Question about Sears Du-all Eight 8mm Projector (584.92040)
How to thread a sears du-all eight 8mm projector
How to load a Sears du all 8 1973
Sears 8mm projector with 1950's & 60's films - YouTube
? 13:24
https://www.youtube.com/watch?v=7-IIS8ti7Ig
Jul 5, 2011 - Uploaded by drh4683
Vintage sears automatic projector. ... All 8mm and 16mm movie film, even going back to the 1920's and 30's ...
Sears Du-all Eight - Demo - YouTube? 0:37https://www.youtube.com/watch?v=WHbqCMKUGkoNov 13, 2007 - Uploaded by fierorcr86Buy This Now at www.mycurrentauctions.com I demo a Sears Du-all Eight super 8 ... How to load a Bell ...Sears Du-all 8 auto thread projector - YouTube
Jan 01, 2016 | Office Equipment & Supplies
Loading film
Hi Jacqueline, While I haven't used the particular model you have asked about, I "Googled" the Sears Du-all & got many hits. One of the hits was a UTube demonstration of a working Du-all. The link to it is the first link below. I also found a Sears database that details the manual number, lamp information, etc. That is the second link below. Take a look at these and other links you get when you Google "Sears Du-all". I hope this helps !!! Jim
http://www.youtube.com/watch?v=WHbqCMKUGko
http://www.super8data.com/database/projectors_list/projectors_sears/projectors_sears.htm
Mar 27, 2014 | Sears Du-all Eight 8mm Projector...
Kodak m67 8mm movie projector struck in rev lever can be move to forward but miss run backwards
it is hard to explain but there is a metal pin on one of the mechanisms it can become bent out of place. you need to remove it and heat it up and put back straight. dont try to bend it straight as it will snap or the pin will come out of the metal part.
Oct 13, 2013 | Kodak 1950s/60s Brownie 500 8mm Movie...
THREADING FILM IN A ELMO FP-C PROJECTOR
Is your film super 8mm? If yes, then the red sprocket above the lens should be pushed in, and the bottom black sprocket will stick out. If you have regular 8mm, then the black bottom sprocket should be pushed in. If the sprockets are not in the correct position, push the green lever forward (towards the screen) then open the two orange tabs, then push in the correct sprocket. Once you have the correct sprockets aligned, close the orange tabs. How to tell if you have 8mm or super 8mm film: Look carefully at the film image. If the sprocket hole is next to the middle of the image, it's super 8mm. If the sprocket hole is between images, it's 8mm.
Jan 10, 2013 | Sewing Machines
HAVING TROUBLE THREADING FILM - ELMO FP-C
Is your film super 8mm? If yes, then the red sprocket above the lens should be pushed in, and the bottom black sprocket will stick out. If you have regular 8mm, then the black bottom sprocket should be pushed in. If the sprockets are not in the correct position, push the green lever forward (towards the screen) then open the two orange tabs, then push in the correct sprocket. Once you have the correct sprockets aligned, close the orange tabs. How to tell if you have 8mm or super 8mm film: Look carefully at the film image. If the sprocket hole is next to the middle of the image, it's super 8mm. If the sprocket hole is between images, it's 8mm. If your green lever is stuck in the forward position, that's because the film is not threaded. Once your film threads correctly, the green lever will spring back.
I need the owner's manual for a Sears Du-all projector
I believe if you check out the "Manuals & Guides" section of Fixya, they have the manual there. I found many listings for it online, also. Jim
Oct 09, 2012 | Sears Du-all Eight 8mm Projector...
How do I thread the film through an 8mm B&H Projector
http://www.folkstreams.net/vafp/stream.php?id=97
It's about four and a half minutes long, and shows how to clean the various components that need cleaning beforehand as well as how to thread the projector.
However, I wish you good bloody luck on finding a bulb, if you don't have one that still works. From the look of the unit, it uses a DAR bulb, which was delisted (read: went out of production) thirty years ago. You can sometimes find new old-stock (NOS) DAR bulbs on eBay, but expect to pay $30 to $35 apiece plus shipping for them.
Sam
Feb 23, 2009 | BenQ (200NSH-LAMP) Projector Lamp for...
Keystone 8mm movie projector
Re Keystone 68 projectors:
I join the growing throngs of folks who wish to view their family archives in 8 mm before submitting the reels to the digitals for conversion. Doesn't anyone have an answer for us? I continue to search, if I find, I'll post.
Fauvette
Jul 12, 2008 | BenQ (200NSH-LAMP) Projector Lamp for...
Sears Du-all Eight 8mm Projector (584.92040) Logo
496 people viewed this question
Top Sears Office Equipment & Supplies Experts
k24674
jasbo
jasbo
Are you a Sears Office Equipment and Supply Expert? Answer questions, earn points and help others
