Question about Microwave Ovens
Hi I have a whirlpool stand alone fridge/freezer and the freezer part is giving a warning sign on the front where you set the temperature. The temperature changes to two lines and there is a constant beeping. I have switched the appliance off for a few minutes and turned it back on and it happens again. I cleaned out the back of the fridge where the compressor is and it has made no difference. The fan is not running at the back when it is switched on. I am not sure what the model is as I bought it second hand from a friend. It is 6-7 years old.
  • alexgolledge Jun 22, 2009
    the fan i looked at was at the bottom of the fridge at back, i removed the panel and there is a fan
  • alexgolledge Jun 23, 2009
    I checked the fan and it seems to be working fine now, removed the front panel at the bottom and removed a load of dirt built up on some coils. fridge still not getting cold at the top half of both sides yet bottom half seems ok
    Top Expert:
  • Microwave Ovens Master
  • 81,400 Answers
The problem is most likely the temperature control circuit board up front, replace the circuit board, u will need to find out the model to do this, it may be on a tag at back of fridge.
Posted on Jun 23, 2009
    President:
  • 2,923 Answers
The fan at the bottom of the of the fridge is called the 'condenser fan'. That fan should be working while the fridge is plugged-in or turned on because it will affect the functionality of the fridge including the temperature inside of it.
The things that you could do to fix that is either check the wiring (if everything's properly connected) or replace the motor.
You need to refer to the user manual of the fridge to see the exact model number or it's better to contact the manufacturer for assistance or for second opinion.
Hope it helps and have a great day!
Posted on Jun 22, 2009
    Brigadier General:
  • 3,917 Answers
If your refrigerator is turned on and the compressor is running your freezer fan should be running unless the fan motor is bad.
To take a look at the fan motor.
1. Unplug the refrigerator.
2. Open the freezer door.
3. Clean the freezer out.
4. Remove ice maker, if you have one in the freezer.
5. Remove the back panel inside the freezer.
If you have a meter you can check to see if you have power to the fan motor, but like I said if your refrigerator is on and the compressor is running that fan should be running to, unless it's bad.
If the freezer is not defrosting there could be frost build up around the fan keeping it from turning, but your freezer will be a bit warm too if that is the case.
You will be able to check for frost build up around the fan once you take the back panel off so you can see the fan motor.
Replace the fan motor and that should correct the problem.
Warning: If the condenser fan is not running then the compressor will overheat and go out on overload
Thanks for contacting Fixya
  • e-Guru
    e-Guru Jun 22, 2009
    correct. After consulting its for sure that if u replace the fan motor the issue will resolve. The error signal that you are getting is due to faulty fan motor.
Miele Fridge Freezer not getting cold
Power off and remove all fluff under the fridge.
Compressor can be hot but not too hot. Are the settings ok for desired level cold. Is the fridge too heavily loaded? Try now.
Aug 07, 2013 | Miele Microwave Ovens
I auto cleaned my oven the other day. I wiped it out with a damp cloth and later on that night went to turn it on and it would not heat up. The power turns on and the display seems to work normal and the...
Hi, Look at the home breaker box or fuse box to check for a tripped breaker or blown fuse. If your oven is not heating because there is no power, you may need to replace a fuse or reset a breaker. Also check the power outlet to confirm that the oven is plugged into the outlet securely.
Press the "START/ENTER" button to get the oven to heat after selecting your temperature, if you cannot get it to heat. If you do not press this button within five minutes of setting the temperature, the oven heating cycle will automatically be canceled and the oven control panel will return to displaying the sign.
Calibrate the temperature setting on the oven if it is not heating at a temperature that you like. Do this by holding down the "BAKE" button until the current calibration setting appears, which will be a temperature followed by "CAL." Use the up and down arrow button to increase the temperature and press the "START/ENTER" button once you are done. You can increase in five degree increments up to an additional 35 degrees.
Call the Whirlpool customer interaction center at 800-253-1301 if your troubleshooting fails to fix your heating problem. The customer service representative can give you contact details for a local service technician so that you can have the oven looked at by a professional.
Hope it helped
Aug 25, 2011 | Microwave Ovens
I have a ocean fridge freezer & want to know if No.1 is the coldest setting or No. 9 is the coldest on the temperature dial
9 is usually the coldest setting. Turn the dial all the way. The side with the click is off. If it does not click, then turn it all the way and listen for the compressor to turn on or off. What I just told you applies only to the freezer. The numbers on the dial for the fridge should be the same.
