Question about Weber Genesis Silver A Grill
Kitchenaid 4 burner gas grill model#720-0745B wont light
frcs68
  • 1605 Answers
SOURCE: weber gas grill wont heat past 300 degrees
are the fire red , orange or blue?
must likely is the burner control.
check the air control at the back of the burner control, it should be open all the way.
it it is, then try another themostate.
Posted on Mar 24, 2009
  • 10 Answers
SOURCE: gas grill
Probably 1 of 3 things:
Check your LP tank valve at an LP filling station. Make sure both valve and tank are in working order.
Next check for webs or cocoons up around where knob valves go into burners. You may have to remove burners to see into back of valves. Then swab orifice holes with a torch tip cleaner.
Third, a Menards , LP outfitter/station, or grill shop should have a universal replacement rubber gas line and "regulator"(possibly plugged or stuck shut). Sometimes you end up with cheap/bad regulator out of the factory.
Good luck and hope one these helps or does the trick.
Posted on Apr 11, 2009
  • 233 Answers
SOURCE: gas flowing to burners 1 and 2 but not 3
there could be debris in the carryover tube..(the open channelled pipe that connects the three burners together) alignment is also critical,
Posted on Jul 12, 2009
SOURCE: Back burner won't light on my Weber Genesis Silver A Gas Grill
Only front burner lights (out of three) and it only has flame comming out of half of the tube.
Posted on Apr 30, 2010
  • 139 Answers
SOURCE: the grill will not light
It may be the regulator replace that and you should be ready to go!
Posted on Jul 07, 2010
I need the user manual for the KitchenAid 4-Burner Stainless Steel Gas Grill model# 720-0745
Ricky, you can order the Owner's Manual from Nex Grill, the manufacturer of KitchenAid Gas Grills. I have supplied a link to it. It's item # 88. At this time, there are no free downloads for this model.
http://www.shopnexgrill.com/products/kitchenaid/720-0745_page2
Happy Grilling!!
Jul 14, 2011 | KitchenAid Grilling
My model is KFGR361SSS. The right burner cllicks when i try to light it, but it won't ignite
You might want to check to make sure that the gas is reaching the burner. If you can light with a match, then your igniter circuit is not aligned properly. If there is no gas getting to the burner, follow the gas line back until you find where it is blocked. OR it could be the switch is bad and not allowing gas to that burner.
Jun 01, 2011 | KitchenAid KFGR361SSS Grill
the first thing you have to due is check to see if gas is coming through the lines. Easiest way to do this is to light the burner with a stick lighter. If you have flame it probally a mis alignment of the igniter. If you cant get the burner to light you probally have a clog some where and you will have to back track the line until you find it. Let me know if you run into problems.
Mike
Jun 01, 2011 | KitchenAid KBGS364PSS Grill
I have a KBNU367TSS and I am having problems with 3 of the 4 ignitors. Two of them will not work at all and one of them gets red but not hot enough to ignite the gas. The rear burner ignitor works fine....
One problem with glo plug ignitions is the loss of voltage across the glo plug. Each glo plug has to have the correct amount of current to get hot enough to light the gas. If the current is to low, the plug will glow, but not light the gas. You have to open the grill up and check the wiring, etc for shorts, bare spots in the wires insulation, etc.
Mar 19, 2011 | KitchenAid KBNU367TSS Gas All-in-One Grill...
Gas will not flow to burner to light grill?
could be the reg on the tank , not working no flow of gas ,
May 15, 2010 | Barbeques Galore Capt'n Cook 4-Burner (NG)...
The new style OPD valves have a small brass ring located in the female fitting on the LP tank. Over time this ring can work loose and then it does not allow the male fitting to fully depress the OPD valve thus reducing your gas flow
Using a small flat bladed screw driver tighten the small brass ring This should solve your problem
Mar 28, 2010 | Barbeques Galore Capt'n Cook 4-Burner (NG)...
Kitchenaid Gas convection range lower burner will
whirlpool oven wont turn on top burner work.
model #SF315PPQ2
Sep 04, 2009 | KitchenAid KGRT607HBS Gas Kitchen Range
Kitchenaid gas stove left back burner won't light. hear clicking
I have one of the kitchenaide gas ranges and if the burner cap is not set on PERFECTLY straight, the gas doesn't flow properly and will not ignite. Try lifting and replacing the cap back down on the burner and see if this solves it.
Mar 05, 2009 | KitchenAid Kitchen Ranges
Cant get the burners to stay lite.
Spiders like to create little hidey webs in the tubes of propane grills and stoves.
Take it apart as much as you can and blow compressed air through all of the holes and apertures. You can either take it to the gas station and us the $.25 air machine or buy a can of compressed air at your computer store.
Apr 13, 2008 | Grilling
Weber Genesis Silver A Grill Logo
Top Weber Grilling Experts
paulcarew
Dan Webster
Dan Webster
Treefrog15
Treefrog15
Are you a Weber Grilling Expert? Answer questions, earn points and help others
