Question about Tecumseh Enduro Vertical Engine 16 HP 1in x 3 532in Shaft Model OHV16204230F
No Spark OH 160
No spark believe Ign Module bad. Where to find part
  • Clyde Ottaway Nov 08, 2017
    check the wire comeing off the coil to the ground sounds like grounfd not releasing
  • 603 Answers
Go to jacks small engines.com
Posted on Dec 09, 2017
    Loyalty:
    Visited the website for 30 consecutive days.
  • 211 Answers
Has to be iginition coil take coil offf and look for a part noumber get on amazon or ebay type in model and part noumber you should find it hope this helped.
No spark 2 coil &distributer
Do you mean no spark from the coil or distributor? Because the coil needs battery voltage to it to operate.
If you have no spark from the coil wire and you believe the wire is good or you have no reason to suspect it failing in a very short time, then before you do anything else, you should check if the small, pink wire to the little + side of the coil is a live wire (has current or voltage, and the connection is clean and tight) when the key is in on position. If no power there, the ignition switch or the wiring from the switch to the coil is bad.
If you have power to the coil, then either the coil or the electronic ignition module (inside the distributor, I think) may be bad. They can both be tested. Auto parts stores will test the ignition module for free. There are other possibilities for no spark, like a computer fault, or a bad pick-up coil, or a wiring or grounding fault, but for starters test the coil or swap in a known good one. If not the coil, check the ignition module next.
Good luck. Don't see many of those cars on the road anymore. Hope you keep it running.
May 28, 2012 | 1986 Buick Skylark
Won't start no spark
Check all your fuses, under the hood and at the fuse panel for ign fuse or ecm fuse and make sure they are'nt blown, then check for power to ign module which is under the coil paks, should be pink wire. good luck...sounds like maybe your ign module or crank sensor may have gone bad.
May 13, 2012 | 2002 Buick LeSabre
94 CAPRICE WITH LT1 WONT STAY RUNNING
check fuel regulator, fuel pressure, could be bad sending unit in fuel tank, change out fuel filter
Apr 30, 2012 | Chevrolet Caprice Cars & Trucks
My jimmy wont start have 58 psi of fuel pressure good spark but the spider injection wont open to spary the fuel brand new 280 bucks for it have checked grounds two broken one fixed those still no start...
check your ecm-ign fuse.if it is ok check to see if you have power to your spider injector.if you have power, you either have a bad computer or a bad connection between the computer and the inj.do you have spark??.if you have no spark check your ign module or bad connection at the ign module.i have seen that before.
Feb 01, 2011 | 1993 GMC Jimmy
Will not start, replaced fuel lines (1 was broken) and spark plug
does it even run at all for a short bit? If not pull the spark plug from the unit, place some part of the spark plug threads on the metal surround the spark plug hole in the engine, turn the unti manually with the pull cord/starter and see if you get spark, if no spark it could be the Ign. coil module, a bad spark plug wire, or a break in the wiring to the ign. coil module.
Jun 07, 2010 | Poulan Weed Eater Electric Blower/Vacuum...
My Poulon Pro 17 will not start; it has new fuel lines, new spark plug, new filter, and clean fuel. What have I overlooked?
Got spark? Take the plug out but leave it connected to the plug wire, touch some part of the threads to the metal near the hole in the engine for the plug, turn it over a few times either with the pull cord or with a starter, and see if you get spark, if not, could be ign. coil module, bad plug wire, or bad wiring to the ign. coil module.
Jun 01, 2010 | Poulan 25cc 2-Cycle Gas Powered String...
I have a 1997 Gmc Sierra 5.7 4x4. It has no spark. I replaced the coil and ign module today but still no spark. Tech suggested Crank shaft sensor? Truck was running then died going down road. (30kms after...
It could be the CPS, but as you now know throwing parts at a repair is costly and sometimes it does not fix anything. A code scanner should be able to tell you if the sensor is bad. If the CPS goes bad you will have no spark.
Oct 17, 2009 | 1997 GMC Sierra
Mtd snowblower 4.5 no spark new coil,new plug, wire is good,switch is good, new shear pin
Hello pbck98:
>>The Following is a Basic Instruction File I Made for Checking the Coil/Ign Coil/Magnetron/Armature on Small Engines. Any Input is Appreciated.
>>**To Check the Ign Coil; Remove the Spark Plug/s.
>>With a Good Plug, Wrap a Wire Around the Threads of the Plug and Attach the Other End of the Wire to the Engine Block. >>Remove the Blower Housing (metal engine cover). The Wire that is Connected to the Coil/Ign Module from the Shut Off Switch needs to be Removed (unplugged) from the Coil/Ign Module.
>>Now Check for Spark at the Plug.
>>If Spark, then the Shut Off Switch or the Wire is Bad.
>>If Still No Spark, then the Coil/Ign Module is Bad. If there are Safety Switches on this Unit and the Coil is Good; you Need to Check the Safety Switches for Being Bad and Check the Oil Guard Switch also.**
>>If you have a New Coil/Ign Coil and Still No Spark, then
>>Turn the Coil Over and Check for Spark. Ign Coils are Wound 1 Way for Clockwise Engine and the Oposite Way for Counter Clockwise Rotation Engines. I have Seen Ign Coil Boxed Wrong and Turning the Ign Coil Over will Correct the Problem.
>>The Coil is Gapped to .015in from the Flywheel.
For Better Assistance;
>>Send me the Make, Model and Type or Spec Numbers Off the Engine, Please. With these I can Locate the Proper Manual and Better Assist you.
Please, Do Not Hesitate, If I Missed Something or you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
jbridger (John)
May 13, 2009 | Mtd 22" Yard Machine Push Mower
Wont start is there any way of resting the coil.
Hello
Please, Do Not Hesitate, If you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Good Luck
Respectfully
jbridger (John)
May 11, 2009 | Garden
Tecumseh Enduro Vertical Engine  16 HP 1in x 3 532in Shaft Model OHV16204230F Logo
211 people viewed this question
Top Tecumseh Garden Experts
Mike Squire
lnbn1975
itsman
Are you a Tecumseh Garden Expert? Answer questions, earn points and help others