Jun 04, 2011 | Microwave Ovens
My whirlpool fridge (model ED22TOXGW00) does not keep the food cold enough.I have the temperature settings set to MAX and it's still not cold enough. Seems like the motor is not running as often as it...
Have you checked the cooling coils to make sure they are clean and air can flow through them? Are the coils in the freezer frozen up? full of ice?? Must have air from from freezer to cool refrigerator.
Aug 20, 2017 | Microwave Ovens
Refigarator and freezer no longer cold enough. freezer is not freezing and refigarator is not cold enough, food is going bad. Unit is not yet 5 years old.
pull out the plug for the fridge and let it stand for 7 days then plug in after seven days.the problem is that the fan that circulates the air is cloged up with ice so you have to give time for the ice to melt off.
Mar 04, 2011 | Microwave Ovens
Hi cant get my Samsung fridge freezer to turn on - just the letters RD appear in the top digital display Any ideas Thx Dave
hi RD stands for refridgerator defrost ...
prob best to switch of for 5 mins and then put back on - has anyone been playing with buttons at front as this can put appliance into service mode where this code can show up ??
samsung fridge freezer diy channel on toutube
hope this helps ">
Feb 07, 2011 | Microwave Ovens
Food in the refrigerator department is freezing. I checked the refrigerator temperature setting and it is 46 deg f. I checked the freezer temperature setting and it is 5 deg f. I put a NIST traceble...
When the refrigerator side is getting too cold this is because the control of the compressor has gone bad in some way...
There a few different things that could cause the unit to lose control over the temperature of the fridge side.
If your refrigerator has a damper door that opens and closes to allow cold air to move to the fridge side the damper linkage or the damper motor may have broken or gone bad.
The coils in your fridge may have frozen over and now the air does not move at all so then the ice builds up and can freeze parts of the fridge side.
The thermostat has gone bad and so now the compressor runs continually. This will not be noticed readily on the freezer side but will show up quickly on the fridge side.
Many newer model refrigerators use an electronic sensor or thermistor to read the temperature and supply the info for the circuit board and often a digital readout.
So, here is how I would go about troubleshooting this problem.
Check the coils for ice, defrost the coils with a heat gun or hairdryer, then check for the reason why they iced over. Defrost control or defrost timer bad? Evaporator fan bad?
Check the damper door to see if it is stuck in the open position. If it is then check the motor and the linkage.
Check to see if the refrigeration unit will shut down if the thermostat or digital setting is turned up to a higher temperature. If it continues to run then find the cause and fix it. It may be a bad thermostat, sensor, or control board.
Sometimes with a change is weather to a cooler climate this will be enough to also affect the inside temperatures. Make sure that a bit of adjustment in the thermostat or setting of the temperature will not solve your problem very simply.
I hope the above helps.
Good luck.
Jan 13, 2011 | Microwave Ovens
Have samsung american fridge freezer with ice dispenser i bought it second hand the problem is the digital display says the freezer is 20 degrees but its freezing inside also every minute or so we hear a...
If it's American, the temperature probably reads as fahrenheit. If so, 20 degrees F is 12 degrees F below freezing which converts to only -6.67 degrees Celsius.
Domestic freezers should be set to -17 degrees Celsius (= 0 degrees F), so the beeper is warning you that the freezer compartment is far too warm. If it's working correctly and has the temperature control set correctly, then it should achieve the correct temperature if you leave it for 24 hours and do not open the door nor try to use the ice dispenser. If the freezer is full of unfrozen items and so has to cool those down as well, then it may take even longer to reach the correct operating temperature.
Te operating manual for your appliance will tell you how to set the temperature correctly and whether it's possible to select between fahrenheit and Celsius scales. Most models allow you to set an override on the beep alarm as well. I cannot guide you on this without knowing the exact Samsung model.
Please take a moment to rate my reply.
Sep 22, 2010 | Microwave Ovens
My refigerator and freezer are not cooling enough
You could call for service. It is commonly possible that there was a loss of gas, or the thermostat is defective, or the compressor is weak. The refridgeration service man should be able to check for all of this.
Jerry G.
Apr 13, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave Ovens Logo
56 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Marvin
Marvin
Are you a Microwave Oven Expert? Answer questions, earn points and help others
