latch (hand at top of latch screwdriver at base kind of toward the middle of machine). You should be able to get it open like this with only light pressure. Now of course if you need bags or filters please visit us at NelsonVacuums.com.au.
Kind regards Alec
Which vacuum would you prefer for pet hairs ?
I've been repairing vacuums over 30 years, I prefer a bag vacuum because a good bag vacuum is a lot less maintenance, all the nasty stuff goes in a cheap paper bag (which is actually just a really good great big cheap filter) which you simply remove and gently sit in the trash. It usually takes less than 30 seconds to change bags and only needs done about once a month. You will dump a dirt cup about 40 times compared to changing one bag. Bags compact the dirt while bagless fluffs the dirt. Bagless filters and dust compartments need frequent cleaning and replaced at least once a year to work properly. Bagless vacuums leak more dust and dirt which you will notice on your vacuum. In the long run its much easier and cleaner using a bag vacuum plus they usually last much longer, usually outlasting 3 or 4 bagless vacuums. Much less expense and hassle in the long run.
Mar 05, 2018 • Vacuums
My wertheim 5035 won't shut properly when trying to put a bag in? Does anyone know how to fix this problem?
Sounds like something is not propertly aligned. Try repositioning -- do not force it!
Jan 02, 2014 • Vacuums
Wertheim vacuum cleaner 2000 does not seem to be having enough suction
If you are sure the is no leaks on suction line, please check and clean the filter. The common problem on weak suction vacuum cleaner are leaks and filter clog up.
Regards
Jun 18, 2011 • Vacuums
4helpful
Kind regards Alec
Aug 02, 2010 • Vacuums
1helpful
How to open the case of a wertheim b20 vacuum cleaner
Mar 24, 2009 • Vacuums
Top Vacuums Experts
AskDyson
AskDyson
Anonymous
Are you a Vacuum Expert? Answer questions, earn points and help others
