Question about Pioneer DEH-P940MP CD Player
Face does not open completely and go back rigth after stops.
Besides there is a cd inside and does not plat this, shows an error 10, faceplate opens just a little and turns off and stop, rigth after closes by itself.
Jexx
  • 148 Answers
SOURCE: Screen behind faceplate stopped illuminating/working
The ribbon cable has gone bad. A new one can be ordered direct from pioneer at parts.pioneerelectronics.com Good luck!
Posted on Nov 05, 2006
ampman
  • 98 Answers
SOURCE: Pioneer DEH-P6900UB
make sure that you have power not only to the red wire but also the yellow wire... one is battery power the othe ris ignition on power. If it only is getting one power it might not think the ignition key is on.. also maks sure there is not a reset button somewhere that you can press with a pen...
Posted on Aug 27, 2007
SOURCE: pioneer deh-p9600mp and deh-p960mp
my 9600 gat the same problem.. been told the ribbon needs replacing they sell on ebay for about £30 or you can send ur h/u to pioneer to do but that will be more expensive..
hope this helps
Posted on Jan 22, 2008
  • 23 Answers
SOURCE: 6800mp ribbon/power problem
NEEDS FACE PLATE RIBBON CABLE
Posted on May 16, 2009
  • 5 Answers
SOURCE: just bought a 2004 jeep cheroke, aftermarket radio, the face plat
the only to recieve a new faceplate, unfortunatly, is to buy a whole other new or used head unit.
Posted on Aug 06, 2009
DISPLAY ON MY KENWOOD STEREO STOPPED WIORKING
I also created a tutorial on fixing faceplates with 2R7 resistors (refer to my tip).
But, your unit will have a different chassis, as the faceplate is also a video display.
First you need to determine if the buttons on the faceplate are operating the various functions. If the buttons are NOT operating, then the faceplate itself (or connection to the main unit) can be considered faulty.
It's highly probable that the RIBBON cable (which connects faceplate to the inside of the unit) may be defective - this is common in some Kenwood units.
Try searching Google or youtube for ribbon cable repairs etc.
Hope this leads you in the right direction.
Cheers,
Scott
Dec 29, 2012 | Kenwood Car Audio & Video
Hi my problem is with the dvd tray it does not open . it make a funny noise but it does not open thx
OK I fixed it. One of the CD's had gotten stuck between trays in the loader. I pulled out a few CD's by forcing open the trays gently. However even after removing as many cd's as possible one was still stuck. 1. Remove screws holding cover plate on in back and sides. 2. Remove cover. 3. Lift face plate latches and lift over top of unit. Remove serial cables from connectors on board. Take face plate and place aside. Remove screws from back of CD tray unit and bend back metal tab with flathead screwdriver. Lift CD unit up on one side so you can get your fingers up inside underneath and push stuck cd towards tray openings. You can gently force top few trays out. You may need to shake unit so that stuck cd reaches open end. Pull out CD. 4. Replace faceplate and connect serial cables. Plug in power cord, power on unit and make sure trays will eject normally. 5. Put it all back together!
Jan 31, 2011 | Panasonic SC-PT660 Theater System
The player will not eject the cd but it will not play it either.
I know it sound crazy, but turn the system on, press eject while using a PLASTIC knife to lift the CD in the player. If the system is stock also try disconnecting the radio fuse for about 10 minutes or so with the car off. Reconnect it to see if the radio resets. You'll know the power completely went out because you'll have to reset your stations. By Resetting, hopefully the issue will solve itself. In a few of the system issues I've seen, when the motor won't open the faceplate, or the CD player won't give the CD back. I usually remove the faceplate or disconnect the negative side of the battery for about ten minutes. Try this if the fuse removal doesn't work. Good look. Let me know how it goes. there are other things to try.
Jul 27, 2009 | 2004 Honda Pilot
Wont stay open
I had load of these units and the cure is simple. You need to replace the ribbon to the faceplate as these get damaged due to wear and tear. Every unit i had with this fault, i fixed by replacing this ribbon. Buy the ribbon and surround as the new surround is a modified one to give extra life to the ribbon. Hope this helps, good luck!
May 25, 2008 | Pioneer DEH-P9600MP CD Player
Face plate won't open far enough to insert a CD
try to hit slowly the faceplate in the left side until its open
Mar 08, 2008 | Pioneer DEH-P80MP CD Player
Will power up,will hide, will open on igntion start
yup.. needs a new face plate ribbon cable.. just like mine :-(
Sep 24, 2007 | Kenwood KDC-716S CD Player
Illumination not working when faceplate is open.
Wire braid out to the faceplate has got a parcially broken wire on it. Sony referes to it as a flexible circuit board. Part can be purchased from sony directly, an on a one to 10 scale to replace about a five.But it does involve taking your radio apart. So if you are handy at electronics. you can look it over. If you have doubts let a professional do it.
Jan 05, 2007 | Sony CDX-M8815X CD Player
Nov 03, 2006 | Pioneer Premier DEH-P960MP CD Player
Pioneer DEH-P940MP CD Player Logo
29 people viewed this question
Top Pioneer Car Audio & Video Experts
Marvin
Marvin
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
